pulsair(at)mindspring.com Guest
Posted: Fri Jul 07, 2006 12:30 pm Post subject: Turtle Deck |
John McBean,
I have been thinking about replacing the turtle deck on my Classic IV. I was thinking of the Leaxn but think it is probable heavier than the aluminum. What I would like to do is go to a one piece turtle deck with one window. Do away with the havles and make it one piece. Do you know if Skystar fabricated their own or did they send that out? Jeff
bmwebb(at)cox.net Guest
Posted: Fri Jul 07, 2006 1:43 pm Post subject: Turtle Deck |
Jeff, I did just that. Mine was the original two window design, and I just cut a large opening, and pop-riveted a single panel of polycarbonate into it, with RTV to seal it from water. I drilled out the hinge rivets, and riveted a thin aluminum sheet behind (under) it, and it works great, super easy, and quick. And a $12 roll of dark window film finished it off nicely.
I had the thought of replacing the original hinge, and have a single window that folds. Not much harder, and still allows it to fit in the seat for transport.
As easy as it was, there is no way I could justify the expense of the formed Lexan turtledeck. It would have to sell for $50 to make it a cost-effective replacement for my method.
Bradley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of jeff puls
Sent: Friday, July 07, 2006 4:09 PM
Subject: Turtle Deck
John McBean,
lcfitt(at)sbcglobal.net Guest
Posted: Fri Jul 07, 2006 3:27 pm Post subject: Turtle Deck |
Not a bad idea. As I recall the original reason for the hinge was for the
guys trailering. After folding the wings, the turtle deck folded and fit
nicely on the seats.
Lowell
noelloveys(at)yahoo.ca Guest
Posted: Sat Jul 08, 2006 2:57 am Post subject: Turtle Deck |
My turtle deck is a one piece with a single large piece of Lexan installed.
I think the original builder fabricated it himself to try to cut down on
winter drafts. I much prefer to use it to the folding deck which I also
have. The one piece is quite a bit easier to install as the centre isn't
flopping around like a drunken sailor while I'm trying to get the camlocs
turned.
Noel
[quote] --
Michel
Posted: Sat Jul 08, 2006 4:06 am Post subject: Turtle Deck |
On Jul 8, 2006, at 12:54 PM, Noel Loveys wrote:
| Quote: | ... flopping around like a drunken sailor ...
Whot? Er ye talking 'bout me, gov?
I also fond the hinged turtle deck to be a source of rainwater
infiltration. I had to tape mine. I'd rather have a one-piece one.
Michel
Posted: Sat Jul 08, 2006 7:16 pm Post subject: Turtle Deck |
In the cold winter weather the previous owner of my plane also taped the
edges around my one piece deck. I haven't flown in the winter yet.
As for drunken sailors... I look out my double patio doors and see the cruel
sea..... (North Atlantic) That's the cheapest high I can imagine!! and I
wouldn't' be any place else!!
Noel
[quote] --
Lynn Matteson
Posted: Mon Jul 10, 2006 3:32 pm Post subject: Turtle Deck |
Jeff-
I got my one-piece t'deck from LP Aeroplastics. You make the former
t'deck a one-piece, then attach the LP version, bubble window, to it.
Lynn
On Friday, July 7, 2006, at 04:08 PM, jeff puls wrote:
| Quote: | John McBean,
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Mon Jul 10, 2006 5:20 pm Post subject: Turtle Deck |
Can we see a picture? Please.
Noel
[quote] --
henrysfork1(at)msn.com Guest
Posted: Tue Jul 11, 2006 4:38 am Post subject: Turtle Deck |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I installed a one piece turtle deck with no window and don't miss it a bit.
Dee
