hivanhaecker(at)gmail.com Guest
Posted: Mon Nov 30, 2015 3:46 pm Post subject: Testing of Overvoltage Module |
I have a need to test my ov module. I found a link from the aeroelectric connection detailing the method. Not having a variable dc power supply, I have ordered one (Tekpower TP3005T). My question is what purpose is the precision voltmeter shown in the link for the test. Doesn't the dc power supply setting tell you what voltage you are supplying to the ov module? Sorry if my question displays a lack of basic knowledge, but that's how I learn.
Ivan Haecker
ceengland7(at)gmail.com Guest
Posted: Mon Nov 30, 2015 5:28 pm Post subject: Testing of Overvoltage Module |
On 11/30/2015 5:44 PM, H. Ivan Haecker wrote:
| Quote: | I have a need to test my ov module. I found a link from the
Ivan Haecker
Answer is, it depends. Lots of 'old school' variable supplies had
analog meters that, even if inherently accurate, didn't have enough
resolution to read less than ~1/2-1 volt of change; not good enough when
you're trying to set something to the nearest tenth of a volt. Even if
the PS has a built in digital meter, it'd be a good idea to verify it's
accuracy with a known good digital meter before trying to set up
something like the OV module.
Charlie
Posted: Tue Dec 01, 2015 5:43 am Post subject: Testing of Overvoltage Module |
At 05:44 PM 11/30/2015, you wrote:
| Quote: | | I have a need to test my ov module. I found a link from the aeroelectric connection detailing the method. Not having a variable dc power supply, I have ordered one (Tekpower TP3005T). My question is what purpose is the precision voltmeter shown in the link for the test. |
If your power supply voltmeter is of sufficient
resolution/accuracy, then the external voltmeter
is unnecessary.
| Quote: | | Doesn't the dc power supply setting tell you what voltage you are supplying to the ov module? Sorry if my question displays a lack of basic knowledge, but that's how I learn. |
The TP3005 is adequate to the task 'barefoot'.
Just turn the current setting all the way up,
then hook the ovm across the power supply output
terminals. Slowly increase the voltage until
the ovm 'trips' (Current jumps up, voltage goes
down). The trip should be in the range of 16.0
to 16.5 volts.
