Powering "minor" devices
trigo(at)mail.telepac.pt
PostPosted: Tue Apr 26, 2016 2:43 am    Post subject: Powering "minor" devices Reply with quote
Bob and all
I have to get power to 5 or 6 critters who will live in my instrument panel (instruments' lights, LED strip, USB socket, warning lights, etc.).
I don't want to have a dedicated circuit breaker (or fuse - please don't start a CB versus Fuse war again...), so I decided to use a small buss, powered from a single CB, and then connect all those devices to this small buss.
Questions:
- is this the right and elegant solution to this particular need?
- which kind of buss should I use, a single bolt/screw, or a small bar?
- as for the circuit-breaker, should I use a 2A, which would be what each circuit would need, or should I "upgrade" it to, say 5A, to protect all wires for the case all of them are simultaneously transporting energy?
Carlos
Enviado do meu iPhone
ARGOLDMAN(at)aol.com
PostPosted: Tue Apr 26, 2016 3:44 am    Post subject: Powering "minor" devices Reply with quote
Carlos, consider individual poly fuses for those. a short in one of the "minors" will not effect the others and you have protection.
Practice Safe sparks.
Rich
In a message dated 4/26/2016 3:44:28 A.M. Pacific Daylight Time, trigo(at)mail.telepac.pt writes:
--> AeroElectric-List message posted by: Carlos Trigo <trigo(at)mail.telepac.pt>
Bob and all
I don't want to have a dedicated circuit breaker (or fuse - please don't start a CB versus Fuse war again..), so I decided to use a small buss, powered from a single CB, and then connect all those devices to this small buss.
Questions:
Carlos
Enviado do meu ======================== = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - NEW MATRONICS LIST WIKI -_-= - List Contribution Web Site sp;   ===================================================
yellowduckduo(at)gmail.co
PostPosted: Tue Apr 26, 2016 4:40 am    Post subject: Powering "minor" devices Reply with quote
I would use a single bolt and 5 amp protection with awg22 wire.
I would also daisy chain anywhere that made sense. ie if not convenient
to bring some wires back to the CB then split them off from any of the
downstream connections.
Don't drop down to smaller wires though as the 5 amp CB might not
properly protect some smaller wires.
Ken
On 26/04/2016 6:41 AM, Carlos Trigo wrote:
Bob and all
Questions:
Carlos
stein(at)steinair.com
PostPosted: Tue Apr 26, 2016 6:30 am    Post subject: Powering "minor" devices Reply with quote
Not debating your rationale, but I will still give you my 2 cents and that
is not to do what you're doing....because I'm wondering what/how you're
going to size your protection device at? Will it be sized for the 2-4A USB
charger, or the .2A LED strip, or the warning lights, or the combination of
all of them (in which case the device would potentially be too large to
protect the wiring to any single one of them)? At this point in your build,
don't step over a dollar to pick up a dime.
One of the easiest solutions to that conundrum is a small fuse block with a
single input that has 6+ circuits that you can individually fuse. You could
still hide it behind a screen where it has easy access, but it'd be much
simpler and much more elegant in my opinion....plus the quickest and easiest
to wire up yet still allowing you the option for multiple protected circuits
quite easy and cleanly.
If you're still dead set against protecting each device/circuit (which I
stress would be the proper method), I'd say use either a smaller terminal
strip with jumpers or a remade buss bar with either bolts or screws on it.
Again, the goal here is to keep it simple, clean and have the least amount
of "failure points" in the system.
Stein
PostPosted: Tue Apr 26, 2016 7:26 am    Post subject: Powering "minor" devices Reply with quote
Bob and all
It's entirely rational. It's done on a larger scale
in TC aircraft.
Consider the distribution tree and its branches.
A similar thing is in operation all over your
house. Any one appliance, like a hair dryer,
may have a current/overheat protector built
in. The breaker feeding the outlet comes from
a bus in your breaker box. A transformer behind
your house probably has a protective device on
the hv primary feeder . . . and so it goes up
the line until you get to a steam driven turbine
somewhere that powers a whole lot of hair dryers.
The goal in designing distribution is to protect
branches with devices robust enough to not be
nuisance tripped by anticipated load and fault
conditions downstream. For example, the main
breaker for your house should not operate when
every branch is loaded to capacity and only
one branch is faulted causing its particular
breaker to open. Hence, a short in nobody's
hair dryer should turn out the lights in the
the room, much less the whole neighborhood.
A Hawker or King Air has multiple busses
with feeders from heavier upstream sources.
