art(at)zemon.name Guest
Posted: Wed Mar 02, 2016 7:42 pm Post subject: Newbie Wiring Questions |
Hello,
I am starting to plan the wiring for my BD-4C. My immediate problem is that I want to install the wires for things which will go in the rear of the plane, and near the floor by the back seat, soon so that I can close up the "tunnel" and (hopefully) not need to get in there again.
The autopilot servos and the magnetometer have me wondering what to do. Each needs power + 4 signal wires. The autopilot servos draw up to 1.7 A so I think I use larger wire for the power than the signals. The magnetomer only draws 0.12 A, though, so do I just get a cable with 5 or 6 conductors in it? Or should the power be a separate wire from a 4-conductor signal cable?
The rear seat intercomm has me wondering, too. It looks like 4-conductors will do, since there aren't any PTT switches. But shielded or not? I think not but would like some reassurance.
Finally, an off the wall question: How do you size a fuse for a circuit? Do you just round up to the next highest integer or do you go bigger? I'm thinking of the autopilot servos, average current of 0.9 A and max current of 1.71 A. Should I use a 2 A fuse? 3 A? Put both on a single 5 A fuse? Something else?
  -- Art Z.
http://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
ceengland7(at)gmail.com Guest
Posted: Wed Mar 02, 2016 9:18 pm Post subject: Newbie Wiring Questions |
Size the wire for the load. Size the fuse to protect the wire.
-------- Original message --------
Date:03/02/2016 9:39 PM (GMT-06:00)
Subject: AeroElectric-List: Newbie Wiring Questions
Hello,
-- Art Z.
kenryan
Posted: Wed Mar 02, 2016 9:42 pm Post subject: Newbie Wiring Questions |
Example: 1.7 amp X 2 = 3.4 amps. Table 11-9 in AC43.13 shows to carry that amount of current you will need at least #20 wire. Figure 11-2 shows #20 wire with 4 amps can only be 12 feet long (otherwise too much voltage drop). I would use #18 to be safe. Table 11-3 shows #18 wire being protected by 10 amp breaker or 10 amp fuse. That would be the maximum. Since the load is only 3.4 amps I would use a 5 amp fuse. Or something like that. Consult 43.13 for specifics.
On Wed, Mar 2, 2016 at 8:16 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
| Quote: | Size the wire for the load. Size the fuse to protect the wire.
Hello,
  -- Art Z.
matronics(at)rtist.nl Guest
Posted: Wed Mar 02, 2016 10:23 pm Post subject: Newbie Wiring Questions |
Good example, but you didn't apply the "size the fuse to protect the wire" rule. Using a 5A fuse is sized to the load, not to the wire. The table says 10A for a #18 wire, so use 10A.
On 3/3/2016 6:40 AM, Ken Ryan wrote:
| Quote: | Example: 1.7 amp X 2 = 3.4 amps. Table 11-9 in AC43.13 shows to carry that amount of current you will need at least #20 wire. Figure 11-2 shows #20 wire with 4 amps can only be 12 feet long (otherwise too much voltage drop). I would use #18 to be safe. Table 11-3 shows #18 wire being protected by 10 amp breaker or 10 amp fuse. That would be the maximum. Since the load is only 3.4 amps I would use a 5 amp fuse. Or something like that. Consult 43.13 for specifics.
Subject: Newbie Wiring Questions
Hello,
  -- Art Z.
http://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
Joined: 28 Mar 2008 Posts: 1967 Location: Riley TWP Michigan
Posted: Thu Mar 03, 2016 6:26 am Post subject: Re: Newbie Wiring Questions |
I agree with kenryan. Fuse sizes in a table are the maximum fuse sizes. There is nothing wrong with using a smaller fuse size as long as it does not nuisance blow. If the wire size is increased to reduce voltage drop over a long distance, the fuse size does not need to be increased. If there are plenty of fuse slots available, it is preferable to fuse each load separately rather than to combine loads onto one fuse. If one load blows a fuse, you do not want an unrelated circuit to be disabled too.
