		kinnepix(at)earthlink.net Guest
				 Posted: Mon Jan 16, 2006 7:37 am    Post subject: VG's |
				With all the talk about VG's I haven't heard anything about how
 they're to be lined up fore-and-aft. Any specs on this?  If they're
 straight into the wind I don't believe they'll do diddley. Look at a
 commercial jet's wings -- esp. the 727. The VG's are twisted about
 10-15 degrees. They are after all meant to create turbulence right at
 the boundary layer -- how can they do this if they're edge-onto the
 apparent wind?
 Glaciers -- thanx John  for a GREAT pic of some marvellous country!
 Glaciers are soooo cool, esp. with a gravel strip at their foot. We
 did a lot of glacier flying on the Icefield Ranges in the Yukon years
 ago, in Helio Couriers, marvellous aircraft. Before I got there
 they'd lost an engine, then changed it out UP ON THE GLACIER!  Flew
 in the new engine, three long 4x4's, a chain  hoist, and went at it.
 Engine was a 540 as I recall. Not your typical maintenance --
 Only real txp problem I ever had was flying over Portland ME jetport
 years ago at 3500', photographing the coast. Didn't talk to tower or
 ATC . Later talked to Brunswick NAS  (to go thru their airspace), and
 they asked me to call PTL. When I did they said my txp readout was
 1300'!! -- which must have startled them a little. I pointed out that
 while the radar room  has no windows, the tower sure does, and they
 could so easily have looked out the window and seen I was NOT at
 1300', but at 3500'. Vis  was excellent that day. Anyway, I
 apologized but pointed out that I was flying  perfectly legally, and
 have a nice day. That was the end of it. But no doubt my N-number had
 a flag on it (another??)  from then on.
 Fly safe, have fun,
 Russ K
				 Posted: Mon Jan 16, 2006 8:28 am    Post subject: VG's |
				At 09:35 AM 1/16/06 -0600, you wrote:
 apparent wind?
 Russ,
 I developed my VG's from an old EAA Sport Aviation article.  They said 15
 degrees and that is what I used.  As I recall, they gave a height
 measurement (3/8 of an inch) but no other measurements, but they did include
 a photo in the article.  It showed a single vane VG and an old fashion lead
 pencil with the eraser end next to the VG.  By scanning in the photo and
 re-sizing the photo and comparing pencil eraser lengths, I was able
 determine the VG length. I used a trapezoidal shape the VG vane pairs
 because they will not work the fabric as hard as single vane a VG.
 All I can say is that they seem to work very well.  One could make them
 taller and wider, but doing so would increase VG weight and drag.  If you
 want to maintain the same top and/or cruise speed, it is important to
 minimize VG drag. It must be less or equal to the drag reduction that occurs
 by flying the wing at a lower angle of attack due to the wings increase in
 lift capability for a given air speed.
 Jack B. Hart FF004
 Winchester, IN
		ElleryWeld(at)aol.com Guest
				 Posted: Mon Jan 16, 2006 8:40 am    Post subject: VG's |
				Russ K are you in Maine ?
 Ellery in Maine
		Possum
				 Posted: Mon Jan 16, 2006 9:27 am    Post subject: VG's |
				At 10:35 AM 1/16/2006, you wrote:
 apparent wind?
  	  | Quote: | 	 		  To: kolb-list(at)matronics.com
 apparent wind?
 This is from http://www.landshorter.com/index.html
 Q:  How do I know where to put them on my wing and tail?
 A:  Our eight page manual and complete set of computer generated
 templates give you the information you need to install and test your
 Landshorter! vortex generators.  Most likely you will end up placing
 them around the 10% chord line for your wing and spacing them at
 about 50 per wing (close to 1% of span).  If you decide to use them
 on the underside of your horizontal stabilizer to improve your flare
 then you will place them about 1 1/2" apart and just in front of the
 elevator.  In all cases the VG's are placed at a precise angle to the
 airstream and are aligned and spaced with the included templates.