In every instance, a bus feeder is selected
to be free of nuisance tripping due to
smaller faults downstream. There have been
a number of suggestions for selection of
protective devices . . . the choices are
several and combinations are many. But one
simple design rule applies: Don't let any
single fault event propagate into other
systems. Hence, you can use a fuse, cb,
current limiter or automatic solid-state
wire-protection gee-whizz at the source
end of any feeder . . . just make sure it
is sized for DYNAMIC performance to grunt
the load of any single downstream fault.
Breakers are very slow compared to fuses.
A breaker protected 'buss feeder' to a
fuse block is a perfectly rational thing
to consider. You may want to size the bus
feeder and wire not so much for temperature
effects of maximum anticipated loads . . .
but from the perspective of staying put
when your GPS feeder fuse is called upon
to operate. A 30A breaker driving a 10AWG
feeder to a block of ten, 1A fuses may
be a bit overkill . . . but it does
not violate the first rule of feeder
protection - protect the feeder but ignore
downstream faults.
PostPosted: Tue Apr 26, 2016 7:28 am    Post subject: Powering "minor" devices Reply with quote
RIGHT ON!
PostPosted: Tue Apr 26, 2016 9:01 am    Post subject: Re: Powering Reply with quote
How minor are those items? Do you care if they all stop working at once? If they all go dead, will it be a non event that can wait until landing? If not, follow Stein's advice. Install a 4 or 6 position fuse block. It does not necessarily have to be in-flight accessible. The fuse block can be mounted out of sight. You are better off waiting until safely on the ground before replacing a fuse. I think that each and every electrical load should have its own fuse. If one blows, you will know exactly which load is the problem. Fuses are cheap.
Years ago an airliner crashed because the pilot and copilot were distracted trying to replace an indicator lamp.
Joe Gores
PostPosted: Tue Apr 26, 2016 9:10 am    Post subject: Powering "minor" devices Reply with quote
Thanks for your answer, but to be frank you got a little bit too much philosophical, so in the end I think I did not quite got your message
Could you please be a little more specific on answering my 3 questions?
Carlos
No dia 26/04/2016, às 16:25, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> escreveu:
--> AeroElectric-List message posted by: Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)>
Bob and all
in TC aircraft.
downstream faults.
PostPosted: Tue Apr 26, 2016 9:41 am    Post subject: Powering "minor" devices Reply with quote
Thank you Stein
I will consider your solution.
CT
No dia 26/04/2016, às 15:28, Stein Bruch <stein(at)steinair.com> escreveu:
Stein
PostPosted: Tue Apr 26, 2016 9:42 am    Post subject: Powering "minor" devices Reply with quote
Thank you Ken
You did answer all my questions.
Carlos
No dia 26/04/2016, às 13:38, C&K <yellowduckduo(at)gmail.com> escreveu:
I would also daisy chain anywhere that made sense. ie if not convenient to bring some wires back to the CB then split them off from any of the downstream connections.
Don't drop down to smaller wires though as the 5 amp CB might not properly protect some smaller wires.
Ken
> Bob and all
> Questions:
> Regards
> Carlos
PostPosted: Tue Apr 26, 2016 1:59 pm    Post subject: Powering "minor" devices Reply with quote
At 12:09 PM 4/26/2016, you wrote:
If it were my airplane:
Select a fuse-block (which becomes your minor-items bus)
with sufficient number of slots to power planned devices
plus a few spares . . . perhaps a 10-slot block.
Wire this 'fuse bus' to your main bus through a
robust feeder, say 14AWG.
Put a 15A breaker or 20A fuse at the main bus
end of this feeder.
Populate the minor items bus with fuses no
greater than say 3A so each item enjoys
its own, protected source.
PostPosted: Tue Apr 26, 2016 2:40 pm    Post subject: Powering "minor" devices Reply with quote
My exact recommendation as well! Cheap, easy, light and accomplishes exactly what you want/need whilst still be serviceable and proper.
Stein
Do not archive.
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: Tuesday, April 26, 2016 4:58 PM
Subject: Re: Powering "minor" devices
end of this feeder.
PostPosted: Tue Apr 26, 2016 3:42 pm    Post subject: Re: Powering Reply with quote
When trying to decide which is the best way to accomplish a task, I ask myself what is best in the long run, not what is the easiest or least expensive at the moment. In this particular case, Stein and Bob have suggested the right and elegant long term solution. A few years from now when one of those fuses blow, you will be thankful that 5 other electrical loads still work. And you will know which device caused the fuse to blow.
Joe Gores
