Stratux Build
Goto page Previous  1, 2
ceengland7(at)gmail.com
PostPosted: Sat Nov 14, 2015 12:12 pm    Post subject: Stratux Build Reply with quote
Sorry; I thought I'd read on the interwebs that the 330 would fit a 327
tray, with just a few added pins. I guess I've discovered the first
error on the 'net. Smile
On 11/14/2015 9:44 AM, Bill Bradburry wrote:
I think you can upgrade the GTX330 to the ES version for about $1K, but per
the Q&A at AC Spruce the GTX327 tray and harness is not interchangeable.
Will the GTX 330 ES fit the same rack as the GTX 327? How about the harness?
The Garmin GTX 330 ES and the GTX 327 use both different racks and
harnesses.
rampil
PostPosted: Sun Nov 15, 2015 6:11 am    Post subject: Re: Stratux Build Reply with quote
Just a Nota Bene:
I have reviewed the Pilot Aware docs and discovered the following:
1) It is not open source. In fact it requires a license code from the author.
2) It uses the iOS hardware GPS. The GPS Chipset in an iPhone or
iPad is not a certificated TSO location source, nor does it even meet
TSO specs. Therefore it would not be legal to transmit data into the
NAS in the US even under the lenient requirements for experimental
aircraft.
3) It only does 1090 Extended squatter (for now). In the UK, ES is the
only game in town. In the US most GA traffic is 978 Hz TISb. So, in the US
PilotAware will show you mostly Transport Category stuff in the Flight Levels
but basically no traffic below FL180 (except near big airports).
Ira N224XS
Kellym
PostPosted: Sun Nov 15, 2015 8:36 am    Post subject: Stratux Build Reply with quote
A large proportion of high performance GA aircraft have or will get
1090ES because their aircraft can go above 18,000 and/or they already
had a Garmin 330 and upgrade to ES is their cheapest option.
Of flight schools in Phoenix that have ADS-B (all the big ones) one uses
978, the rest are all 1090ES.
On 11/15/2015 7:11 AM, rampil wrote:
Just a Nota Bene:
aircraft.
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=449410#449410
Kelly McMullen
KCHD
deej(at)deej.net
PostPosted: Sun Nov 15, 2015 9:12 am    Post subject: Stratux Build Reply with quote
It would be interesting to see actual numbers, but my guess is that at
present, most traffic in the US is on 1090 since most of the aircraft
that are currently equipped are commercial and business. There are also
a likely large number of GA aircraft using 1090 as well, since they will
want to do IFR at reasonably high altitudes.
As we get closer to 2020, we will likely see more GA traffic using 978,
but my gut is telling me that the largest number of traffic overall will
still be on 1090 for the reasons above. There really doesn't seem to be
an advantage to using 978 "Out" as far as I can see, but that does give
good reasons for equipping with a dual band "In" so you can see both.
-Dj
Dj Merrill - N1JOV - EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
bbradburry(at)verizon.net
PostPosted: Sun Nov 15, 2015 11:41 am    Post subject: Stratux Build Reply with quote
Are you saying that the FAA is not going to broadcast the "out" on both
freqs? That makes absolutely not sense to me.
You will be just as dead no matter what airplane you run into.
With the possible exception of Wonder Woman's plane... :>) Does she have
to install ADS-B as well??
wrmaxwell(at)bigpond.com
PostPosted: Sun Nov 15, 2015 1:29 pm    Post subject: Stratux Build Reply with quote
I think your Nota Bene somewhat undersells Pilot Aware, Ira. It is not open-source but the beta licence is free and once it enters the market, the projected annual licence fee is very, very cheap. It can use the iOS GPS but it can equally use any other GPS. In fact, an external GPS is now the developer's preference. I take your point that it might not suit the US at the present time but the potential is there for most locations, provided they solve the ISM transmitter issues and there is widespread adoption so that lower level traffic use it and therefore can be seen.
Bill.
On 16/11/2015 1:11 AM, rampil wrote:
--> AeroElectric-List message posted by: "rampil" <ira.rampil(at)gmail.com> (ira.rampil(at)gmail.com)
Just a Nota Bene:
aircraft.