 What they look like on a Kolbish Aircraft
 http://sos.photosite.com/Album1/
		JetPilot
		Mark
				 Posted: Mon Jan 16, 2006 5:52 pm    Post subject: Re: VG's |
				I installed a set of VGs on my Twinstar.......WHAT A DIFFERENCE!!  Plane now stalls 38 power on,down from 45. Aileron control is more solid,used to have a dead spot in the middle a foot wide(or so it seemed).
   I tried these without expecting a lot,and got great results. I dont know how other Kolbs fly without them. That flat bottomed,sharp LE wing has some bad points too....the VGs seem to fix them...
  _________________ Mark Shimei
Twinstar, 503
Phantom, Kawasaki 440
Weight shift Quick, Chrysler |
				 Posted: Mon Jan 16, 2006 6:10 pm    Post subject: VG's |
 seem to fix them...
 | Mark Shimei
 Hi Mark:
 Please tell us about the dead spot in your ailerons and how the VG's
 improved this seemingly dangerous problem.
 Somehow there are a lot more Kolbs flying without VG's than with them.
 I don't know how we fly without them.
 Would also be very nice to know what these bad point of the Kolb wing
 are, and how the VG's fixed them.  To state that a wing has bad points
 does not help us understand the problem.
 MKIII
  _________________ John Hauck
Titus, Alabama |
		Richard Pike
				 Posted: Mon Jan 16, 2006 6:39 pm    Post subject: VG's |
				Other Kolbs fly pretty good without them. Better than most any thing
 else in it's class. But nothing made by man is perfect, and improvement
 is always possible. VG's fall into that category.
 Richard Pike
 MKIII N420P (420ldPoops)
 Mark wrote:
 Mark Shimei
 Twinstar, 503
 http://forums.matronics.com/viewtopic.php?p=4542#4542
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
				 Posted: Mon Jan 16, 2006 7:02 pm    Post subject: VG's |
				Right on, bro! glaciers are cool, but comfortable. I worked at -63
 once. THAT was more than  cool.
 (Shivering)
 do not archive (do we still need this??)
 On Jan 16, 2006, at 7:22 PM, JetPilot wrote:
  Hahahah,  I dont think you will find any disagreement there
  [Laughing]
  NO FEAR -  If you have no fear you did not go as fast as you could
  have !!!
  http://forums.matronics.com/viewtopic.php?p=4529#4529
				 Posted: Mon Jan 16, 2006 7:08 pm    Post subject: VG's |
 thing
 improvement
 | Richard Pike
 Richard:
 Would be very interesting to do a side by side comparison, two of same
 model Kolb aircraft, rather than individual tests that present results
 to the List based on their inprecise methods of testing.
 I would be more than happy to participate in such a test, as the Kolb
 without VG's.  Even side by side would not be precise, but would seem
 to me much better than what we have now.  Based on what I have read
 and seen on the List and the internet, I don't think I'll run right
 out and start sticking VG's on Miss P'fer.  I guess I have seen Kolbs
 fly with them, but have not paid that much particular attention at the
 time.  Wasn't any noticeable difference in performance between with
 and without.  However, if I could get up close to a MKIII that had
 them, compare take off, cruise, slow flight, short landings, etc.,
 then I would be better prepared to make a semi-educated decision about
 VG's.
 If me and Miss P'fer are put to shame, I'll run right out, get a
 bucket full of VG's and start sticking.
 Take care,
 Naked MKIII
Titus, Alabama |
		Denny Rowe
  Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
				 Posted: Mon Jan 16, 2006 7:49 pm    Post subject: VG's |
				John,
 Seeing how the take off and landing performance of Miss Pfer is already
 beyond the stock Mk-3 due to your gear mods, a side by side comparison with
 most any other Mk-3 with VGs would be worthless.
