Tri-gear wheel source?
Rick Moss
PostPosted: Thu Apr 14, 2016 1:04 am    Post subject: Tri-gear wheel source? Reply with quote
Hi all,
Maintenance has just revealed a crack in one of the disk lugs of a main wheel on my Trigear. My preference would be to buy one from Europa, but they're closed for 2 weeks; does anybody know the Matco part details, as I believe they make them? I don't want to be grounded for that long!
Rick
nigel_graham(at)m-tecque.
PostPosted: Thu Apr 14, 2016 3:51 am    Post subject: Tri-gear wheel source? Reply with quote
I've attached a useful Matco publication to help you identify your parts.
You are in luck as it would appear that Matco will supply the brake half
of the wheel individually:
http://www.matcomfg.com/WHLW51125DRILLED-idv-3464-44.html
Nigel
On 14/04/2016 10:04, Rick Moss wrote:
Hi all,
Rick
http://forums.matronics.com/viewtopic.php?p=455010#455010
Matco_Wheels.pdf
 Filename:  Matco_Wheels.pdf
 Filesize:  1.2 MB
 Downloaded:  444 Time(s)
budyerly(at)msn.com
PostPosted: Sat Apr 16, 2016 5:26 am    Post subject: Tri-gear wheel source? Reply with quote
Rick,
Go onto my www.customflightcreations.com site and hit the techniques
articles and download the pdf on spare parts. Everything from fuel to gear.
Other stuff their too.
Somebody should do the same type list for Europe.
Bud Yerly
