		CarterM
				 Posted: Tue May 31, 2016 8:58 pm    Post subject: Stainless Steel Exhaust Needed |
				Good evening Yakkers,
 I am desperately in need of a piece for my Housai stainless steel exhaust. I managed to toast the piece on the Number 2 cylinder (top left if you're sitting in the cockpit). Checked with both Doug and M-14P to no success. Looks like I may have to get one shipped from China unless anyone out there has one they would be willing to sell.
 Thanks!
 Carter
		byronmfox(at)gmail.com Guest
				 Posted: Wed Jun 01, 2016 6:38 am    Post subject: Stainless Steel Exhaust Needed |
				Suggest you also check with Jim Selby, jimscjs(at)att.net , and Vladimir Yastremski, yastremski(at)sbcglobal.net
 Blitz Fox
 415-307-2405
  	  | Quote: | 	 		   On May 31, 2016, at 9:58 PM, CarterM <cmann1.cm(at)gmail.com> wrote:
  Thanks!
  Carter
  http://forums.matronics.com/viewtopic.php?p=456722#456722
		wlannon(at)shaw.ca Guest
				 Posted: Wed Jun 01, 2016 9:11 am    Post subject: Stainless Steel Exhaust Needed |
				Hi Carter;
 I have many new, old stock, NON stainless exhaust sections.
 Probably 3 or 4 of the one you need.   No charge but you will have to tell
 me how you managed to toast it!
 Walt
		jblake207(at)comcast.net Guest
				 Posted: Wed Jun 01, 2016 9:27 am    Post subject: Stainless Steel Exhaust Needed |
				I'd offer to weld it, but I promised my welding instructor in A&P school that I'd never weld on an airplane if he'd just pass me... Only broke that promise once and it cost me a who new muff for my C172...
 Sent from my Verizon Wireless 4G LTE DROID
 Byron M Fox <byronmfox(at)gmail.com> wrote:
 --> Yak-List message posted by: Byron M Fox <byronmfox(at)gmail.com>
 Blitz Fox
 415-307-2405
  --> Yak-List message posted by: "CarterM" <cmann1.cm(at)gmail.com>
  Thanks!
  Carter
 _-============================================================
 _-=          - The Yak-List Email Forum -
 _-= Use the Matronics List Features Navigator to browse
 _-= the many List utilities such as List Un/Subscription,
 _-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
 _-= Photoshare, and much much more:
 _-=
 _-=   --> http://www.matronics.com/Navigator?Yak-List
 _-=
 _-=               - MATRONICS WEB FORUMS -
 _-= Same great content also available via the Web Forums!
 _-=
 _-=   --> http://forums.matronics.com
 _-=
 _-=              - NEW MATRONICS LIST WIKI -
 _-= Add some info to the Matronics Email List Wiki!
 _-=   --> http://wiki.matronics.com
 _-=             - List Contribution Web Site -
 _-=  Thank you for your generous support!
 _-=                              -Matt Dralle, List Admin.
 _-=   --> http://www.matronics.com/contribution
		dougsappllc(at)gmail.com Guest
				 Posted: Wed Jun 01, 2016 10:16 am    Post subject: Stainless Steel Exhaust Needed |
				Walt,Failure sequence of the std steel stock Chinese exhaust is normally first- top left, next bottom right, then bottom left.  If his pipes are all the same age and the top left is bad the bottom L & R are not far behind.  I do have the L & R bottoms in stainless steel, but no joy on the top left.
 Doug
 On Wed, Jun 1, 2016 at 9:47 AM, Walter Lannon <wlannon(at)shaw.ca (wlannon(at)shaw.ca)> wrote:
 [quote]--> Yak-List message posted by: "Walter Lannon" <wlannon(at)shaw.ca (wlannon(at)shaw.ca)>
  Hi Carter;
  Probably 3 or 4 of the one you need.   No charge but you will have to tell me how you managed to toast it!
  Walt
				 Posted: Wed Jun 01, 2016 7:19 pm    Post subject: Stainless Steel Exhaust Needed |
				Doug;
  He says it is a stainless exhaust.   The upper left apparently  failed at the weld joint to the cylinder flare.
  Walt
  Sent: Wednesday, June 01, 2016 10:51 AM
  Subject: Re: Stainless Steel Exhaust  Needed
   Walt,  Failure sequence of the std steel stock Chinese exhaust is normally first-  top left, next bottom right, then bottom left.  If his pipes are all the  same age and the top left is bad the bottom L & R are not far behind.   I do have the L & R bottoms in stainless steel, but no joy on the top  left.
  Doug
 Hi    Carter;
 Walt
		CarterM
				 Posted: Wed Jun 01, 2016 8:19 pm    Post subject: Re: Stainless Steel Exhaust Needed |
				First off, thank you all for the very quick responses. Looks like we have a solution in place.
 Second, yes we put the stainless exhaust on about 8-9 years ago (we've had the airplane almost 10) after the original exhaust failed. As Walt describes, this piece failed at the joint where the pipe flares to meed the cylinder underneath the locking nut. It will be a few days before I can provide pictures, but in the end there was nothing left of the flared portion to weld back onto the pipe and duplicating the flare without a pattern would be an exercise in futility.
		Viperdoc
				 Posted: Wed Jun 01, 2016 9:23 pm    Post subject: Stainless Steel Exhaust Needed |
				Tie an art.
 Doc
 Sent from my iPad
 On Jun 1, 2016, at 12:03 PM, Jon Blake <jblake207(at)comcast.net (jblake207(at)comcast.net)> wrote:
  	  | Quote: | 	 		  I'd offer to weld it, but I promised my welding instructor in A&P school that I'd never weld on an airplane if he'd just pass me... Only broke that promise once and it cost me a who new muff for my C172...
 Byron M Fox <byronmfox(at)gmail.com (byronmfox(at)gmail.com)> wrote:
 --> Yak-List message posted by: Byron M Fox <byronmfox(at)gmail.com (byronmfox(at)gmail.com)>
  Suggest you also check with Jim Selby, jimscjs(at)att.net (jimscjs(at)att.net) , and Vladimir Yastremski, yastremski(at)sbcglobal.net (yastremski(at)sbcglobal.net)
 Blitz Fox
 415-307-2405
  	  | Quote: | 	 		   On May 31, 2016, at 9:58 PM, CarterM <cmann1.cm(at)gmail.com (cmann1.cm(at)gmail.com)> wrote:
  --> Yak-List message posted by: "CarterM" <cmann1.cm(at)gmail.com (cmann1.cm(at)gmail.com)>
  Thanks!
  Carter
  http://www.matronics.com/Navig==========================p;             -=======================================================================================================http:/================================================
  _________________ Viperdoc |
