spcialeffects
Posted: Wed Dec 30, 2015 10:00 am Post subject: Gascolater position |
I am building a mono classic and have a question about the angle of the gascolater. I am at the moment installing the fuel system, pumps and gascolater, under the port side baggage area. I haven't yet topped out which makes it all the easier. I am about to make a hinged flap under the gascolater, however when the aircraft is on the ground, on its own wheels, I want the gascolater to point straight down so it's easy to drain, replace the filter etc. So my question is.....using the top edge of the lower fuselage as a datum what angle should it be at in order for the gascolater to be positioned to point straight down?
Many thanks Frank
Posted: Thu Dec 31, 2015 1:59 am Post subject: Gascolater position |
Frank, I have flown with the system you describe for 13 yrs - an Andair mini gascolator + drain valve, mounted on the baggage bay upright and accessed by a flap under the fuselage. I orientated mine to be vertical in level flight, (thinking this would let it be as efficient as can be), and have found no issues with it having 7 degrees backward slope when on the ground. I have incidentally never found any water and precious little else after the first 50 hrs when gunge was appearing from the fuel system.
HNY, David Joyce, GXSDJ
On 2015-12-30 18:00, spcialeffects wrote: | Quote: | | Quote: | --> Europa-List message posted by: "spcialeffects" <spcialeffects(at)aol.com (spcialeffects(at)aol.com)>
Many thanks Frank
http://forums.matronics.com/viewtopic.php?p=451517#451517
">www.buildersbooks.com
.matronics.com/contribution
ics.com
spcialeffects
Posted: Thu Dec 31, 2015 8:59 am Post subject: Re: Gascolater position |
Hi David, thanks for the reply. I remember reading somewhere that the mono had an 8 degree pitch. Looks like it doesn't matter too much anyway from the other offline responses Iv had. Many thanks