 Why don't you just make a bucket full of em out of Lexan and stick em on
 with double sided tape (outside the prop arc of course) and let us know your
 results.
 I don't have them either but if Possums and brother Pike say they work, I
 tend to beleive them.
 Again, I am not endorsing their use nor do I plan on installing them but
 their benifits on all types of planes seem to be fact, not fiction and you
 yourself are well known to want the most out of your bird. After all your
 mods, it seems like temporarily sticking a few VGs on your wings would be
 childs play.
 Denny Rowe
		JetPilot
				 Posted: Mon Jan 16, 2006 8:09 pm    Post subject: Re: VG's |
				[quote="John Hauck]
 VG's.
 [/quote]
 Hi John
 It wont be to long before my MK III is finished with VG's on it.  It will be very similar to yours, 912's, Classic Flaps, Slightly heavy...  Im sure we will meet up at a fly in one day and you will be welcome to try it and see if you like them.
 Michael A. Bigelow
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
				 Posted: Mon Jan 16, 2006 8:10 pm    Post subject: VG's |
 <rowedl(at)highstream.net>
 already
 comparison with
 Got stock wings, tail, and an 11 lb tail wheel.     Not going to fly
 any sooner than stock.  Don't see how the main gear are going to give
 it a lower stall speed/approach speed.
 em on
 know your
 | results.
 Don't have time right now.
 work, I
 I also believe them, but would be nice to be there and fly with them
 to compare the difference in real time rather than cyber time on the
 internet.
  After all your
 would be
 | childs play.
 Seems that way, but it ain't.  What mods are you talking about?  I
 haven't changed any flight characteristic of a MKIII from what was
 called for in the 1991 edition of the plans.  I don't mess with
 Homer's flight characteristics and never have.
 Shucks, I thought a good fly off comparison would be a good way to get
 a good idea of what I am missing.
 Looking for a little comparison.
Titus, Alabama |
				 Posted: Mon Jan 16, 2006 8:25 pm    Post subject: VG's |
 Im sure we will meet up at a flyin one day and you will be welcome to
 | Michael A. Bigelow
 Thanks Mike:
 One of these days I'll get to make a comparison.  Guess I am going to
 have to be patient.
 MKIII
Titus, Alabama |
				 Posted: Tue Jan 17, 2006 6:14 am    Post subject: VG's |
				Ellery
 I'm in CT, not ME -- but not by choice. ME is a great state. I run
 boats up & down coast (boatrelocate.com), used to fly, mostly
 coastal, like to troutfish (anywhere), hike (do), haven't yet run
 Allagash but would like to. Whjere are you?
 fair winds,
 Russ
 On Jan 16, 2006, at 10:40 AM, ElleryWeld(at)aol.com wrote:
  Ellery in Maine
		Denny Rowe
				 Posted: Tue Jan 17, 2006 6:27 am    Post subject: VG's |
		vicsvinyl(at)verizon.net Guest
				 Posted: Tue Jan 17, 2006 6:39 am    Post subject: VG's |
				Hey Russ, I'm about 60+ miles from Ellery And I can tell you , "yoy can't
 get Theya from heya"
 Vic
 MK3X
 Smellinocket,Me
				 Posted: Tue Jan 17, 2006 10:52 am    Post subject: VG's |
				CT thats where my wife is from
 I have been on the Alligash Water Way many times it is a great place  I am In
 a small town called Levant 11 miles West of" KBGR" Bangor International
 Airport
 Ellery
				 Posted: Wed Jan 18, 2006 4:28 am    Post subject: VG's |
				Hi,
 the only way that John is going to be convinced of the efficacy of VG`s is
 to fit some to his own bird and try it.  Kit built planes vary quite a bit
 in performance depending on the builder and flying one against the other
 would be a pretty useless exercise.
 The only way is to fly a single plane, establish a datum, fit the VG`s and
 fly it and measure again.
 Cheers
 Pat
