		JohnInReno
				 Posted: Sun Dec 06, 2015 4:16 pm    Post subject: Weak Starter |
				My Skytec starter barely turns over an IO320.
 I measured:
 Battery 13.12 volts.
 "On" side of master contactor to airframe ground 12.25 volts.
 "On" side of starter contactor to airframe ground while cranking 8.6 to
 9.0 volts.
 Big wire on starter to airframe ground while cranking is 8.6 volts or less.
 All this was done with a genuine Harbor Freight $4.00 digital meter. I
 believe that this points to the starter contactor as the culprit. Correct?
 john
  _________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
		jmjones2000(at)mindspring Guest
				 Posted: Sun Dec 06, 2015 4:53 pm    Post subject: Weak Starter |
				Is say high resistance in the starter contactor
 More than likely due to internal arcing. This causes corrosion and pitting.
 Slap a new contactor on there and I bet it fixes the issue.
 Afterwards, dissect the old contactor to see exactly what happens internally.
 Justin.
  	  | Quote: | 	 		   On Dec 6, 2015, at 16:15, John Morgensen <john(at)morgensen.com> wrote:
  I measured:
  "On" side of starter contactor to airframe ground while cranking 8.6 to 9.0 volts.
  All this was done with a genuine Harbor Freight $4.00 digital meter. I believe that this points to the starter contactor as the culprit. Correct?
  john
		ceengland7(at)gmail.com Guest
				 Posted: Sun Dec 06, 2015 5:50 pm    Post subject: Weak Starter |
				On 12/6/2015 6:15 PM, John Morgensen wrote:
  I measured:
  to 9.0 volts.
  less.
  Correct?
  john
 12.25 volts with minimal load (contactor coil only) *might* be a little
 weak for a fully charged battery. The measurement doesn't really mean a
 lot if there's no load on the other side of the contactor. You could put
 a 100,000 ohm resistor in series & still measure full battery voltage on
 the other side of the resistor, as long as there's no load to ground.
 What's the measurement at the 'on' side of the master contactor while
 cranking? (Don't change test conditions.)
 Another method of measurement when looking for bad joints/high
 resistance in a high current circuit:
 1. Measure from the battery positive post (not the bolt or clamp) to the
 starter positive post while cranking. A voltage drop of greater than
 ~1/2 volt means you have a high resistance somewhere between battery &
 starter.
 2. Measure from the frame (ground) of the starter to the actual negative
 post on the battery (not the bolt or clamp) while cranking. That
 measurement should again be less than 1/2 volt. If not, you have high
 resistance in the ground circuit.
 8.5-9 volts across the starter windings while under load really doesn't
 sound bad, as long as the rest of the circuit is 'right' and the battery
 is in good shape.
 Charlie
				 Posted: Sun Dec 06, 2015 5:56 pm    Post subject: Weak Starter |
 > I measured:
 > to 9.0 volts.
 > less.
 > Correct?
 > john
 Edit: I missed the 1st line, battery 13.2 & load side of contactor at
 12.25. The contacts in the master contactor have really high resistance
 to see that much drop.
  	  | Quote: | 	 		   12.25 volts with minimal load (contactor coil only) *might* be a
  little weak for a fully charged battery. The measurement doesn't
  really mean a lot if there's no load on the other side of the
  contactor. You could put a 100,000 ohm resistor in series & still
  measure full battery voltage on the other side of the resistor, as
  long as there's no load to ground. What's the measurement at the 'on'
  side of the master contactor while cranking? (Don't change test
  conditions.)
  the starter positive post while cranking. A voltage drop of greater
  than ~1/2 volt means you have a high resistance somewhere between
  battery & starter.
  negative post on the battery (not the bolt or clamp) while cranking.
  That measurement should again be less than 1/2 volt. If not, you have
  high resistance in the ground circuit.
  doesn't sound bad, as long as the rest of the circuit is 'right' and
  the battery is in good shape.
  Charlie
		Kellym
				 Posted: Sun Dec 06, 2015 6:42 pm    Post subject: Weak Starter |
				You probably need to replace both starter relay and master relay.
 Download Skytec's troubleshooting chart and follow it carefully.
 On 12/6/2015 5:15 PM, John Morgensen wrote:
  I measured:
  to 9.0 volts.
  less.
  Correct?
  john
KCHD |
		wgreenley
  Joined: 09 Jan 2010 Posts: 100 Location: Dowagiac, MI
				 Posted: Mon Dec 07, 2015 4:05 am    Post subject: Weak Starter |
				I agree, I had these same issues on my 172 and it was the master relay, the starter relay was fine. I replaced both as they were both of the same vintage. Starting problems gone.
 Bill
		JohnInReno
				 Posted: Mon Dec 07, 2015 6:07 am    Post subject: Weak Starter |
				Thanks for all of the replies.
 Skytec's troubleshooting chart says that the starter needs to see 10+
 volts. I will be replacing both relays.
 john
 On 12/6/2015 6:41 PM, Kelly McMullen wrote:
  <kellym(at)aviating.com>
 > I measured:
 > to 9.0 volts.
 > less.
 > Correct?
 > john
RV4 - for sale |
		skywagon
				 Posted: Mon Dec 07, 2015 10:13 am    Post subject: Weak Starter |
				John,
 A problem like you are seeing can also be caused by an "aged" main battery.
