choke cable query
rowlandcarson(at)gmail.co
PostPosted: Wed Apr 06, 2016 9:55 am    Post subject: choke cable query Reply with quote
I’ve got to the stage of hanging my Rotax 912ULS engine on my Europa XS monowheel fuselage, just to check how and where various things will fit and where holes have to be made in the firewall, etc. (The firewall is not yet fitted at this stage and the engine will be coming off again later to fit that.)
I’ve connected the choke cables to the carbs but am puzzled by the resulting action at the knob. It seems to need quite a bit of effort to pull it out, and it will not stay in the out (ie choke on) position, but slides back in to almost the rest position immediately.
I routed the cables the same way as the throttle cables, through the small gap between the top tube of the landing gear frame and the corner of the phenolic firewall, and they seem quite comfortable there. I have fitted the SkyDrive carb heaters which move the carbs aftwards a little, but I don't think that has a significant effect on the cable routing.
I had to snip a tiny bit off the stiff soldered ends of the cable inners in order to persuade them round the right-angle guide on the carbs, but otherwise I believe I have followed the manual exactly.
Is it intended that the choke knob has to be held out manually? Or is there some trick I’ve missed?
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
Burrilla
PostPosted: Wed Apr 06, 2016 10:06 am    Post subject: choke cable query Reply with quote
On my Tri-Gear the Choke also slides back in and I hold it out during start and warm up. slowly letting it go back in as the engine warms and no choke required.
If it locked out would that potentially give you a full choke out if you forgot to release it and push back in?
Mine also requires effort to pull out which I again perceive as no great problem providing you keep the cable lubricated and its not due to chafing.
Alan
G-OBJT
in friendship
Rowland
pete(at)lawless.info
PostPosted: Wed Apr 06, 2016 10:11 am    Post subject: choke cable query Reply with quote
No Roland you have not missed anything. You hold the choke with one
hand while pressing the starter with your second hand and holding the
stick back with your third.
Pete
G-RMAC Classic #109
in friendship
Rowland
dpark748(at)icloud.com
PostPosted: Wed Apr 06, 2016 10:12 am    Post subject: choke cable query Reply with quote
You only have to hold out for 10-15 seconds and slowly change to low throttle setting!
Dave G-LDVO
in friendship
Rowland
rlborger(at)mac.com
PostPosted: Wed Apr 06, 2016 11:15 am    Post subject: choke cable query Reply with quote
Rowland,
FWIW. That is the way my “Choke” has operated from day one.
I hold the choke out when starting cold. Use the throttle to set about 2000-2200 RPM to warm up. Then, continuing to hold the “Choke” knob, allow it to slowly retreat to maintain that 2000-2200 RPM as the engine warms and RPM slowly increases. Kind of gives me something to do while monitoring Oil Pressure, Oil Temp, Coolant Temp, CHT & EGT while warming the engine. My “Choke” will hold with about 1/4” of travel remaining. I have to be on the throttle when I push it in that last quarter inch as the engine RPM will drop quite a bit and I have to add throttle to get it back above 1800 RPM.
I don’t know of any means of increasing friction in the cable system to allow the cable to hold against the springs on the carbs.
Hope this helps. Maybe someone else can come up with a better idea.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (85 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Apr 6, 2016, at 12:53 PM, Rowland Carson <rowlandcarson(at)gmail.com> wrote:
in friendship
Rowland
rlborger(at)mac.com
PostPosted: Wed Apr 06, 2016 11:18 am    Post subject: choke cable query Reply with quote
Pete,
And don’t forget the throttle with your fourth hand!
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Apr 6, 2016, at 1:10 PM, Pete Lawless <pete(at)lawless.info> wrote:
No Roland you have not missed anything. You hold the choke with one hand while pressing the starter with your second hand and holding the stick back with your third.
Pete
G-RMAC Classic #109
PostPosted: Thu Apr 07, 2016 4:29 am    Post subject: choke cable query Reply with quote
Thanks to Pete and all the others who confirmed my suspicions!
in friendship
Rowland
