Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 25204 Location: Livermore CA USA
Posted: Fri Dec 18, 2015 2:40 pm Post subject: Lycoming O-360 Fuel Flow Rate |
I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me?
I pulled the fuel line off the carburetor and turned the electric fuel pump on and saw about 21 GPH flow. Is that considered "normal" or too low?
Thanks for the feedback,
Matt
Status: 210+ Hours TTSN - Version 2.0 Now Flying!
Status: 300+ Hours - Full Flyer Mode!
_________________ Matt Dralle
Matt
Matt
Posted: Fri Dec 18, 2015 2:43 pm Post subject: Lycoming O-360 Fuel Flow Rate |
Matt
jmjones2000(at)mindspring Guest
Posted: Fri Dec 18, 2015 3:04 pm Post subject: Lycoming O-360 Fuel Flow Rate |
Matt,
This sounds a bit low to me but is in the realm of possibilities. If you don't have any symptoms of low power output from the engine, I'd top the tanks off, fly overhead for 1 or 2 hours, land, refill, and verify the average fuel burn you saw on the instrument is the same as that was actually burned.
Justin
Quote: | On Dec 18, 2015, at 16:38, Matt Dralle <dralle(at)matronics.com> wrote:
Matt
Bob Turner
Posted: Fri Dec 18, 2015 3:10 pm Post subject: Re: Lycoming O-360 Fuel Flow Rate |
Hi Matt,
Looks low to me too. Are you sure of the FF calibration?
I forget what engine you have, but a rule of thumb is full power/full rich FF should be about 0.95*HP/10.
So if your engine makes 160HP at 2700 rpm, and you had 2400 rpm, then roughly you had 24/27 * 160 = 142 HP, times .95/10 = 13.5 gal/hr. So 9 looks low.
_________________ Bob Turner
RV-10 QB |
bill.peyton
Posted: Fri Dec 18, 2015 4:32 pm Post subject: Re: Lycoming O-360 Fuel Flow Rate |
Matt,
I used to see 14gph on my O360 in climb...
_________________ Bill
WA0SYV
Aviation Partners, LLC |
Posted: Sat Dec 19, 2015 4:32 am Post subject: Lycoming O-360 Fuel Flow Rate |
You should see about .9 GPH per 10 horsepower, so if you have a 180HP engine, you should see around 16-17 GPH on takeoff. 9 GPH at 2350-2400 rpm sounds way too low, especially if manifold pressure is high.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Quote: | On Dec 18, 2015, at 5:38 PM, Matt Dralle <dralle(at)matronics.com> wrote:
Matt
jdriggs49(at)msn.com Guest
Posted: Sat Dec 19, 2015 8:34 am Post subject: Lycoming O-360 Fuel Flow Rate |
Great set of charts! Anybody have that for a IO-540???
________________________________________
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of Werner Schneider <glastar(at)gmx.net>
Sent: Saturday, December 19, 2015 7:48:53 AM
Subject: Re: Lycoming O-360 Fuel Flow Rate
Matt,
attached an engine chart for several O-360 types, so 9 gal/hr seems to
be a bit on the leaner side, are you sure your carburetor is correctly
set from a mixture point of view? It would give you roughly 120 hp
according the charts.
Fuel flow with 21 gals/hr are just ok, according the FAR's the max flow
you have to supply is 125% of what the engine can surge at max power,
according the charts about 16.5 gal/hr with 2700 and 180hp *1.25 =
20.625 gal/h so just about...
But I would rather crosscheck your fuel flow meter first, get a bucket
unscrew the fuel line and time 2-3 times what it takes to fill the
bucket with 1 gal and compare to your FF meter.
Cheers Werner
Posted: Sat Dec 19, 2015 12:47 pm Post subject: Lycoming O-360 Fuel Flow Rate |
Thank you to everyone that responded!! There were some great comments that got me going down the right path.
