draftsjust417(at)gmail.co Guest
Posted: Mon Jun 13, 2016 12:04 pm Post subject: main tire lock nut |
Gents (and ladies)-
Can anyone tell me the size of the socket required for the CJ6's main wheel locking nut?
I've heard 50mm... ?
Thanks all- Justin/N280NC
kelmonroe(at)comcast.net Guest
Posted: Mon Jun 13, 2016 1:10 pm Post subject: main tire lock nut |
I think the right main is left hand thread!!!
| Quote: | On Jun 13, 2016, at 3:03 PM, Justin Drafts <draftsjust417(at)gmail.com> wrote:
Gents (and ladies)-
jblake207(at)comcast.net Guest
Justin, I was the one who said 50mm, but I wasn't exactly certain... the size is about 50... I also sometimes use a large left-handed (metric) crescent wrench. JB
Sent from my Verizon Wireless 4G LTE DROID
Gents (and ladies)-
dougsappllc(at)gmail.com Guest
Posted: Mon Jun 13, 2016 1:21 pm Post subject: main tire lock nut |
Justin,The nut which holds the wheel on mic's 46MM.
On Mon, Jun 13, 2016 at 1:03 PM, Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
| Quote: | Gents (and ladies)-
Posted: Mon Jun 13, 2016 1:30 pm Post subject: main tire lock nut |
You really don't need a socket Justin. You can use a pair of channel lock pliers or as otherwise called, a metric adjustable channel lock pliers. Just remember though....the left main nut is a right hand thread and the right main nut is a LEFT hand thread.
Dennis
To: yak-list(at)matronics.com
Sent: Monday, June 13, 2016 4:03 PM
Subject: Re: main tire lock nut
Gents (and ladies)-
Posted: Mon Jun 13, 2016 1:38 pm Post subject: main tire lock nut |
I was close...
Posted: Mon Jun 13, 2016 2:46 pm Post subject: main tire lock nut |
Ah, I'd heard that too. Thx- On Jun 13, 2016 1:13 PM, "Kelley Monroe" <kelmonroe(at)comcast.net (kelmonroe(at)comcast.net)> wrote: | Quote: | --> Yak-List message posted by: Kelley Monroe <kelmonroe(at)comcast.net (kelmonroe(at)comcast.net)>
> On Jun 13, 2016, at 3:03 PM, Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
> Gents (and ladies)-
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
Posted: Mon Jun 13, 2016 2:51 pm Post subject: main tire lock nut |
Excellent info guys, thanks much-
These big nut jobs are typically tough (ie-LPS1 soak and breaker bar req'd), or generally easy to remove? Looking for any pitfalls before I stumble into them.
Thanks again all-
Justin On Jun 13, 2016 1:33 PM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote: | Quote: | You really don't need a socket Justin. You can use a pair of channel lock pliers or as otherwise called, a metric adjustable channel lock pliers. Just remember though....the left main nut is a right hand thread and the right main nut is a LEFT hand thread.
Dennis
From: Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)>
Gents (and ladies)-
Ernie
Posted: Mon Jun 13, 2016 3:10 pm Post subject: main tire lock nut |
I have the same issue with my nuts
On Mon, Jun 13, 2016 at 6:50 PM, Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
Thanks again all-
Justin On Jun 13, 2016 1:33 PM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote: | Quote: | You really don't need a socket Justin. You can use a pair of channel lock pliers or as otherwise called, a metric adjustable channel lock pliers. Just remember though...the left main nut is a right hand thread and the right main nut is a LEFT hand thread.
Dennis
Gents (and ladies)-
Posted: Mon Jun 13, 2016 5:35 pm Post subject: main tire lock nut |
It should never be so tight that you have to use a breaker bar to loosen it.
To tighten, turn the nut until it stops. Do not gorilla tighten it. THEN back it off until the bolt hole lines up with the slot in the axel.
Dennis
On Jun 13, 2016, at 6:50 PM, Justin Drafts <draftsjust417(at)gmail.com (draftsjust417(at)gmail.com)> wrote:
Thanks again all-
Dennis
Gents (and ladies)-
Posted: Tue Jun 14, 2016 5:34 am Post subject: main tire lock nut |
Excellent, thanks Dennis!
J On Jun 13, 2016 5:37 PM, "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote: | Quote: | It should never be so tight that you have to use a breaker bar to loosen it.
Dennis
Thanks again all-
Dennis
Gents (and ladies)-
Viperdoc
Posted: Tue Jun 14, 2016 5:24 pm Post subject: main tire lock nut |
If tighter correctly, your fingers work fine.
Doc
Sent from my iPad
Gents (and ladies)-
_________________ Viperdoc |
