Ring Terminals for Tyco LEV100A4ANG
haribole
PostPosted: Tue Mar 29, 2016 7:08 am    Post subject: Ring Terminals for Tyco LEV100A4ANG Reply with quote
Hello Group
I have been looking for terminal lugs for these contactors without much luck. These contactors have terminals that take M5 (0.19") bolts and the smallest holes on a copper lug that I could find are 5/16".
To those who have used these contactors, what lugs did you use?
HariĀ
jluckey(at)pacbell.net
PostPosted: Tue Mar 29, 2016 7:51 am    Post subject: Ring Terminals for Tyco LEV100A4ANG Reply with quote
What size cable are you using?
On Tuesday, March 29, 2016 8:42 AM, Hariharan Gopalan <rdu.hari(at)gmail.com> wrote:
Hello Group
Hari
haribole
PostPosted: Tue Mar 29, 2016 8:40 am    Post subject: Ring Terminals for Tyco LEV100A4ANG Reply with quote
#2 and #4
I found a 1/4 lug, but it is still large. Not sure if I can use washers between the terminal and the lug.
Hari
On Tue, Mar 29, 2016 at 11:49 AM, Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)> wrote:
On Tuesday, March 29, 2016 8:42 AM, Hariharan Gopalan <rdu.hari(at)gmail.com (rdu.hari(at)gmail.com)> wrote:
Hello Group
HariĀ
 Filesize:  87.71 KB
 Viewed:  5368 Time(s)
PostPosted: Tue Mar 29, 2016 8:42 am    Post subject: Ring Terminals for Tyco LEV100A4ANG Reply with quote
At 09:56 AM 3/29/2016, you wrote:
Hello Group
Order 3/16 terminals and drill them out to M5
http://tinyurl.com/gsccbm8
