Posted: Tue Mar 29, 2016 5:22 pm Post subject: GARMIN autopilot servos wiring |
Guys
Those of you who installed or are installing a GARMIN G3X, which wires or multi-wire cable did you use to connect the autopilot servos?
Carlos
Enviado do meu iPhone
stein(at)steinair.com Guest
Posted: Wed Mar 30, 2016 6:40 am Post subject: GARMIN autopilot servos wiring |
You would use shielded multi conductor wires for the CAN portion and
RS-232's (and possibly some trim), but individual wires for the CWS, PWR,
GND, and CAN termination (if you're using it for the terminator on the CAN).
Cheers,
Stein
Albert Gardner
Posted: Wed Mar 30, 2016 7:47 am Post subject: GARMIN autopilot servos wiring |
The list seems too quite lately. I'm thinking about building another plane
and wonder if it should be a tail-dragger or tri-gear, and which EFIS and
primer is best?
Albert Gardner
RV-19 N991RV
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Bob Turner
Posted: Wed Mar 30, 2016 8:14 am Post subject: Re: GARMIN autopilot servos wiring |
It has been quiet. I wonder if people are reluctant to post while Matt is in recovery?
_________________ Bob Turner
RV-10 QB |
Kellym
Posted: Wed Mar 30, 2016 6:11 pm Post subject: GARMIN autopilot servos wiring |
RV-14 tail wheel with Blue Mountain EFIS and Corrosion X for primer. 8^)
Then get RV-10 wings, and fuselage parts to stretch it back into a -10,
tail dragger. Of course you could upgrade to steam gauges and use Ipad
for MFD. For nostalgia you could add a Laurance GPS por Apollo 920.
On 3/30/2016 8:46 AM, Albert wrote:
primer is best?
Albert Gardner
RV-19 N991RV
Yuma, AZ
KCHD |
Posted: Thu Mar 31, 2016 10:35 am Post subject: GARMIN autopilot servos wiring |
Thank you Stein
I believe the DYNON servo wires are all unshielded.
Why do you recommend the CAN, the RS-232 and the trim wires to be shielded?
Best
Carlos
No dia 30/03/2016, às 10:39, Stein Bruch <stein(at)steinair.com> escreveu:
Cheers,
Stein
Posted: Thu Mar 31, 2016 11:28 am Post subject: GARMIN autopilot servos wiring |
Because it's what Garmin recommends in their manual!
That said, it is recommended to be shielded just to keep "noise" to a minimum, but we actually have seen people retrofit both TruTrak and Dynon Autopilots with the Garmin Servos, re-use their existing wiring with no ill effects. Of course it's always best to follow the manufacturer recommendations, but we have seen people do it the other way and have acceptable results....we've also seen people have unacceptable results as well though (so fair warning).
Cheers,
Stein
