turbot
Posted: Fri Jun 24, 2016 9:03 am Post subject: Tow bar fit |
Im building a tow bar for a KF2
Should the brackets fit tight against the fuselage or have a gap & let the cross rods take the load ?
Am worried about the side mounts wearing the fabric.
peteohms
Posted: Fri Jun 24, 2016 10:19 am Post subject: Tow bar fit |
On Jun 24, 2016, at 12:02 PM, TURBO T <turbot(at)shaw.ca (turbot(at)shaw.ca)> wrote:
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
andynfultz(at)bellsouth.n Guest
Posted: Fri Jun 24, 2016 10:26 am Post subject: Tow bar fit |
The attach points on the fuselage should extend out past the fabric about 3/8" and should not allow the tow bar to come in contact with the fabric when attached.
Andy F
sourdostan(at)aol.com Guest
Posted: Fri Jun 24, 2016 1:21 pm Post subject: Tow bar fit |
I share your concern! My tow bar has just enough room on each side to insert a rubber isolator between the bar and fuselage.
Stan
Model 4 speedster
On 24 Jun 2016, at 11:02 am, TURBO T <turbot(at)shaw.ca (turbot(at)shaw.ca)> wrote:
rexinator
