		kearney
				 Posted: Mon Feb 29, 2016 5:16 pm    Post subject: 12V USB Panel Mount Outlet |
				Hi
 I have found that my IPAD doesn't seem to charge all that well with the USB outlets  I installed in my panel / console. They are rated at 2.1 amps but I guess there must be more to it than that.
 Does anyone have a part # / recommendation for a mountable USB port.
 Inquiring minds need to know....
 Cheers
 Les
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rlborger(at)mac.com Guest
				 Posted: Mon Feb 29, 2016 5:37 pm    Post subject: 12V USB Panel Mount Outlet |
				Les,
 Check out http://commitlift.com for a USB that works and isn’t noisy.
 Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX  76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
  	  | Quote: | 	 		  On Feb 29, 2016, at 7:16 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
 --> AeroElectric-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>HiI have found that my IPAD doesn't seem to charge all that well with the USB outlets  I installed in my panel / console. They are rated at 2.1 amps but I guess there must be more to it than that.Does anyone have a part # / recommendation for a mountable USB port.Inquiring minds need to know....CheersLes
		email(at)jaredyates.com Guest
				 Posted: Mon Feb 29, 2016 6:05 pm    Post subject: 12V USB Panel Mount Outlet |
				I've been using one from brian(at)eamanufacturing.com (brian(at)eamanufacturing.com) that has worked out well. His website is still under construction, but you can probably get one by asking directly.  I got mine from the B&B tent at Oshkosh.
 On Mon, Feb 29, 2016 at 8:34 PM, Robert Borger <rlborger(at)mac.com (rlborger(at)mac.com)> wrote:
  	  | Quote: | 	 		  Les,
 Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX  76208-5331Cel: rlborger(at)mac.com (rlborger(at)mac.com)
 Hi
 Cheers
 Les
		kearney
				 Posted: Mon Feb 29, 2016 8:05 pm    Post subject: Re: 12V USB Panel Mount Outlet |
				HI
 Thanks for the advice, greatly appreciated.
 Cheers
 Les
		n233ee(at)gmail.com Guest
				 Posted: Mon Feb 29, 2016 8:23 pm    Post subject: 12V USB Panel Mount Outlet |
				Be sure to use a 'cord' made for an iPad not a generic.  The charging circuit is in the cord connector.  Good luck.
  	  | Quote: | 	 		   On Feb 29, 2016, at 19:16, kearney <kearney(at)shaw.ca> wrote:
  Hi
  Cheers
  Les
  http://forums.matronics.com/viewtopic.php?p=453305#453305
		rampil
				 Posted: Sun Mar 20, 2016 7:42 am    Post subject: Re: 12V USB Panel Mount Outlet |
				Actually, Apple USB-Lightning cords do not contain any charging circuitry.
 Apple-qualified chargers have resistors which identifies the current carrying
 capacity of the cord. Different resistors for 0.5, 1 amp and 2 amp adapters.
 Of course cheap generic chargers do not have the Apple resistor network
 so the iPad treats it like a 0.5A source.
 Depending on the iPad and the brightness setting, a 0.5 Amp charger
 will barely keep status quo.  You could shut off the iPad and leave it on the
 active cord for an hour to see if it charges at all. If any other low-requiring
 appliance charges on that cord, it is just a cheap USB socket appliance.
 Ref for old, non-Apple chargers:
 http://www.righto.com/2012/03/inside-cheap-phone-charger-and-why-you.html#ref10
 Ref for Apple USB Chargers:
 http://www.righto.com/2012/05/apple-iphone-charger-teardown-quality.html
 Ref for Resistor Network:
 http://blog.curioussystem.com/2010/08/the-dirty-truth-about-usb-device-charging/