_________________ Joe Gores |
Posted: Thu Mar 03, 2016 6:38 am Post subject: Newbie Wiring Questions |
Thank you for the references, Ken. That was just the sort of information I was seeking.
BTW, I found this online Voltage Drop Calculator to be pretty useful.
  -- Art Z.
On Wed, Mar 2, 2016 at 11:40 PM, Ken Ryan <keninalaska(at)gmail.com (keninalaska(at)gmail.com)> wrote:
| Â
kenryan
Posted: Thu Mar 03, 2016 7:46 am Post subject: Newbie Wiring Questions |
A 5 amp fuse or breaker will certainly protect an 18AWG wire, so yes, the fuse is sized to protect the wire.
On Wed, Mar 2, 2016 at 9:17 PM, Rob Turk <matronics(at)rtist.nl (matronics(at)rtist.nl)> wrote:
| Quote: | Good example, but you didn't apply the "size the fuse to protect the wire" rule. Using a 5A fuse is sized to the load, not to the wire. The table says 10A for a #18 wire, so use 10A.
Hello,
  -- Art Z.
rene(at)felker.com Guest
Posted: Thu Mar 03, 2016 7:48 am Post subject: Newbie Wiring Questions |
Not to start another primer war....
As my old school electrical engineer reminds me every time we are on a
project. The fuse is to protect the wire, size it that way.
If the wire is capable of handling 10 amps, why not use a 10 amp
fuse.......? That might be the question.
I completed my airplane in 2008. Since then I have modified my panel many
times. That has required me to change CBs because I added loads to a line.
I wish I would have followed my EE advice and just set the breaker to the
wire size.
Rene'
801-721-6080
Posted: Thu Mar 03, 2016 8:58 am Post subject: Re: Newbie Wiring Questions |
| Quote: | If the wire is capable of handling 10 amps, why not use a 10 amp
fuse.......? |
In this particular case where the maximum load is less than 3 amps, I would use a 3 or 5 amp fuse because, when something shorts out, a smaller fuse will blow quicker and there will be less spark and smoke. Sizing circuit protection at the maximum allowed does have the advantage of being able to add future loads to that circuit.
There was a recent discussion on VansAirforce about the number of fuses that should be installed. The consensus was: twice as many as the expected need. Fuses and fuse blocks are relatively inexpensive.
Posted: Sun Mar 06, 2016 5:54 pm Post subject: Newbie Wiring Questions |
At 09:39 PM 3/2/2016, you wrote:
| Quote: | Hello,
Why not run a conduit of pex or nylon tubing through the
covered tunnel environs? Then you can push/pull wires
through at any later time at your convenience . . . after
you've crafted wiring diagrams that comport with manufacturer's
instructions for each appliance. You can get a LOT
of wires into a piece of 1/2 or 3/4" pex.
Here's an exemplar 'bundle' of wires in a piece of
5/8" tubing . . .
http://tinyurl.com/hez7eat
When I install such features, I always pull in one more
strand of wire than necessary and secure the pigtails
at each end. Then, when you need to add a wire later,
use your 'tag wire' to pull in the new wire PLUS
a new 'tag wire'. I've got a 20 foot conduit that
runs from my desk up the wall an out the roof to
my antennas. The pipe already had 4 coax cables in
it when I pulled a 5th into the bundle with no
sweat.
Running the bundle through a secured conduit eliminates
concerns for supporting the wires through the inaccessible
and invisible tunnel environs.
| Quote: | | The autopilot servos and the magnetometer have me wondering what to do. Each needs power + 4 signal wires. The autopilot servos draw up to 1.7 A so I think I use larger wire for the power than the signals. The magnetomer only draws 0.12 A, though, so do I just get a cable with 5 or 6 conductors in it? Or should the power be a separate wire from a 4-conductor signal cable? |
As long as EVERY electron running one way through
a bundle is exactly paired with another electron
going the other way, there is no coupling of energy
from one wire to another.
| Quote: | | The rear seat intercomm has me wondering, too. It looks like 4-conductors will do, since there aren't any PTT switches. But shielded or not? I think not but would like some reassurance. |
I'd use three conductor shielded where the shield is
a fourth, ground conductor for one of the features at the
far end.
| Quote: | | Finally, an off the wall question: How do you size a fuse for a circuit? Do you just round up to the next highest integer or do you go bigger? I'm thinking of the autopilot servos, average current of 0.9 A and max current of 1.71 A. Should I use a 2 A fuse? 3 A? Put both on a single 5 A fuse? Something else? |
Does EACH servo get powered from its own bus-power-tap?
