bob.verwey(at)gmail.com Guest
Posted: Tue Dec 29, 2015 12:20 am Post subject: Alternator and regulator connections |
Happy Holidays everyone!
Time for me to emerge from my lurking mode to enlist some help.
I have a Kelly Aerospace ALY 8520 alternator, with two field connections.
The regulator is an Echlin unit, 5 MSA 6, a locally built automotive unit with 5 wires:
warn lite
ign
reg sense --not sure what this is for
neg
field.
Now despite trawling the web, and being electrically challenged, I am unable to figure out how to connect this setup.
Regards the warn lite...would there be 12v emanating from the regulator so that a lite with one terminal grounded would then light up?
I would really appreciate some help or suggestions!
user9253
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Tue Dec 29, 2015 8:02 am Post subject: Re: Alternator and regulator connections |
Here are some educated guesses:
Reg Sense: Connect to main power bus through a fuse. Do not connect to IGN terminal.
Warn Lite: Use the trial and error method. The lamp will limit the current so hopefully no harm will be done if polarity is wrong. I suggest first connecting the lamp to the main power bus through a fuse. It should light up when the engine is not running. If not, then try connecting the lamp to ground.
_________________ Joe Gores |
Posted: Tue Dec 29, 2015 12:26 pm Post subject: Alternator and regulator connections |
At 10:02 AM 12/29/2015, you wrote:
Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com>
Warn Lite: Use the trial and error method. The lamp will limit the current so hopefully no harm will be done if polarity is wrong. I suggest first connecting the lamp to the main power bus through a fuse. It should light up when the engine is not running. If not, then try connecting the lamp to ground. |
Joe has it nailed . . .
With respect to TWO field terminals on
alternator. Ground ONE and run the other to
the F terminal on regulator. These terminals
are not polarity sensitive.
Posted: Tue Dec 29, 2015 9:56 pm Post subject: Alternator and regulator connections |
Ah, the power of Aeroelectric !
Thanks Guys, always learning!
On 29 December 2015 at 22:24, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Quote: | At 10:02 AM 12/29/2015, you wrote:
Quote: | --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
Best...Bob Verwey
yellowduckduo(at)gmail.co Guest
Posted: Wed Dec 30, 2015 5:13 am Post subject: Alternator and regulator connections |
If the regulator is an unknown automobile unit, isn't it more likely
that one field terminal should go to positive rather than ground as per
most cars since the 70's.
Before permanently wiring anything, I would be inclined to test whether
the regulator F terminal goes to ground or positive when system voltage
is low.
Similar for the Light terminal as it may need the warning light bulb to
positive voltage rather than ground.
Ken
> to IGN terminal.
user9253
Posted: Wed Dec 30, 2015 6:53 am Post subject: Re: Alternator and regulator connections |
This particular alternator has two field connections. One field terminal does go to positive (from the regulator). And the other one goes to negative. Polarity does not matter because an alternator produces AC voltage. So even if the polarity of the field wires is reversed, the alternator will still produce AC voltage. Six diodes rectify the 3 phase AC from the stator windings into DC.
Unlike this alternator, most modern automotive alternators have the voltage regulator located inside of the alternator case. Some of these automotive alternators might have a terminal marked "F". But that terminal does not connect to an external voltage regulator because there is already one inside of the alternator case.
https://alternatorparts.com/understanding-alternators.html
user9253
Posted: Wed Dec 30, 2015 7:04 am Post subject: Re: Alternator and regulator connections |
Below is a link to a Youtube animated movie that explains how alternators work.
http://tinyurl.com/Alternator-Explained
Posted: Wed Dec 30, 2015 1:24 pm Post subject: Alternator and regulator connections |
This video is a little mis-leading. The final
evolutionary step in alternator development
shows a dc generator driving a commutator wtih
power pickoff brushes driving the alternator's
slip rings.
I don't think anyone would build one this way
because the whole idea behind the itty-bitty
generator sharing a shaft with the alternator
is to arrive at a totally BRUSHLESS design.
A tiny alternator with a rotating power winding
excited by a STATIONARY field would excite a small
3-phase rectifier on the rotating assembly and
wired such that DC power output excites the
ROTATING field of the main alternator. ALL
brushless designs will exploit this configuration
for wild frequency AC alternators, constant
speed alternators or beefy versions of the
legacy vehicular alternator/rectifiers
machines but with no slip-rings.
Posted: Thu Dec 31, 2015 8:18 am Post subject: Alternator and regulator connections |
Guys thanks for all the replies!
So I connected everything as postulated by Joe and Bob, and I am seeing 14.2 volts on the Bus, which I believe to be correct.
The only thing is that the warn lite connection shows +12v when the master is turned on, and it does not extinguish when the voltage stabilizes and the amp meter is showing a good charge.
Any more ideas?
Happy New Year, one and all!
On 30 December 2015 at 23:22, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
slip rings.
Best...Bob Verwey
Posted: Thu Dec 31, 2015 11:53 am Post subject: Alternator and regulator connections |
As a general rule, alternator failure lights
built into regulators are of limited value
and should never take the place of ACTIVE
NOTIFICATION of low bus voltage. I presume
you have this function in place with
other hardware. I never hook up the built-in
lights.
Posted: Thu Dec 31, 2015 11:11 pm Post subject: Alternator and regulator connections |
Bob thanks,
I have the EFIS alarm so will ignore the warning lite connection.
On 31 December 2015 at 21:51, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
lights.
Best...Bob Verwey
Posted: Sun Jan 03, 2016 11:30 pm Post subject: Alternator and regulator connections |
What is the function of the AUX connection?
On 1 January 2016 at 09:09, Bob Verwey <bob.verwey(at)gmail.com (bob.verwey(at)gmail.com)> wrote:
lights.
Best...Bob Verwey
Best...Bob Verwey
