Fwd: Flap + aileron + wing tip alignment
trigo(at)mail.telepac.pt
PostPosted: Fri Nov 13, 2015 8:30 am    Post subject: Fwd: Flap + aileron + wing tip alignment Reply with quote
Enviado do meu iPhone
Too fast hit in the send button....
Guys
The plans say to align the aileron, in its neutral position, to the flap when the flap's leading edge hits the wing rear spar doubler.
But doing this, the trailing edge of the FG wing tip does not align with the aileron.
What to do?
Carlos
Bob Turner
PostPosted: Fri Nov 13, 2015 9:38 am    Post subject: Re: Fwd: Flap + aileron + wing tip alignment Reply with quote
This is common. Fiberglass wingtips too high, too low, too long, etc. You may need to slice open the joint, bend and re-glue, or sand shorter or add glass to lengthen. Don't forget to clamp the elevator neutral during the aileron adjustments - they do move, in tandem, with fore-aft stick motion.
Bob Turner
RV-10 QB
rv10flyer(at)live.com
PostPosted: Fri Nov 13, 2015 10:22 am    Post subject: Fwd: Flap + aileron + wing tip alignment Reply with quote
Bob beat me to my response. I was sying to assure the aileron and flap line
up. that is your priority, than I did as Bob mentioned I molded and shapped
the trailing edge of the wingtip to fit. I recall sanding and reinforcement
but I also recall clamping the wingtip to align with aileron (that was
clamped and aligned with Flap) and used a heat gun to soften the fiberglass
to get the last bit of alignment, than finally added some fiberglass cloth
to reinforcement that area. To this day the alignment is the same.
carl.froehlich(at)verizon
PostPosted: Fri Nov 13, 2015 10:44 am    Post subject: Fwd: Flap + aileron + wing tip alignment Reply with quote
This is the reason I tell any builder who will listen to not fit the
wingtips until after you put on the wings (at least temporarily), really
make sure you have the flaps rigged right, then rig the ailerons. Do not
rely on the Van's aileron template for rigging. It will get you close but
not close enough.
Make sure you do as Bob says on clamping the elevators in neutral before
doing any flap, aileron or wing tip fitting. I chased my tail forgetting to
do that a few times.
Carl
flying-nut(at)cfl.rr.com
PostPosted: Fri Nov 13, 2015 11:52 am    Post subject: Fwd: Flap + aileron + wing tip alignment Reply with quote
Same problem on my friends RV-7.  You can drill a hole in the tip on the side that's high, about 8-10" from leading edge, cleco, and push the tip TE so it aligns with aileron.  Use a ratchet strap from wing LE to tip TE to hold the tip in place to drill and rivet.
We also used two ratchet straps to hold the tip to the wing.
Sent from Samsung tablet cruising on the Allure
-------- Original message --------
From Carlos Trigo <trigo(at)mail.telepac.pt>
Date: 11/13/2015 11:27 AM (GMT-05:00)
To rv10-list(at)matronics.com
Subject RV10-List: Fwd: Flap + aileron + wing tip alignment
--> RV10-List message posted by: Carlos Trigo <trigo(at)mail.telepac.pt>
Guys
What to do?
Carlos
_-============================================================
_-=
_-=       -- Please Support Your Lists This Month --
_-=           (And Get Some AWESOME FREE Gifts!)
_-=
_-=   November is the Annual List Fund Raiser.  Click on
_-=   the Contribution link below to find out more about
_-=   this year's Terrific Free Incentive Gifts provided
_-=   by:
_-=
_-=     * The Builder's Bookstore www.buildersbooks.com
_-=
_-=   List Contribution Web Site:
_-=
_-=   --> http://www.matronics.com/contribution
_-=
_-=   Thank you for your generous support!
_-=
_-=                              -Matt Dralle, List Admin.
_-=
_-=          - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?RV10-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=             - List Contribution Web Site -
Kellym
PostPosted: Fri Nov 13, 2015 12:17 pm    Post subject: Fwd: Flap + aileron + wing tip alignment Reply with quote
I think that method works best. By having wing, flaps and ailerons
installed and rigged first, then you position the tip to line up, secure
it as best you can, and only then drill the screw holes for the tips.
Subject Fwd: Flap + aileron + wing tip alignment
> Guys
with the aileron.
What to do?
Carlos
Kelly McMullen
KCHD