Last night I got the cowling back on and took the RV-6 out on the runway and ran it up to full power with the intent of carefully watching the flow rate and aborting the take off if the flow wasn't sufficiently high enough. I'm happy to report that the flow rate climbed nicely up though the teens as my takeoff roll progressed. I lifted off around 15-16 gph and decided to take it around the pattern. As I climbed through the crosswind to downwind turn I noted that the flow was in the 18.5gph range, RPM was at 2700, and EGTs were low 1300's. After a few more loops around the pattern everything seemed to be working as expected. I took it out of the pattern and dialed it into my normal cruse configuration which is typically 75% power at 2250 RPM and leaned to about 1425 on the hottest EGT. Everything sounded and felt fine. Flow was right at 9.5 GPH per usual.
The only weird thing I noticed was at about 1700 RPM. When I turn from Downwind to Base and go from idle to about 2000 RPM like I usually do, right about 1700 RPM the engine kind of sags and then picks back up. It is very repeatable. Strangely there is no sag on the ground after a touch and go when I push the throttle in fast going from idle to full power anymore like there was with the old carb.
Does anyone have any idea what that sag at 1700 is? Is there a nurd knob on the carb for this specifically?
Thanks again for the great feedback!
At 02:38 PM 12/18/2015 Friday, Matt Dralle wrote:
Quote: | I'm still chasing down this weird problem with low fuel flow rates on the RV-6. I've replaced the mechanical fuel pump and got a rebuilt 4-5 carburetor, both of which were well over do for replacement/overhaul anyway. I haven't put the cowling back on yet, but I did a static run up to about 2350-2400 and am seeing about 9gph, which seems low to me?
Matt
Matt
Posted: Sat Dec 19, 2015 12:48 pm Post subject: Lycoming O-360 Fuel Flow Rate |
Matt
Posted: Sat Dec 19, 2015 12:50 pm Post subject: Lycoming O-360 Fuel Flow Rate |
Matt
Posted: Tue Dec 22, 2015 12:19 pm Post subject: Lycoming O-360 Fuel Flow Rate |
Well, it was probably the fuel pump. I think my flow rates right after replacing the fuel pump (but before I replaced the carb) were probably alright as they were similar to what I saw after the new carb. But, it was time for a new carb anyway, so I guess it worked out. Btw, as if all of this debacle wasn't frustrating enough, last weekend while trying to test all of this, the battery went dead. Checking the logs it was 36 months ago since I replaced it the last time. Guess that's about right. Sigh. Is it time to fly it yet? I've been working on it enough lately.
At 10:24 AM 12/21/2015 Monday, you wrote:
Quote: | So what did you do to fix the problem Matt?
Harry Crosby
To: "RV-List" <rv-list(at)matronics.com>, LycomingEngines-list(at)matronics.com, rv6-list(at)matronics.com, rv10-list(at)matronics.com
Sent: Saturday, December 19, 2015 12:44:41 PM
Subject: RV-List: Re: Lycoming O-360 Fuel Flow Rate
>Matt
Posted: Tue Dec 22, 2015 12:20 pm Post subject: Lycoming O-360 Fuel Flow Rate |
Harry Crosby
>Matt
Harry Crosby
>Matt
Posted: Tue Dec 22, 2015 12:22 pm Post subject: Lycoming O-360 Fuel Flow Rate |
Harry Crosby
>Matt
rv10flyer(at)live.com Guest
Posted: Tue Dec 22, 2015 1:23 pm Post subject: Lycoming O-360 Fuel Flow Rate |
Matt;
I run a battery excerciser, or in my case a Battery tender and have had
the battery for 5 years, still going strong. if you arent keeping the
battery excercised that may be the issue with a 3 year life span. Or
maybe that is normal for aircraft batteries? I am using a wheel chair
battery. (UB12350)
Pascal
> Harry Crosby
> From: "Matt Dralle" <dralle(at)matronics.com>
> Matt Dralle
>> Matt
> Matt Dralle