How many power feeders are depicted on the installation
instructions? They probably speak to suggested wire
gages too. Unless your wire runs are especially LONG
(seldom in OBAM aircraft), then picking wires and
their respective protective devices is right out
of the book 5A/22AWG, 7A/20AWG, etc. etc. There's
no risk for having the wire oversized. There's nearly
zero risk for being a little 'undersized' wherein the
risk is for nuisance tripping of a fuse or breaker.
20AMPS will not burn a 22AWG wire suspended in free
air. See:
http://tinyurl.com/6qr72fr
So even if you found that some transient load on
the end of a 22AWG wire nuisance trips a 5A fuse,
then go up to 7A fuse but do not change the wire.
99* percent of wiring failures are open circuits.
Wire comes out of terminal, screw comes loose,
pin pushes back in a connector, etc. Most of
the remaining failures are HARD faults to ground
or within loads where the current will be many times
higher than the wire's installed protection. In
these instances you're interested in fast response
that does not overheat the wire. Compared to breakers
Fuses are VERY fast. Hence upsizing from 5 to
7A fuse on a 22AWG wire is a yawn.
But in any case, begin with the manufacturer's
recommendations for the appliance being installed.
They SHOULD know more about achieving efficiency
and reliability for that device than anyone else.
Further, when their product falls short of advertised
performance, root cause will most likely be found
In shortfalls of quality assurance in production
or installation as opposed to design.
Please don't take this as any kind of push-back
for bringing those questions to the List but
understand that some well considered answers require
more knowledge than one might be expected to have
in their hip pocket. The last two failure analysis
programs I participated in started with a study of
the prior art. I read the manuals, looked up patents,
researched process recommendations for installing
the parts. All those references were cited in my report
bibliography and became part of a foundation
for what turned into as simple, two paragraph conclusion/
recommendation.
So like you wife admonished as you struggled
with your kid's new bike on Xmas eve, "Gee
dear . . . have you read the instructions?"
Of course, if they were translated from Chinese
by a second year language student . . . oh well . . .
bring it to the List and we'll commiserate.
How did you happen into the BD-4 project? That
was probably uncle Jim's finest contribution
to the OBAM aviation community . . .
Posted: Sun Mar 06, 2016 7:31 pm Post subject: Newbie Wiring Questions |
On 3/6/2016 7:47 PM, Robert L. Nuckolls, III wrote:
| Quote: | At 09:39 PM 3/2/2016, you wrote:
| Quote: | Hello,
5/8" tubing . . .
sweat.
far end.
air. See:
recommendation.
Bob . . . | For wire raceway, I found this stuff:
https://www.techflex.com/prod_ccp.asp
and
https://www.techflex.com/prod_f6w.asp
As long as you leave a bit of extra length, the 1st can expand substantially for future wire additions.
The 2nd allows wire to be added without being pulled through the tube, and allows wire to exit at any point along the run without cutting open the tube.
Very flexible, can turn sharp corners, weighs next to nothing, very thin 'wall', and good abrasion resistance. I used the split stuff to run down the sides of my RV-7 from behind the instrument panel to the fuel line/cable chase at the main spar. The unsplit stuff I've used to bundle runs from subD connectors behind the panel. The 3/4" diameter version will expand enough to go over a populated subD, if the shell is removed & the wires bent 90 degrees.
FWIW...