Ira N224XS
Kellym
PostPosted: Sun Nov 15, 2015 4:16 pm    Post subject: Stratux Build Reply with quote
Your out signal contains what type of In receiver you have, and the
ground station sends you data on your freq. Mostly a moot point for the
ground stations...1090 does not have bandwith for more than TIS-A, so
you get no weather or TIS-B traffic unless you have 978 receiver. Way
more complex than it needed to be.
Kelly McMullen
KCHD
rampil
PostPosted: Sun Nov 15, 2015 5:39 pm    Post subject: Re: Stratux Build Reply with quote
Hi Bill,
I noted the discrepancy about Open Source because the original poster Clive
described it as such.
I have not seen any hard data about the division between 1090 and 978.
However, I have been using a dual receiver Stratux for more than a month.
In my neck of the woods, the traffic I see is airline and corporate on 1090
and the traffic doing less than 300 kts is all 978. Time will tell.
1090 traffic received by an aircraft receiver is solely direct transmission from other aircraft in range.
978 traffic is a combination of direct reception from other aircraft plus
ground-based retransmission of targets both 978 and 1090. (Not to
mention the FISb data)
Ira N224XS
stephencliverichards(at)g
PostPosted: Mon Nov 16, 2015 4:24 am    Post subject: Stratux Build Reply with quote
Hi Ira                  I am sorry for my mistake I should have written Open Hardware I have been following the topic on the Flyer Forum and got my misconception from their.   As some of the other posters on the list were looking for ADSB out I thought it might be worth a look, any grade GPS could be used. If the concept  is of any use to add to Stratus Pi they could write their own code. Our CAA are conducting trials at the moment  using uncertified GPS. There are not a lot of Certified GA aircraft in UK with Mode S transponders using ES because it is a Major mod to connect the two wires to a certified GPS.  I will build one when the transmit is sorted out as due to low cost I think a lot of pilots will take it up and we will be able to see each other + ES traffic.           A lot of pilots are now using Tablets with navigation software like Skydemon or Easy VFR and GPS work with no problem  this is where the traffic would be displayed.
Clive
On 16 November 2015 at 01:39, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
--> AeroElectric-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Hi Bill,
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=449511#449511
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
rampil
PostPosted: Mon Nov 16, 2015 5:18 am    Post subject: Re: Stratux Build Reply with quote
As things stand at the moment in the US domain, there are multiple distinct
hurdles to homebuilding ADSB-Out
1) The first is that microwave (near 1 GHz) circuit design and construction
is complex, much more so than VHF. Not to say it can't be done, but
it requires expert level skill set. There some UHF amateur radio folks who
are proficient, but it is way different than command line hacking a RaspPi.
2) Outside of the ham bands, transmitters of this power output require FCC
certification for a variety of specs including frequency spread, power output, stability, etc.
3) Any transmitter sending data into the NAS (National Airspace System)
requires FAA TSO or, for OBAM and gliders, as I understand the current state
of affairs, meeting TSO spec without actual certification. The specs are
onerous to meet, needless to say.
You get around 1-3 by using a commercial transponder which will take
position data and transmit 1090ES in a regulatory approved manner.
4) So far as I can determine, it is mandatory in the US to use a certified
position source to feed the 1090ES. I'd be shocked to discover that the EU
is less discerning about positional accuracy. I'm not saying that the specs
of a cheap chip set like the RY835 aren't good, they just are not
certified for TSO for ADSB out (so far as I know, and I have read their docx).
Ira N224XS
Kellym
PostPosted: Mon Nov 16, 2015 6:59 am    Post subject: Stratux Build Reply with quote
The best comparison of what it takes is the Dynon Skyview system. They
started with a Trig 1090ES transponder, and had EFIS and moving map
running of commercial grade GPS WAAS chips, with the GPS unit costing
$200 retail. To meet the 2020 requirement, after the FAA clarified that
the GPS had to meet TSO performance specs, but did not need actual TSO
approval for experimental OBAM aircraft; Dynon designed a GPS that had
all the integrity checking features the TSO called for, and is now
offering a "certified" grade GPS that will be legal in US for 2020, at
retail cost of $590. Combined cost of the Trig transponder and the legal
GPS is around $2700 on top of the cost of the EFIS. Not bad, but more
than the Freeflight combination UAT and WAAS GPS unit that is TSO
approved priced around $2000 plus install.
