Stud removal question
rleffler
PostPosted: Sat Nov 28, 2015 11:50 am    Post subject: Stud removal question Reply with quote
I was removing some studs today. I got them all out but one. Unfortunately, one broke off about 3/8" to 1/2" from the engine block. The stud is on the oil filter adapter, it I don't think that's important.
I don't have any experience here. I'm looking for assistance to understand what options may be available to me. I'm hoping I can find a solution other than drilling it out.
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
Kellym
PostPosted: Sat Nov 28, 2015 12:59 pm    Post subject: Stud removal question Reply with quote
If you have enough protruding, double nut stud, then back it out. Some
heat likely will help, but don't over do it. If there isn't enough left
for that, there are extractors with left hand threads that will grab and
start turning stud when you tighten them on. If nothing is protruding
you are pretty much left with drilling enough to get an extractor into
the resulting hole.
As to your re-assembly, Rapco makes a crowfoot wrench specifically for
the vacuum pump pad. It is the solution for the most difficult nut.
Kelly McMullen
KCHD
saolesen(at)sirentel.net
PostPosted: Sat Nov 28, 2015 1:53 pm    Post subject: stud removal question Reply with quote
Check out this website for a how to on broken stud removal.
diymotofix.com Click on "Blog." The article is on the right side under Categories. The article is "Fixing Broken Bolts."
Be sure to wish the author a Happy Birthday! I have very good knowledge that he is 27 today.
Sheldon Olesen
bob88
PostPosted: Mon Nov 30, 2015 9:41 pm    Post subject: Re: Stud removal question Reply with quote
I had the same problem, defied all recommended techniques. I finally drilled out the old broken off stud. I then tapped oversize to 5/16 and used a bolt. A more elegant solution might be a helicoil.
