Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Fri Jul 07, 2006 9:51 am Post subject: Elevator trim servo |
I have a question for the group. I am finishing up section 12 and am to the point of adjusting the elevator trim tab servo. The instructions say to move the servo are through the necessary range of motion (don't have my plans available right now to get the exact wording). My question is what kind of power sources have been used to motor the servo, or what other method has been used? I would appreciate any assistance and suggestions on this matter as I wasn't able to track down much through the archives. Thank you.
Eric Kallio
#518 finishing up the tailcone
mstewart(at)iss.net Guest
Posted: Fri Jul 07, 2006 10:14 am Post subject: Elevator trim servo |
Using the white wires, you can run the motor off any ~12v source.
I used my 14.4 volt battery off my cordless drill for this motor and the
flap motor. Just flip the wires around to run the motor the other way.
Mike
rene(at)felker.com Guest
I used a model train transformer. Don't be surprised when the cable
movement is asymmetrical. One of the cables moves out and back if I
remember right.
Rene' Felker
40322
N423CF
Finish Kit
jim(at)CombsFive.Com Guest
Posted: Fri Jul 07, 2006 10:54 am Post subject: Elevator trim servo |
9 volt rectangular battery works just fine.
Use the two unmarked leads of the servo.
Swap the leads to change direction.
The servo will stop on it's own when travel limits are reached.
Note: The left and right trim tabs move different amounts.
Jim Combs
40192
Eric Kallio
http://forums.matronics.com/viewtopic.php?p=45513#45513
rvbuilder(at)sausen.net Guest
Posted: Fri Jul 07, 2006 11:13 am Post subject: Elevator trim servo |
In addition to the answers you already received, I believe several
people in the past simply used a 9 volt battery. I think I used a auto
battery charger.
Michael Sausen
RV-10 #352 Working on Fuselage
Tim(at)MyRV10.com Guest
Posted: Fri Jul 07, 2006 11:27 am Post subject: Elevator trim servo |
I think you may be able to use a 9V battery. I'm not sure if that's
what I used or not, but it may have been. If that doesn't work,
then any old 12V source should do.
Eric_Kallio wrote:
Eric Kallio #518 finishing up the tailcone
Rick S.
Posted: Fri Jul 07, 2006 1:28 pm Post subject: Elevator trim servo |
Eric,
I picked up a 12 volt 1000 Mah DC power supply from Radio Shack. It was like $20. I have used it to operate and test all the electrical items I have installed to date to include lights, strobes, flap motor, trim servos, trim relays and it even kicks over the main battery relays. Pick up a set of aligator clips and install them on the leads. Very easy and cheap way to ops check things as you go.
Rick S.
40185
Wiring
_________________ Rick S.
RV-10
40185 |
