Electrics and Trim
wdaniell.longport(at)gmai
PostPosted: Mon Feb 29, 2016 8:01 am    Post subject: Electrics and Trim Reply with quote
A couple of questions for the assembled company
  1. In the Europa wiring diagram there is a separate alternator output switch and a 25 A fuze or CB.  Can this be replaced by a just a 25A circuit breaker?  Is there any reason to have the switch?
  2. Dynon trim.  Has anyone fitted the Dynon SV-AP-PANEL?  If so how did you wire it to the Trim servo supplied with the Europa?  The Dynon puts out 4A to the trim motor and the Europe Trim has a 1A CB....So I am assuming that one can use the Dyonon trim controller but with a 1A CB between the controller and the trim motor.
Thanks in advance
Will
William Daniell
LONGPORT
+57 310 295 0744
rampil
PostPosted: Mon Feb 29, 2016 9:42 am    Post subject: Re: Electrics and Trim Reply with quote
The size of the circuit break is strictly dependent on the gauge of the
wire that you run to the trim motor in the tail.
Do yourself a favor and get a copy of "The Aeroelectric Connection"
Ira N224XS
PostPosted: Mon Feb 29, 2016 9:59 am    Post subject: Electrics and Trim Reply with quote
Thanks Ira
William Daniell
LONGPORT
+57 310 295 0744
On Mon, Feb 29, 2016 at 12:42 PM, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
--> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=453295#453295
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
          -Matt Dralle, List Admin.
FORUMS -
b Site -
Fred Klein
PostPosted: Mon Feb 29, 2016 1:22 pm    Post subject: Electrics and Trim Reply with quote
On Feb 29, 2016, at 9:42 AM, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
Do yourself a favor and get a copy of "The Aeroelectric Connection”
Will... Here’s a link: http://www.bandc.aero/aircraft-electrical-books.aspx
…check out the entire site…lots of good info…
F.
Fred Klein
PostPosted: Mon Feb 29, 2016 2:23 pm    Post subject: Electrics and Trim Reply with quote
Here’s another source for VERY helpful electrical info:
http://www.aeroelectric.com/articles.html
F.
On Feb 29, 2016, at 1:21 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
F.
h&jeuropa
PostPosted: Tue Mar 01, 2016 2:01 pm    Post subject: Re: Electrics and Trim Reply with quote
Will,
These are strictly my opinions, use them as you see fit.
The diagram I have XS Page 25-11 Issue 4, shows a 30 amp slow blow fuse. This is required and needs to be a slow blow type fuse. I used a Buss Maxi fuse to get the slow blow feature.
The switch shown which is rated at 25 amps allows one to isolate the alternator from the aircraft electrical system. This could be useful in case of an alternator failure or if the capacitor should fail by shorting out. Many prefer to start their engine with the alternator out of the circuit and then turn it on after the engine is started. For these reasons a switch is probably preferred since circuit breakers may not be rated to be turned on and off frequently. I used Aero Electric Connection standard diagram Z-13 as the basis for my electrical system. I have since incorporated portions of Z-16 as well. I can send you a pdf of my electrical system if you like. Don't forget an overvolt protection device. There is a approved club mod for an overvolt crow bar module.
I have looked at the Dynon SV-AP Panel install instructions. I assume you are fitting a Skyview system with Dynon pitch and roll servos for their autopilot system. That should be a cool setup! The Dynon panel will allow you to control the Europa supplied Ray Allen pitch trim motor without using the supplied rocker switch. The Dynon is to be fed through a 4A fuse (they probably specified 4A since it can control two trim motors and some motors may draw more than 1A). It will supply as much current as the Ray Allen motor requires. The Ray Allen servos are fused at 1A when installed alone and the wires are quite small (26 AWG), so fuse the wire going from the Dynon Panel to the trim motor with a 1A fuse. You will probably want to keep the Europa supplied position indicator. I know I always look at it prior to take off to make sure the trim is positioned properly.
I hope this helps.
Jim Butcher
N241BW
carlp101
PostPosted: Wed Mar 16, 2016 3:18 pm    Post subject: Re: Electrics and Trim Reply with quote
Hi Will,
I have just gone through the rather lengthy process of fitting a full Skyview D1000T system in my Europa Tri-gear, G-URMS. It includes the auto-pilot panel. I wired the trim motor to the AP panel's D-type 15 way connector, but the panel's nose-up / nose-down buttons cannot be used to alter the pitch unless the auto-pilot is flying the plane. You need to wire the existing trim switch to the 15 way D-type connector too to give you the ability to manually control the pitch trim. In addition, if you want the trim gauge to work you'll need to wire it in a specific way that includes the addition of a resistor. It works well.
Email me on cparkinson(at)cisc-uk.com and I'll send you the details of what I did to get it working. I'm typing this on a tablet at the moment, so I don't have the information easily to hand.
Carl
+44 7810 565195