Posted: Mon Mar 07, 2016 5:45 am Post subject: Newbie Wiring Questions |
On Sun, Mar 6, 2016 at 7:47 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
| Quote: | Hello,
Brilliant. Now why didn't I think of that? I ran a 3/8" piece of PVC to the tail "just in case I ever need it" but never thought of doing the same in the tunnel.
There is a lot of value in hashing out even "obvious" questions with other people. Thank you.
Â
  a new 'tag wire'.
I have used string for similar duties in my home, but fastening the new wire to the string has been worrisome. How do you do it with wire, butt splice? That seems like it would be more reliable and with smaller diameter than the tape that I have used at home.
Â
Good to know. That eliminates my only concern about using a conduit.
Â
I am building an aluminum airplane. I have not (yet) found guidelines for selecting from three scenarios:Â
- Run a ground wire
- Use a shielded wire
- Use the fuselage as the ground
Can you point me at something?
Â
| Quote: | | Quote: | | Finally, an off the wall question: How do you size a fuse for a circuit? Do you just round up to the next highest integer or do you go bigger? I'm thinking of the autopilot servos, average current of 0.9 A and max current of 1.71 A. Should I use a 2 A fuse? 3 A? Put both on a single 5 A fuse? Something else? |
 instructions?
MGL's instructions are pretty sparse for their servos (at least compared to what they write for their AHRS and magentometer units, where they do specify a circuit breaker size):
| Quote: | In order to accommodate the current required, 18 to 20 gauge wires should be
used for the power wires (positive and negative supply). Thinner wires can be
used for the signal wires.
If the servo is installed onto an bracket that is grounded (for example in an all
metal aircraft), ensure that the area created by the returning ground (thick) power
cable is kept to a minimum – keep the distance between the wire and the metal
construction to a minimum for the full length of the cable up to termination into
the power bus. |
I'm inclined to use a fuse for each servo, mostly because I don't have any reason to cheap out and save a fuse. We had some good discussion about that over the last few days, so I won't rehash it.
Â
| Quote: | They probably speak to suggested wire
 air. See:
This is very good to know. I'm a "gotta know why" kind of guy. Understanding the rationale behind fuse selection makes it much easier for me to "size the fuse for the wire" instead of the load. Specifically, I had not thought it through far enough to realize that the current in a failure will be many times higher than the fuse's limit. That explains why using a smaller fuse doesn't offer any additional protection.
Â
Short version: I wanted a fast 4-place X-C airplane with modern avionics for my wife and me to travel in. I wanted to eliminate moving parts, in particular mechanical gyros and vacuum pumps. I didn't want to spend the money on a new factory-built plane or spend the money to completely upgrade my '68 Arrow. I am way more interested in function than beauty so the BD-4C was the natural choice.
Long version:Â How I Chose to Build a Bede BD-4C (on my blog)
  -- Art Z.
Posted: Mon Mar 07, 2016 7:33 am Post subject: Newbie Wiring Questions |
| Quote: | For wire raceway, I found this stuff:
and
FWIW...
Charlie |
Yeah, we had this stuff around at Hawker-Beech but I'm
not sure I ever saw it used in the airplanes . . . I'll
have to ask some guys who had more experience on
the lines. We used it a lot for fabricating test harnesses,
the techs called it 'snake skin'.
I'm not sure one could pull new wires in with a tag
line if the bundle was secured in an inaccessible
space with adel clamps. The rigid diameter conduit
approach preserves cross section under the clamps.
But this makes for VERY flexible test harnesses. A
string tied bundle can become quite stiff when
individual strands of wire get bound tightly
to each other under those constrictor knots.
ashleysc(at)broadstripe.n Guest
Posted: Mon Mar 07, 2016 8:26 am Post subject: Newbie Wiring Questions |
Hi All;
Recommend putting a nylon pull string into the tubing before burying it in the aircraft. The string can be pulled through with a vacuum cleaner. Tie on a loose fitting ball of foam or cloth at the leading end of the string to help pull the string through.
Cheers! Stu.