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=449514#449514
Kelly McMullen
KCHD
rd2(at)dejazzd.com
PostPosted: Mon Nov 16, 2015 7:48 am    Post subject: Stratux Build Reply with quote
Just wondering - could the same $590 "certified" GPS (antenna) be used to simultaneously feed a X-ponder and 430W or GTN650 with a splitter ?
(instead of feeding the X-ponder from the 430W; the reasoning is to remain ADS-B compliant in case the 430W is temporarily removed)
Ira N224XS
edpav8r(at)yahoo.com
PostPosted: Mon Nov 16, 2015 8:23 am    Post subject: Stratux Build Reply with quote
Assuming Dynon's GPS outputs standard NEMA sentences over serial comm (they don't have a proprietary data stream) it should be possible. Being a position source itself, does the 430W have provision for position input?
Does anyone know if, or how, the Feds' ADS-B ground system verifies that data it receives from airborne sources is coming from a compliant position source? Does the data stream contain a model-specific code that's compared against an approved list? Or, is compliance enforced like the requirement for a pilot license (i.e. by ramp check)? And no, I'm not advocating $10 eBay GPS receivers! Wink
Eric
On Nov 16, 2015, at 7:46 AM, <rd2(at)dejazzd.com> <rd2(at)dejazzd.com> wrote:
Just wondering - could the same $590 "certified" GPS (antenna) be used to simultaneously feed a X-ponder and 430W or GTN650 with a splitter (instead of feeding the X-ponder from the 430W; the reasoning is to remain ADS-B compliant in case the 430W is temporarily removed)?
Tim Olson
PostPosted: Mon Nov 16, 2015 11:00 am    Post subject: Stratux Build Reply with quote
One thing I have been curious about lately is something I heard
about back a couple years before ADS-B really took off.
I've been running a 978 system since 2009 now, and I personally
think it makes the most sense for 85%+ all of the piston
singles. That said, I think that ideally all systems would
be dual receive. I queried NavWorX about the ADS600B that I have
and it does sound like they intend to add 1090 In to the box
also, to make it a dual receive system, which will be a good thing.
The thing I'm curious about is that I was told by a couple
people within the avionics indrustry that were well knowing,
that the 1090 Mhz system was already fairly "busy" and
nearing saturation for what that frequency could handle for
these communications. It was said at the time basically,
to paraphrase a memory "If every aircraft equipped with
1090 out, it would bring the system to it's knees."
So if that's true, I am surprised we haven't seen any
rulemaking or guidance to the consumer that they should
equip with the most *appropriate* system for their
aircraft. So if you are a small GA aircraft owner, who
has a plane that won't be flying above the 978mhz ceiling,
you use that 978mhz system by default. Maybe they just
assumed that so many pilots would want the 978Mhz systems
anyway, for the free weather products? When getting my Ham
radio license, it was clear that to be radio frequency
friendly that you don't unnecessarily broadcast things
that could interfere, and if the 1090 system is really
that saturated already, I certainly don't need to broadcast
there.
So is there truth the saturation issue, or not?
