Posted: Tue Jun 21, 2016 8:22 am Post subject: Rv10 fuel tank issues |
This is surprisingly common. I think it has to do with outgassing either of the prose all or possibly the primer. Usually they don't leak fuel. If you pop the back of them with a needle, then heat them with a heat gun, they will shrink back up and will be almost invisible. The sooner you get them the less you can see them after hearing me up.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
On Jun 21, 2016, at 10:22 AM, Ed Godfrey <egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)> wrote:
| Quote: | Listers,
Has anyone experienced the bubbling of the paint around the rivet heads in the area of the fuel tanks? It does not look like other cases of leaking rivets that have been reported. The local paint shop ran into this and was trying to figure out what might be causing it. The plane was painted in 2010.
Ed Godfrey
40717
<mime-attachment.jpg>