Sent: Sunday, March 6, 2016 5:47:56 PM
Subject: Re: Newbie Wiring Questions
| Quote: | Hello,
5/8" tubing . . .
sweat.
far end.
air. See:
recommendation.
Posted: Mon Mar 07, 2016 9:17 am Post subject: Newbie Wiring Questions |
At 10:25 AM 3/7/2016, you wrote:
| Quote: | Hi All;
Cheers! Stu. |
Yeah . . . a airhose blow gun works from the supply
end too. I'll tie a piece of shop rag onto the end
of the string then stuff about a foot of string in
with the rag-wad, blow, stuff more string, repeat.
Posted: Mon Mar 07, 2016 10:03 am Post subject: Newbie Wiring Questions |
I have used string for similar duties in my home, but fastening the new wire to the string has been worrisome. How do you do it with wire, butt splice? That seems like it would be more reliable and with smaller diameter than the tape that I have used at home. |
Kinda depends on how tight the bundle is in
the tube . . . but my personal favorite is to
do a soldered lap-splice to ALL of the strands
being pulled. My tag wire is usually 20AWG.
Overlap about 1/2" of tag wire strands with the
new wires (+ new tag wire). Put a piece of heat
shrink over it to 'smooth' the joint and then
pull them in . . .
| Quote: | | Good to know. That eliminates my only concern about using a conduit. |
Supporting wires hanging out in the breeze is
intended to eliminate potential vibration/abrasion
points and just control what otherwise might be
a floppy bundle. WAaaayyyy back when, cotton over
rubber insulated wire (Mil-W-76) wire was subject
to imbrittlement when exposed to ozone, hydrocarbons,
and just old age. Adequate support went to extending
service life of the insulation. Tefzel doesn't suffer
from this malady so 'floppy' bundles are more an
issue of craftsmanship as long as the wires don't
bang on a hard/sharp point.
| Quote: | I am building an aluminum airplane. I have not (yet) found guidelines for selecting from three scenarios:Â - Run a ground wire
Except for the few examples of 'local grounds' illustrated
in Figure Z-15, it is ALWAYS good practice to include
ground returns in the same bundle that carries power
and signals. Any appliance designer worth his soldering
iron will do this and it should be obvious in the
installation manuals. CAVEAT: when you DO see a local
ground called out on a wiring diagram for some appliance
having mixed signals/power wires running elsewhere, it's
NEVER wrong to extend your ground up to the panel with
all the other wires. | Quote: | - Use a shielded wire
Only when called out by the system designer. Shielding
breaks only one coupling mode for noises that is seldom
encountered in modern aircraft appliances. If the instruction
manual doesn't call out shielded wire, adding it is unnecessary.
I've seen is used many times where it probably doesn't make
any difference . . . probably by some guy whose solder
station includes zinc-chloride flux. Shielding
never hurts but it is very seldom necessary or beneficial.
I use shielded trio as 4-conductor wires in audio
systems only because it's convenient and the wire
is commonly available . . . usefulness of the 4th
conductor's qualities as a shield is problematic.
| Quote: | - Use the fuselage as the ground
. . . only on those devices called out on Z-15
| Quote: | | I'm inclined to use a fuse for each servo, mostly because I don't have any reason to cheap out and save a fuse. We had some good discussion about that over the last few days, so I won't rehash it. |
Can the installation manual for this system be
downloaded? what's the FEMA for this system look
like? Can the system still be useful with one
actuator being un-powered?
Keep in mind that 99.999% of ALL circuit protection
installed in DC vehicular power systems will go
the lifetime of the vehicle having NEVER been
called upon to operate. This is why I blanch at
the idea of using breakers vs. fuses. They use up
a lot of dollars, install time, panel space, weight,
etc while adding nothing to system safety when
compared to the simple out of sight, out of reach fuse.