> the US
> Levels
-Dj
PostPosted: Mon Nov 16, 2015 11:51 am    Post subject: Stratux Build Reply with quote
On November 16, 2015 12:58:37 PM CST, Tim Olson <Tim(at)MyRV10.com> wrote:[quote] [quote]--> AeroElectric-List message posted by: Tim Olson <Tim(at)myrv10.com>One thing I have been curious about lately is something I heardabout back a couple years before ADS-B really took off.I've been running a 978 system since 2009 now, and I personallythink it makes the most sense for 85%+ all of the pistonsingles. That said, I think that ideally all systems wouldbe dual receive. I queried NavWorX about the ADS600B that I haveand it does sound like they intend to add 1090 In to the boxalso, to make it a dual receive system, which will be a good thing.The thing I'm curious about is that I was told by a couplepeople within the avionics indrustry that were well knowing,that the 1090 Mhz system was already fairly "busy" andnearing saturation for what that frequency could handle forthese communications. It was said at the time basically,to paraphrase a memory "If every aircraft equipped with1090 out, it would bring the system to it's knees."So if that's true, I am surprised we haven't seen anyrulemaking or guidance to the consumer that they shouldequip with the most *appropriate* system for theiraircraft. So if you are a small GA aircraft owner, whohas a plane that won't be flying above the 978mhz ceiling,you use that 978mhz system by default. Maybe they justassumed that so many pilots would want the 978Mhz systemsanyway, for the free weather products? When getting my Hamradio license, it was clear that to be radio frequencyfriendly that you don't unnecessarily broadcast thingsthat could interfere, and if the 1090 system is reallythat saturated already, I certainly don't need to broadcastthere.So is there truth the saturation issue, or not?TimOn 11/15/2015 11:09 AM, Dj Merrill wrote:[quote] --> AeroElectric-List message posted by: Dj Merrill <deej(at)deej.net> On 11/15/2015 9:11 AM, rampil wrote:
3) It only does 1090 Extended squatter (for now). In the UK, ES is the only game in town. In the US most GA traffic is 978 Hz TISb. So, in the US PilotAware will show you mostly Transport Category stuff in the Flight Levels but basically no traffic below FL180 (except near big airports).
It would be interesting to see actual numbers, but my guess is that at present, most traffic in the US is on 1090 since most of the aircraft that are currently equipped are commercial and business. There are also a likely large number of GA aircraft using 1090 as well, - --
Sent from my Android device with K-9 Mail. Please excuse my brevity.
PostPosted: Mon Nov 16, 2015 11:56 am    Post subject: Stratux Build Reply with quote
PostPosted: Mon Nov 16, 2015 4:55 pm    Post subject: Stratux Build Reply with quote
On 11/16/2015 1:48 PM, Charlie England wrote:
On November 16, 2015 12:58:37 PM CST, Tim Olson <Tim(at)MyRV10.com> (Tim(at)MyRV10.com) wrote:
--> AeroElectric-List message posted by: Tim Olson <Tim(at)myrv10.com> (Tim(at)myrv10.com)
there.
--> AeroElectric-List message posted by: Dj Merrill <deej(at)deej.net> (deej(at)deej.net)
the US
Levels
since they will
-Dj
Shouldn't be too hard to do the math. How many micro seconds does each squit occupy & how many Micro seconds must the transponder listen before squitting? The 'window' could be many seconds wide, so if there's, say, a 5 million micro second window and a 50 micro second 'listen/squit' interval, that would be room for 100,000 planes.
Followup; just found a pdf comparing ES to mode A & C. max time according to the doc is ~120 uSeconds, & a/c transmit once per second, without interrogation.  So, if we roughly double that to 250 uSeconds & assume a 1 second repetition rate, that's 1,000,000/250= only 4000 planes in a given area. If we halve that again to be really conservative, it's still 2k planes in an area.
Link to the doc (1st one I landed on):
http://www.ssd.dhmi.gov.tr/getBinaryFile.aspx?Type=3&dosyaID=195
richard.beebe(at)yale.edu
PostPosted: Tue Nov 17, 2015 7:04 am    Post subject: Stratux Build Reply with quote
For Experimental Aircraft, the Navworx ADS600-EXP is a self-contained
ADS-B in and out for about $1200. The ADS600-B at $1999 is for certified
aircraft and seems very similar to the FreeFlight unit. However the
Navworx units are both in and out and for $100 you can add wifi to
display traffic & weather on a tablet. The $1999 FreeFlight unit is out
only. Their in/out box is $3700.
I went to an ADS-B seminar on Sunday and the presenter said that Mexico
is going to require 1090ES. I haven't been able to verify that, however.
Just another datapoint if you're trying to decide on UAT vs 1090ES.
Something else I hadn't realized--for those thinking they can avoid
airspace where you need ADS-B out--is that you can't fly over the top of
any Class-B (actually the mode C veil) without ADS-B because the veil
extends to 10,000' and ADS-B is required (in most places) above 10,000'.
In my part of the country that's a significant inconvenience.
--Rick
Page 2 of 2
