Speaking of tyres / wheels
kearney
PostPosted: Sun Nov 15, 2015 8:18 am    Post subject: Speaking of tyres / wheels Reply with quote
Hi
Speaking of tryes and wheels, a friend was flying his Maule recently and ended up with a near flat tyre on landing. He suspects he developed a leak while in flight or shortly before takeoff as pre-flight was normal.
This led to an exciting but fortunately painless landing. If he had known one of his wheels was soft he would have been better prepared for things.
For years I have had TPMS in my car. Has anyone found a RV10 compatible tire pressure sensor system? I found this on Amazon:
http://www.amazon.com/Wireless-Monitoring-STEELMATE-Cigarette-Accessories/dp/B015QTPIRO/ref=sr_1_7?ie=UTF8&qid=1447603580&sr=8-7&keywords=steelmate+tpms
Inquiring minds need to know....
Les
Tim Olson
PostPosted: Sun Nov 15, 2015 10:01 am    Post subject: Speaking of tyres / wheels Reply with quote
Keep in mind we use tube tires so any sensor would have to integrate to the tube not the tire.
On Nov 15, 2015, at 10:18 AM, kearney <kearney(at)shaw.ca> wrote:
Hi
Les
http://forums.matronics.com/viewtopic.php?p=449416#449416
jesse(at)saintaviation.co
PostPosted: Sun Nov 15, 2015 10:03 am    Post subject: Speaking of tyres / wheels Reply with quote
As a simple data point, I had a blow-out on landing once in a -10. It did shred the wheel pant, but there was not a strong pull to that side. There was some, but it was easy to keep the plane on the runway. In this case, a floor dolly and a couple of young guys to squat the wing to get the jack under it did the trick to free up the runway.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
On Nov 15, 2015, at 11:18 AM, kearney <kearney(at)shaw.ca> wrote:
Hi
Les
kearney
PostPosted: Sun Nov 15, 2015 10:13 am    Post subject: Re: Speaking of tyres / wheels Reply with quote
Some of the sensor systems seem to use pressurized caps. The problem with that is if the cap fails - well you have a warning of the impending issue.
What I would really like is to put a SMartThings hub in the hanger and then be able tyre pressure remotely. That way I could catch a pressure problem before my wheel pants get broken. But perhaps that is just way too much tech - even for a -10 <vbg>.
Chees
Les
On Nov 15, 2015, at 10:18 AM, kearney <kearney> wrote:
Hi
Les
flying-nut(at)cfl.rr.com
PostPosted: Sun Nov 15, 2015 12:12 pm    Post subject: Speaking of tyres / wheels Reply with quote
That sensor is made to go inside the tire with the stem out. Won't work
with tube-type tires. However, they make screw-on sensors that replace
the Schrader valve cap for tube-type tires. Don't know if the caps hit
the axle nut on angle valve tubes. I have 90* stems so it wouldn't be a
problem until I tried to get them off and put air in the tire with the
wheel pants on.
As Jesse said .... flat tire is a non-event so I'd pass on the TPMS
system and just plan on a landing with a bad tire each time. If your
other car is a tail dragger you already have that skill. Wink
Linn ..... painting
On 11/15/2015 11:18 AM, kearney wrote:
Hi
Les
kearney
PostPosted: Sun Nov 15, 2015 12:58 pm    Post subject: Speaking of tyres / wheels Reply with quote
Lin
How did you manage access to the stems?
I was think of putting 90 degree extensions on as well but was unsure if there was enough clearance.
Cheers
Les
Dropping your pants to check your pressure is a pain.
On Nov 15, 2015, at 13:09, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
That sensor is made to go inside the tire with the stem out. Won't work with tube-type tires. However, they make screw-on sensors that replace the Schrader valve cap for tube-type tires. Don't know if the caps hit the axle nut on angle valve tubes. I have 90* stems so it wouldn't be a problem until I tried to get them off and put air in the tire with the wheel pants on.
As Jesse said .... flat tire is a non-event so I'd pass on the TPMS system and just plan on a landing with a bad tire each time. If your other car is a tail dragger you already have that skill. Wink
Linn ..... painting
> Hi
> Les
PostPosted: Sun Nov 15, 2015 2:56 pm    Post subject: Speaking of tyres / wheels Reply with quote
Folks may not like my solution, and for various reasons don't recommend
anyone else do it.
I drilled a new hole in the wheel to accept the 90* stem. I chamfered
the original hole on both sides and filled it with flox to form a plug.
Assembled the wheel and all was right again in the world.
When I'm done building (in painting mode right now), I'll get a tire
extension and drill a hole at the base of the wheel pant just large
enough for the extension to go through and lined up with the valve stem.
Screw on the extension and fill the tire.
Whoops!!! How to get the stem lined up with that tiny hole? Get the
tire all lined up and paint a line on the inside of the tire wall ....
and you can see the white mark as you pull the plane forward with your
towbar.
Linn
On 11/15/2015 3:55 PM, Les Kearney wrote:
Lin
Cheers
Les
> Linn ..... painting
>> Hi
>> Les
