				 Posted: Tue Jan 26, 2016 12:39 pm    Post subject: Fuel flow transducer 914 |
				Would I be correct in assuming that to calculate the fuel flow you need to measure the outgoing fuel and then subtract the returning fuel?
 So one needs two transducers....
 thanks
 Will
 William Daniell
 LONGPORT
 +57 310 295 0744
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		pestar
  Joined: 11 Apr 2007 Posts: 61 Location: Auckland, New Zealand
				 Posted: Tue Jan 26, 2016 1:12 pm    Post subject: Re: Fuel flow transducer 914 |
				You need two units which I have in my DynAero MCR-4S and depending on your instrumentation ie EFIS or other, your device will need to subtract one from the other to give you fuel flow.
 I use a MGL EFIS with only one input with the trickery being done by a little device from sparxfly.co.nz (it takes the 2 inputs, subtracts and then outputs to the EFIS).
 Cheers Peter
  _________________ Peter Armstrong
DynAero MCR-4S (Do not shoot me   ). |
		rlborger(at)mac.com Guest
				 Posted: Tue Jan 26, 2016 2:21 pm    Post subject: Fuel flow transducer 914 |
				William,
 That is correct.
 Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX  76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
 On Jan 26, 2016, at 2:35 PM, William Daniell <wdaniell.longport(at)gmail.com (wdaniell.longport(at)gmail.com)> wrote:
 thanks
 Will
 William Daniell
 LONGPORT+57 310 295 0744
		standa.svec(at)volny.cz Guest
				 Posted: Tue Jan 26, 2016 2:56 pm    Post subject: Fuel flow transducer 914 |
				Hellou Peter,
 please, exactly what "little device from sparxfly" do you have in mind?
 I canīt find it on their web.
 Thanks very much.
 Stanislav
		raimo.toivio(at)rwm.fi Guest
				 Posted: Thu Feb 04, 2016 6:39 am    Post subject: Fuel flow transducer 914 |
				My system has calculated well and accurately with one transducer     only (between a returning fuel T and carburrettors).
      Cannot understand reason for two transducers...
      Raimo
                    allekirjoitus        (info(at)rwm.fi)
      26.1.2016, 22:35, William Daniell       kirjoitti:
       	  | Quote: | 	 		                  Would           I be correct in assuming that to calculate the fuel flow you           need to measure the outgoing fuel and then subtract the           returning fuel?
          thanks
          Will
                                                 William Daniell
                LONGPORT
                +57 310 295 0744
		Burrilla
				 Posted: Thu Feb 04, 2016 7:29 am    Post subject: Fuel flow transducer 914 |
				Mine as well.
 Alan
 On 4 Feb 2016, at 14:38, Raimo Toivio <raimo.toivio(at)rwm.fi (raimo.toivio(at)rwm.fi)> wrote:
  	  | Quote: | 	 		                     My system has calculated well and accurately with one transducer     only (between a returning fuel T and carburrettors).
      Raimo
          thanks
          Will
                                                 William Daniell
                LONGPORT
                +57 310 295 0744
		jan_de_jong(at)casema.nl Guest
				 Posted: Thu Feb 04, 2016 5:47 pm    Post subject: Fuel flow transducer 914 |
				Turbo engine fuel system is different. Normal flow rates would be:
      - forward flow 100 l/h
      - carburettor flow 20 l/h
      - return flow 80 l/h.
      Jan
      On 2/4/2016 4:28 PM, Alan Burrill       wrote:
       	  | Quote: | 	 		                Mine as well.
        Alan
            Raimo
                thanks
                Will
        William Daniell
                      LONGPORT
                      +57 310 295 0744
