glipaz
Posted: Wed Oct 14, 2015 8:57 pm Post subject: Air leak from both gear handles |
I have a small leak coming from the rear gear handle in the neutral position. Now I also started getting air from the front gear handle in both neutral and down positions. I have not put it on jacks yet to put it in up position. Any ideas?
JL2A
Posted: Mon Oct 26, 2015 2:51 pm Post subject: Re: Air leak from both gear handles |
could be the handles themselves (corroded or worn selector / body interface). I've had that on the flap handles, had them machined flat again and worked ever since then. Doug Sapp sells stainless ones to avoid this problem.
Posted: Mon Oct 26, 2015 4:29 pm Post subject: Air leak from both gear handles |
I'd be suspicious of either an actuator or actuators or the diverter ir shuttle valves more so than the gear selectors themselves.
Troubleshoot them one by one by removing the B nut from the UP side of each actuator one at a time. With the main air on, put some saliva on the elbow after you remove the B nut. If it bubbles, air is passing by the seals in that actuator. Do this to each actuator. I'll bet you'll find at least one is leaking past the internal seals.
Dennis
To: yak-list(at)matronics.com
Sent: Monday, October 26, 2015 6:51 PM
Subject: Re: Air leak from both gear handles
--> Yak-List message posted by: "JL2A" <info(at)flyingwarbirds.com.au (info(at)flyingwarbirds.com.au)>
http://forums.matronics.com/viewtopic.pronics.com/Navigator?Yak-List" target="_blank">http://www.matronics.com/N - MATRONICS WEB FORUMS -http
glipaz
Posted: Sun Nov 01, 2015 2:59 pm Post subject: Re: Air leak from both gear handles |
Dennis, I tested all three gear actuators and all are good; no leaks on the upside. How do I know if it's the handle vs a valve?
glipaz
Posted: Wed Dec 09, 2015 9:03 pm Post subject: Re: Air leak from both gear handles |
Repair completed. Replaced rear cockpit gear valve assy and leak stopped.
JL2A
Posted: Sun Dec 13, 2015 3:27 am Post subject: Re: Air leak from both gear handles |
Did you pull apart the selector to see what the problem was?
