ceengland7(at)gmail.com Guest
Posted: Tue Feb 02, 2016 6:43 pm Post subject: Automatic way to turn On the Standby alternator |
A mechanical failure in that single switch could take out both alternators. is that acceptable?
Needing to turn both off would imply that both have failed 'shorted' and are trying to drain the battery. Not likely, but separate switches fix that, too.
On 2/2/2016 5:39 PM, Carlos Trigo wrote:
| Quote: | <![endif]--> <![endif]-->
Eric
That is brilliantly simple!
Do you think this is a reliable solution?
And, in your opinion, should I have the possibility of turning OFF both alternators simultaneously?
CT
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Eric Page
Sent: terça-feira, 2 de Fevereiro de 2016 23:13
Subject: Re: RE: Automatic way to turn On the Standby alternator
Yes, a single-pole double-throw, ON-ON switch. Ground on the common tab, main alternator control to your VP-X on one side, standby on the other. This will, of course, offer no way to disable both alternators simultaneously, unless you use an ON-OFF-ON switch.
Eric
On Feb 2, 2016, at 2:35 PM, Carlos Trigo <[url=mailto:trigo(at)mail.telepac.pt]trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)[/url]> wrote:
Thanks again for your eloquent explanations.
However, I probably didn’t make myself clear about my idea.
In my system (switches working through the VP-X box), turning Off the MAIN Alternator field switch means interrupting a ground wire.
And turning On the Standby Alternator means connecting a ground wire.
(Switches in the Vertical Power system work by connecting or disconnecting ground to the assigned pins in their red box)
Therefore, what I need to design is simply an electrical way to accomplish the following action:
when I flip the Main ALT switch to Off (interrupting a ground wire), this same action automatically connects the ground wire that switches the STBY ALT field
Is there a simple and elegant solution to do this?
Cheers
Carlos |
Este e-mail foi enviado a partir de um computador sem vírus protegido pela Avast.
www.avast.com |
glastar(at)gmx.net Guest
Posted: Tue Feb 02, 2016 10:32 pm Post subject: Automatic way to turn On the Standby alternator |
Carlos,
can't the VP-X do that logic, did you check with them?
Cheers Werner
On 02.02.2016 23:35, Carlos Trigo wrote:
| Quote: | Thanks again for your eloquent explanations.
the STBY ALT field
Cheers
Carlos
Posted: Wed Feb 03, 2016 7:32 am Post subject: Automatic way to turn On the Standby alternator |
Rene', if your battery is a bit down from sitting a while, then starting, the alt might well try to supply its full rated amps when engine rpm comes up enough to power it to full output. 60A breaker on 70A alternator, done....
I would say yes. Most A/C have a master switch of some kind so that all power can be removed. Depending on how you wire it…..the master switch may or may not do the job.
I elected to have separate switches to control the Alternators. I can run them at the same time, but my backup is set lower so I am guessing it would never contribute as long as the primary was working. I also have extra battery power…..I really do not need an alternator to finish any reasonable flight. With a little load shedding I am good for 2-3 hours. Unless I lose my alternator on take off at night….I am all set for any flight I take.
BTW, I have tested this in real conditions twice and it works fine. I changed my alternator to a 70 amp version but did not change the breaker. I don’t know how because I do not have 70 amps worth of load, but the 60 amp break tripped twice on a long cross country when I transmitted shortly after takeoff. No problems since I upgraded the breaker. Both flights were completed on the backup battery with the main battery being used as a reserve. (main battery is a 925 and backup is a 680) I have an 8 amp backup alternator which does not keep up with basic load……but extends the flight time way past the fuel limit.
Rene'
801-721-6080
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Carlos Trigo
Sent: Wednesday, February 03, 2016 7:51 AM
Subject: RE: RE: Automatic way to turn On the Standby alternator
I imply from your (very short) answer that I must be able to turn off both alternators in flight, right?
Carlos
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Robert L. Nuckolls, III
Sent: quarta-feira, 3 de Fevereiro de 2016 13:27
Since I've never designed an aircraft electrical system, much less built one, I'll leave it others to advise whether you should be able to turn both alternators off. Bob? |
Smoke in the cockpit?
www.avast.com
richard.beebe(at)yale.edu Guest
Posted: Wed Feb 03, 2016 10:11 am Post subject: Automatic way to turn On the Standby alternator |
Two weeks ago I had the beginnings of an electrical fire in the cockpit
so turning off ALL sources of power to the panel is a very important
safety feature to me.
A pin in a nylon connector (AMP Mate N Lock connector) came loose and
overheated melting the connector and releasing a cloud of smoke. I hit
the master and it stopped. To be fair I later discovered the breaker had
also popped but if it hadn't I could have had a really really bad situation.
--Rick
On 02/03/2016 12:21 PM, Robert L. Nuckolls, III wrote:
| Quote: | At 08:51 AM 2/3/2016, you wrote:
> Bob
Your choice. The probability is rare but
not zero. In a TC aircraft, ABSOLUTE control
over all ship's power sources is a
requirement.
Posted: Wed Feb 03, 2016 10:33 am Post subject: Automatic way to turn On the Standby alternator |
Ok, ok, don't shoot!
I will put 2 separate switches...
Thanks to all
Carlos
Enviado do meu iPhone
No dia 03/02/2016, às 18:09, Rick Beebe <richard.beebe(at)yale.edu> escreveu:
Two weeks ago I had the beginnings of an electrical fire in the cockpit so turning off ALL sources of power to the panel is a very important safety feature to me.
A pin in a nylon connector (AMP Mate N Lock connector) came loose and overheated melting the connector and releasing a cloud of smoke. I hit the master and it stopped. To be fair I later discovered the breaker had also popped but if it hadn't I could have had a really really bad situation.
--Rick
>> Bob
> requirement.
> Bob . . .
