cjhukill(at)cox.net Guest
Posted: Fri Nov 20, 2015 6:05 am Post subject: wheel jack fixture |
Unfortunately there is no source to buy this fixture, that I could find, hence I made my own. It was easy enough to build, but someone with a CNC shop could mass produce and sell them for profit. With 10,000 RVs flying, most with round gear legs, there is certainly a market. As far as needing two, you could get by with one. Just jack the first wheel and then lower the axel onto a 4X4, remove the jack and raise the second wheel. With the first wheel on the 4X4, I would make sure the wings are tied down. I personally would service one wheel at a time though. To build one, get some thick wall 4130, turn the inside of the large tube to match the taper of the leg. This step is optional if you don’t have a lathe. Instead get tube that is slightly larger than the legs, and wrap the leg with tape, with more wraps at the bottom, to make the leg parallel. Next cut the tube for the bottle jack head at the correct angle and use a mill, or file to match the outer diameter and angle of the leg tube were it will attach. Size and weld a thick washer to the inside of the bottle jack tube from the top, so that the jack head has something to push on, and is captured snuggly into the tube. This step assures the jack can’t slip out of the fixture. Weld the jack tube to the leg tube. Next fabricate the four bolt tubes from again thick wall 4130, and weld them to the leg tube, making sure they are all square to each other and the leg tube, otherwise it will be difficult to get all the bolts through the lower half as an assembly. After welding everything together, cut it all in half. Done!
Chris Hukill
Kelly McMullen
Posted: Fri Nov 20, 2015 6:20 am Post subject: wheel jack fixture |
For those not having welding or lathe, you can make something similar with a couple 2X4 scraps. Just drill for a couple 1/4" bolts beyond the width of the steel tube. Then measure gear leg and get a hole saw of right diameter. Bolt the pieces together, run the hole saw through at the parting line, and you are done. I did similar deal for flat steel gear legs for older Cessna. Worked fine. I will be using wing jacks since I have had a pair for the 15 years I owned my Mooney and needed to jack it up for any gear work.
On Fri, Nov 20, 2015 at 7:02 AM, Chris Hukill <cjhukill(at)cox.net (cjhukill(at)cox.net)> wrote:
| Quote: | Unfortunately there is no source to buy this fixture, that I could find, hence I made my own. It was easy enough to build, but someone with a CNC shop could mass produce and sell them for profit. With 10,000 RVs flying, most with round gear legs, there is certainly a market. As far as needing two, you could get by with one. Just jack the first wheel and then lower the axel onto a 4X4, remove the jack and raise the second wheel. With the first wheel on the 4X4, I would make sure the wings are tied down. I personally would service one wheel at a time though. To build one, get some thick wall 4130, turn the inside of the large tube to match the taper of the leg. This step is optional if you don’t have a lathe. Instead get tube that is slightly larger than the legs, and wrap the leg with tape, with more wraps at the bottom, to make the leg parallel. Next cut the tube for the bottle jack head at the correct angle and use a mill, or file to match the outer diameter and angle of the leg tube were it will attach. Size and weld a thick washer to the inside of the bottle jack tube from the top, so that the jack head has something to push on, and is captured snuggly into the tube. This step assures the jack can’t slip out of the fixture. Weld the jack tube to the leg tube. Next fabricate the four bolt tubes from again thick wall 4130, and weld them to the leg tube, making sure they are all square to each other and the leg tube, otherwise it will be difficult to get all the bolts through the lower half as an assembly. After welding everything together, cut it all in half. Done!
Chris Hukill
A&P/IA, EAA Tech Counselor
KCHD |