 The battery V measures fine with no load, may also measure fine with just a
 buss current load, but, when it sees a "starter" type current load (200 -
 300 amps), it slumps badly.  Usually caused by a cell or two that are too
 aged to produce the amps needed.
 Only answer is to install a new battery and keep it fresh by keeping a low
 current "maintainer" style charger on it during hangar periods.
 David
		JohnInReno
				 Posted: Mon Dec 07, 2015 11:22 am    Post subject: Weak Starter |
				David,
      Be careful with "maintainer" style chargers and Odyssey PC680     batteries. Notice that the warranty can be voided:
      C. The warranty does not cover a Battery that is damaged or     destroyed as a result of one for more of the
      following:
      Willful abuse, misuse, physical damage, neglect or if the top     decorative cover has been removed.
      Natural forces such as wind, lightning, hail; damage due to fire,     collision, explosion, vandalism, theft,
      penetration or opening of the Battery case in any manner.
      Overcharging, undercharging, charging or installing in reverse     polarity, improper maintenance, allowing
      the Battery to be deeply discharged via a parasitic load or     mishandling of the Battery such as but not
      limited to using the terminals for lifting or carrying the Battery.       Trickle chargers that do not have a regulated
      trickle charge voltage between 13.5V and 13.8V (no lower than       13.5V and no higher than 13.8V) will cause
      early failure of the Battery. Use of such chargers with     the Battery will also void the Battery’s warranty. For
      applications where an alternator is present, the alternator must     deliver between 14.0V and 14.7V when
      measured at the Battery’s terminals. Alternators that do not have a     regulated charge between 14.0V and
      14.7V (no lower than 14.0V and no higher than 14.7V) will cause     early failure of the Battery. Use of such
      alternators with the Battery will also void the Battery’s warranty
      I thought I was doing the right thing by religiously using a quality     Battery Minder but it destroyed the battery. They use to publish a     list of unacceptable chargers but I can't find it on their web site     any more.
      john
      On 12/7/2015 10:11 AM, David Lloyd       wrote:
      [quote]--> AeroElectric-List message posted by: "David       Lloyd" <skywagon(at)charter.net> (skywagon(at)charter.net)
        John,
        The battery V measures fine with no load, may also measure fine       with just a buss current load, but, when it sees a "starter" type       current load (200 - 300 amps), it slumps badly.  Usually caused by       a cell or two that are too aged to produce the amps needed.
        Only answer is to install a new battery and keep it fresh by       keeping a low current "maintainer" style charger on it during       hangar periods.
        David
RV4 - for sale |
				 Posted: Mon Dec 07, 2015 12:44 pm    Post subject: Weak Starter |
				I would second the points made below in       John's post.
        Over the past 9 years I've managed to abuse and slowly kill a       number of PC680s in a variety of ways.  Simply reading and       FOLLOWING the guidelines documented in their Owner's Manual,       including the fine print of the Warranty, will avoid ALL of the       problems I've experienced.
        Why didn't I?  Well, since I grew up charging batteries from early       60s electric tooth brushes that could barely handle a full set of       teeth, to gliders, boats, cars and 50 years of RC aircraft, I must       know what I'm doing. So I've taken the time to rediscover and       learn anew all that was already known about Odessy's AGM line of       batteries.  I'm almost done with my studies...
        Regarding trickle chargers, according to the Manual, "..there is       no need to trickle or float charge during winter months."  It       continues, "It can be stored for 2 years or more below 77F."  If       you insist, see Warranty notes reproduced below.  If you do have       some kind of parasitic load on the battery during storage (I had       that), get it fully charged (you must start there) , apply a       trickle charger that can produce the regulated voltage (I didn't),       then for good measure, fully charge it before using it.  Better,       just disconnect the load and save the cost of the trickle       charger.... or $150 lets you start the learning process from the       beginning again.
        Just to repeat, I've found the information in Odyssey's Owner's       Manual to be complete and accurate in every way.  The only thing       that upsets me is that they cost $150 a copy, but at least it       comes with a fresh battery.
        Bill "content to remain ignorant about Lithium technologies and to       simply enjoy their performance" Watson
        On 12/7/2015 2:21 PM, John Morgensen wrote:
      [quote]              David,
        following:
        john
          John,
          David
		speedy11
  Joined: 29 Jun 2015 Posts: 62 Location: Port Orange, FL
				 Posted: Tue Dec 08, 2015 5:02 pm    Post subject: Weak Starter |
				John,
  I had the same issue on my IO-390.  Skytec worked okay for five years then got slower and slower.  I did all of the same checks you are talking about.  Replaced the starter.  Problem solved.
  See if you can borrow a starter from someone and try it on your plane.
  Stan
      	  | Quote: | 	 		  My Skytec starter barely turns over an IO320.
   I measured:
   9.0 volts.
   john |
				 Posted: Tue Dec 08, 2015 9:11 pm    Post subject: Weak Starter |
				Be advised, some if not all lycoming skytec starters have a contactor (solenoid) on the starter as well.
 [quote] On Dec 8, 2015, at 16:59, speedy11(at)aol.com wrote:
  John,
  Stan
  I measured:
  9.0 volts.
