727gs
Posted: Fri May 20, 2016 5:24 am Post subject: Serial #/Build Date |
I remember seeing a CJ serial # graph somewhere that showed a manufacture date but I don't remember where it was.
My airplane: 4032009
Can someone point me in the right direction?
Thanks in advance.
_________________ Steve near Chicago |
wlannon(at)shaw.ca Guest
Posted: Fri May 20, 2016 8:30 am Post subject: Serial #/Build Date |
Hi Steve;
Your CJ is # 09 of Batch # 40 from Factory # 320.
There should be a small alum. plate riveted on the forward side of the
firewall on the RH side. It should also show the date of manufacture.
Each major airframe component also has the ID plate.
Walt
William Halverson
Posted: Fri May 20, 2016 8:59 am Post subject: Serial #/Build Date |
Proof that there is almost no question this group can't answer!
[quote]--
draftsjust417(at)gmail.co Guest
Posted: Fri May 20, 2016 9:12 am Post subject: Serial #/Build Date |
I seem to recall that in C Payne's "CJ6 Buyer's Guide", there was a chart that provided serial #, mfg, reference info... ?
Justin
N280NC
On Fri, May 20, 2016 at 8:58 AM, William Halverson <william(at)netpros.net (william(at)netpros.net)> wrote:
[quote]Proof that there is almost no question this group can't answer!
Â
[quote]--
cjpilot710(at)aol.com Guest
Posted: Fri May 20, 2016 10:27 am Post subject: Serial #/Build Date |
See the Red Alert - Spring issue 2007 page 5 & 6.
Jim "Pappy" Goolsby
In a message dated 5/20/2016 1:13:33 P.M. Eastern Daylight Time, draftsjust417(at)gmail.com writes:
Quote: | I seem to recall that in C Payne's "CJ6 Buyer's Guide", there was a chart that provided serial #, mfg, reference info... ?
Justin
N280NC
Quote: | Proof that there is almost no question this group can't answer!
Quote: | -----Original Message-----
From: Walter Lannon [mailto:wlannon(at)shaw.ca (wlannon(at)shaw.ca)]
Sent: Friday, May 20, 2016 12:28 PM
Subject: Re: Yak-List: Serial #/Build Date
--> Yak-List message posted by: "Walter Lannon" Hi Steve; Your CJ is # 09 of Batch # 40 from Factory # 320. There should be a small alum. plate riveted on the forward side of the firewall on the RH side. It should also show the date of manufacture. Each major airframe component also has the ID plate. Walt
-----Original Message----- From: 727gs Sent: Friday, May 20, 2016 6:24 AM To: yak-list(at)matronics.com (yak-list(at)matronics.com) Subject: Serial #/Build Date --> Yak-List message posted by: "727gs" <727gs(at)att.net (727gs(at)att.net)> I remember seeing a CJ serial # graph somewhere that showed a manufacture date but I don't remember where it was. My airplane: 4032009 Can someone point me in the right direction? Thanks in advance. -------- Steve near Chicago Read this topic online here: http://forums.matronics.com/viewtopic.php?p=456388#456388 |
Posted: Fri May 20, 2016 11:20 am Post subject: Serial #/Build Date |
Batch 40 was 24 aircraft built between June 1984 and March 1985 at the Nanchang factory. Airplanes #23 & #24 went to Bangladesh, the remainder to the PLAF.
Jim "Pappy" Goolsby
In a message dated 5/20/2016 2:25:26 P.M. Eastern Daylight Time, cjpilot710(at)aol.com writes:
Quote: | See the Red Alert - Spring issue 2007 page 5 & 6.
[i]Jim "Pappy" Goolsby
Justin
N280NC
Subject: Re: Serial #/Build Date
[/i]
jay-dub
Posted: Sat May 21, 2016 1:37 pm Post subject: Re: Serial #/Build Date |
Mine is 3151215. Presumably number 15, batch 31, factory 512.
Would you mind telling me which factory and the year please? Our UK paperwork says 1976...
_________________ CJ owner |
Posted: Sat May 21, 2016 8:06 pm Post subject: Serial #/Build Date |
Batch 31 was 21 aircraft - built between Sept 1975 and Jan 1976. All aircraft went to the PLAF. I know there was factory "512" but I don't know where.
Jim "Pappy" Goolsby
In a message dated 5/21/2016 5:38:23 P.M. Eastern Daylight Time, flyjnw(at)gmail.com writes:
Quote: | --> Yak-List message posted by: "jay-dub" <flyjnw(at)gmail.com>
CJ and Yak-52 owner
http://forums.matronics.com/viewtopic.php?p=456430#456430===============================================
_-= e ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - NEW MATRONICS LIST WIKI -_-= - List Contribution Web Site sp; ===================================================
Posted: Sat May 21, 2016 8:12 pm Post subject: Serial #/Build Date |
BTW the largest batches were #24 to #29 with each batch made of 80 aircraft. Constructed between Oct 1968 and June 1975.
Jim "Pappy" Goolsby
CJ and Yak-52 owner
jay-dub
Posted: Sun May 22, 2016 10:38 am Post subject: Re: Serial #/Build Date |
Thanks.
