flysrv10(at)gmail.com Guest
Posted: Mon Dec 28, 2015 7:25 am Post subject: Slick mags 1100 hrs |
Tim,
I had to cut the tangs off my new cushions. Once cut, they are exactly the same as the old cushions and fit perfect.
I have forwarded my initial conversation with Lycoming but did not continue the inquiry once I saw that I can modify the new part to fit my mag drive.
You might contact them if you feel that the modified cushions are not appropriate. I did not feel replacing the my mag drives for new mag drives was necessary.
Do not archive.
Rob Kermanj
Begin forwarded message:
| Quote: | <![endif]--> <![endif]-->
Kermanj,
P/N LW-13641 superseded by P/N 68H22624 CUSHION- MAGNETO DRIVE attached is a reference for you.
Best Regards,
Deb
Sent: Monday, December 14, 2015 9:51 AM
To: Day, Deborah
Subject: FW: Lycoming Website Contact Us Inquiry
Hello Deb,
Would you be able to assist Rob?
Best Regards,
Heath Johnson
Field Service Technical Representative
Lycoming Engines, a div. of Avco Corporation
Phone: 570-327-7335
Fax: 570-327-7101
hjohnson(at)lycoming.com (hjohnson(at)lycoming.com)
NOTICE: This E-mail (including attachments) is covered by the Electronic Communications Privacy Act, 18 U.S.C. §§ 2510-2521, is confidential and may be legally privileged. If you are not the intended recipient, you are hereby notified that any retention, dissemination, distribution, or copying of this communication is strictly prohibited. Please reply to the sender that you have received the message in error, and then delete it. Thank you.
Sent: Tuesday, December 08, 2015 2:11 PM
To: Technicalsupportn (Lycoming)
Subject: Lycoming Website Contact Us Inquiry
Lycoming Website Contact Us Inquiry:
First Name: rob
Last Name: Kermanj
Company Name: Company Name
Email: flysrv10(at)gmail.com (flysrv10(at)gmail.com)
Phone: 7724181417
City: Port Saint Lucie
Address: 12350 Golden Eagle Street
State: FL
Zip: 34987-2531
Country: United States
Comment: Hi, I have a IO-540 SN L1427-48. Mag cushion LW-13641 has been replaced with a new model with a tang. However, my engine does not have a tang and I wonder what is the exact replacement part for my mag drive. Thank you Rob.
 Download |
| Filename: |
SI1299B[1].pdf |
46.22 KB |
| Downloaded: |
1166 Time(s) |
Tim Olson
Posted: Mon Dec 28, 2015 8:54 am Post subject: Slick mags 1100 hrs |
Thanks a ton Rob! That was one of my big questions...was the size
right if I cut the tangs off. It's funny that they didn't make
a mention of that to you in the correspondence but if the fit
with the tang removed is the same, it would make sense that it
would work just fine. As long as the rest of that part is
physically the same, I'll be happy. It just caught me off
guard that I ordered the old number and got the new style.
I'm glad I'm not the only one who's had that happen...and you
even got yours from Lycoming.
On 12/28/2015 9:21 AM, Rob Kermanj wrote:
| Quote: | Tim,
mag drive.
Do not archive.
Rob Kermanj
> *From:* "Day, Deborah" <DDay(at)lycoming.com <mailto:DDay(at)lycoming.com>>
> *Date:* December 16, 2015 at 8:46:15 AM MST
> *To:* "flysrv10(at)gmail.com <mailto:flysrv10(at)gmail.com>"
> <flysrv10(at)gmail.com <mailto:flysrv10(at)gmail.com>>
> *Subject:* *RE: Lycoming Website Contact Us Inquiry*
> Kermanj,
> Best Regards,
> Deb
> *From:*Technicalsupportn (Lycoming)
> *Sent:* Monday, December 14, 2015 9:51 AM
> *To:* Day, Deborah
> *Subject:* FW: Lycoming Website Contact Us Inquiry
> Hello Deb,
> Best Regards,
> *Heath Johnson*
> Phone: 570-327-7335
> Fax: 570-327-7101
> hjohnson(at)lycoming.com <mailto:hjohnson(at)lycoming.com>
> *From:*Lycoming Communications
> *Sent:* Tuesday, December 08, 2015 2:11 PM
> *To:* Technicalsupportn (Lycoming)
> *Subject:* Lycoming Website Contact Us Inquiry
> First Name: rob
> Last Name: Kermanj
> Email: flysrv10(at)gmail.com <mailto:flysrv10(at)gmail.com>
> Phone: 7724181417
> State: FL
> Zip: 34987-2531
Posted: Tue Dec 29, 2015 3:51 pm Post subject: Slick mags 1100 hrs |
Bought mine from aircraft acc stories and contact d Lycoming to be sure it was the only part available.
I also made sure thatcher are physically the same once the tangs were cut.
Do not archive.
Rob Kermanj
> Tim,
> mag drive.
> Do not archive.
> Rob Kermanj
> Sent from my iPad
>> Kermanj,
>> Best Regards,
>> Deb
>> *To:* Day, Deborah
>> Hello Deb,
>> Best Regards,
>> *Heath Johnson*
>> Phone: 570-327-7335
>> Fax: 570-327-7101
>> First Name: rob
>> Last Name: Kermanj
>> Phone: 7724181417
>> State: FL
>> Zip: 34987-2531
