Fuselage #30 rivets
JOHN TIPTON
PostPosted: Sun May 22, 2016 2:39 am    Post subject: Fuselage #30 rivets Reply with quote
Hi Guys
There seems to be excessive use of #30 rivets for the fuselage (-9) internals, does it really need them, example: tunnel cover 16x 1/8inch rivets listed
John
ceengland7(at)gmail.com
PostPosted: Sun May 22, 2016 7:06 am    Post subject: Fuselage #30 rivets Reply with quote
On 5/22/2016 5:39 AM, JOHN TIPTON wrote:
Hi Guys
John
I'm building a -7 (same fuselage), & can't figure out which area you're
talking about. Having said that, I'm not an aero engineer, so I try not
to second guess the designer (who, hopefully, is) if the area is
structural. Perhaps the cover you're talking about is required to
complete an area that's structurally significant.
Charlie
gyoung
PostPosted: Sun May 22, 2016 7:18 am    Post subject: Fuselage #30 rivets Reply with quote
The short answer is yes. Van is a minimalist. His designs do not include anything he doesn't believe is needed. The RV's also use mostly -3 rivets so when they use -4's it's for a reason.
Greg Young
JOHN TIPTON
PostPosted: Sun May 22, 2016 9:33 am    Post subject: Re: Fuselage #30 rivets Reply with quote
Charlie
Can't imagine you don't know what the tunnel cover is:
https://buildaplane.files.wordpress.com/2013/01/4-f-741b-center-tunnel-cover-fabricated-and-ready-to-drill.jpg. (Full acknowledgement to the copyright owner)
John
dickseiders(at)gmail.com
PostPosted: Sun May 22, 2016 10:57 am    Post subject: Fuselage #30 rivets Reply with quote
Read Greg young's answer again.
Dick seiders
On May 22, 2016, at 12:33 PM, JOHN TIPTON <jmtipton(at)btopenworld.com> wrote:
Charlie
John
http://forums.matronics.com/viewtopic.php?p=456447#456447
halbenjamin101(at)gmail.c
PostPosted: Sun May 22, 2016 11:25 am    Post subject: Fuselage #30 rivets Reply with quote
Greg is right on. Besides, if you build it per Van's instructions that is one thing less to worry about as you're about to advance the throttle on your first flight!
Hal Benjamin
RV-4 Flying
Long Island, NY
218 Hours
Sent from my iPad
[quote] On May 22, 2016, at 11:17 AM, "bigdog(at)bentwing.com" <bigdog(at)bentwing.com> wrote:
Greg Young
JOHN TIPTON
PostPosted: Sun May 22, 2016 11:41 am    Post subject: Re: Fuselage #30 rivets Reply with quote
Van is a 'minimalist' - I thought his planes were over engineered (bullet proof) - but I stand corrected
John
HCRV6(at)comcast.net
PostPosted: Sun May 22, 2016 12:14 pm    Post subject: Fuselage #30 rivets Reply with quote
Van is not known for an excessive use of anything. If the plans call for it, do it!
Harry Crosby
RV-6 N16CX, 1365 hours.
To: "RV-List" <rv-list(at)matronics.com>
Sent: Sunday, May 22, 2016 3:39:39 AM
Subject: Fuselage #30 rivets
--> RV-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com>
Hi Guys
John
http://forums.matronics.com/viewtopic.php?p=456436#456436
-Matt Dralle, List ==========
jsflyrv(at)frontier.com
PostPosted: Sun May 22, 2016 12:16 pm    Post subject: Fuselage #30 rivets Reply with quote
I think you took Greg's answer in the wrong way. Van's airplanes ARE
over engineered.
John
http://forums.matronics.com/viewtopic.php?p=456456#456456
vanremog(at)aol.com
PostPosted: Sun May 22, 2016 1:19 pm    Post subject: Fuselage #30 rivets Reply with quote
Van's designs are "well engineered". Some things like the original spar were over engineered. Other areas were maybe a little light and prone to cracking but they have been corrected as the designs matured.
After all of the things we have put Van's planes thru over the years I think it is safe to say that they have stood the test of time, so I would recommend building per plans. Small downside, large upside.
-GV
JOHN TIPTON
PostPosted: Sun May 22, 2016 2:09 pm    Post subject: Re: Fuselage #30 rivets Reply with quote
I agree
John
PostPosted: Sun May 22, 2016 2:17 pm    Post subject: Fuselage #30 rivets Reply with quote
On Sun, May 22, 2016 at 12:33 PM, JOHN TIPTON <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)> wrote:
--> RV-List message posted by: "JOHN TIPTON" <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)>
Charlie
John
Thought that might be what you were talking about, but wasn't sure. (Had to go find mine; it's been a while since I built it.)
Look at what it's built of, and what it's expected to withstand in normal use. That's pretty heavy Z channel for a 'cover,' no? Why not use .030 sheet instead of extruded Z stock, & bend it up out of one piece? But what happens when your 200 lb passenger plants their foot on it and pushes off, exiting the plane?
Van is a minimalist, *and* the planes are over-built. I'm sure you can work out the paradox.
Charlie
PostPosted: Sun May 22, 2016 2:31 pm    Post subject: Fuselage #30 rivets Reply with quote
On Sun, May 22, 2016 at 5:16 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
Charlie
John
Charlie
Should have added (or maybe led with), My kit didn't come with any universal head 3/32 rivets. Maybe the engineer decided that 1/8 round heads (already in the kit) would be fine and avoid the need to dimple the top piece & countersink the Z channels.