See:
http://tinyurl.com/hbhlv93
http://tinyurl.com/ht8wtl5
http://tinyurl.com/j3lfdbr
| Quote: | | This is very good to know. I'm a "gotta know why" kind of guy. Understanding the rationale behind fuse selection makes it much easier for me to "size the fuse for the wire" instead of the load. Specifically, I had not thought it through far enough to realize that the current in a failure will be many times higher than the fuse's limit. That explains why using a smaller fuse doesn't offer any additional protection. |
Good for you. Most of the hangar lore about
breakers and wires seems to impart images of
smoke and fire pouring out from under the panel
along with admonitions: "Tho shalt not oversize
thy breakers less wires melt and open the gates
to hell-in-the-air."
In fact, insulation quality is the wire's limiting
factor for current rating working hand in hand
with controlling voltage drop. I've only experienced
burned wires one time (improperly installed p-leads
and disconnected crankcase ground). I've experienced
and/or conducted analysis on dozens of bad smells and
smoke that came from INSIDE a device and would probably
never operate the breaker.
Looking through the accident reports for TC aircraft,
it's exceedingly7 difficult to find instances of
bad days in the cockpit due to electrical faults.
Many electrical emergencies in OBAM aircraft have
roots in poor craftsmanship, piloting skills and/or
system architecture.
See:
http://tinyurl.com/ky7szec
Fuse and wire sizing is pretty straight-forward
and way down on the list of reliability/safety
concerns. Just keep in mind that for every
condition that will open a fuse on some appliance
useful for comfortable termination of flight,
there are dozens to hundreds of conditions more
likely to bring the system down without blowing
the fuse.
If loss of any single appliance drives your
pucker=pressure up, then having a Plan-B for
continued comfortable flight without that
appliance.
| Quote: | Â
I'll read it . . . thanks for the heads-up . . .
raymondj(at)frontiernet.n Guest
Posted: Mon Mar 07, 2016 10:58 am Post subject: Newbie Wiring Questions |
I don't know if it's applicable to aircraft wire types, but I have found
wire lube makes pulling wire in a full conduit and/or long runs
significantly easier.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
On 03/07/2016 12:01 PM, Robert L. Nuckolls, III wrote:
| Quote: | >
pull them in . . .
> 1. Run a ground wire
> 1. Use a shielded wire
> 1. Use the fuselage as the ground
See:
See:
the fuse.
appliance.
> Â
> Â Â How did you happen into the BD-4 project? That
> Â Â was probably uncle Jim's finest contribution
> Â Â to the OBAM aviation community . . .
> <https://cheerfulcurmudgeon.com/2013/10/13/how-i-chose-to-build-a-bede-bd-4c/>
> (on my blog)
Posted: Mon Mar 07, 2016 12:37 pm Post subject: Newbie Wiring Questions |
At 12:55 PM 3/7/2016, you wrote:
| Quote: | --> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net>
I don't know if it's applicable to aircraft wire types, but I have found wire lube makes pulling wire in a full conduit and/or long runs significantly easier. |
TC aircraft are generally designed up from a clean
piece of paper and don't benefit from inclusion of conduits.
From the TC perspective, it's a weight penalty that
project management would really argue against. I
have seen conduits that run through wet-wing tanks and
occasionally along the rear spar for wing wires.
Those conduits were never really 'tight' on the
wires.
Pex is so slick inside that you would need to
have it REALLY full of wire before there was
risk to successful addition of a few
new wires.
wires.
new wires.
Posted: Wed Mar 09, 2016 5:35 am Post subject: Newbie Wiring Questions |
I agree with you completely on the fuses vs. circuit breakers choice. I don't have as much experience as you but I have had two CB's pop while I was in flight. One was a CB failure and the other was a failed voltage regulator. Had I had fuses, the first would not have happened. As you can imagine, resetting the CB didn't help in the second failure so a fuse would have been fine there, too. From what I have read, and from my personal experience, I decided to put fuses in my plane.
And given what you and others have written, I will run ground wires, install fuses that are sized for the wires, and spend my time worrying about preventing the more likely failures (like brushing up on my soldering skills).
Gee... I wonder if I can still find my step-father's old soldering iron. The thing was large enough to almost be confused with a cop's Billy club.
  -- Art Z.
