yaknorway52(at)gmail.com Guest
Posted: Mon Jun 27, 2016 11:29 pm Post subject: Gear handle |
Hi,
Had my 52 on jack's solving an air leak in up position. Have a Small leak out of forward gear handle After gear is in up and locked.
Any suggestions?
Br
Havard
Norway
Sendt fra min iPhone
[quote] Den 28. jun. 2016 kl. 09.03 skrev Yak-List Digest Server <yak-list(at)matronics.com>:
Today's complete Yak-List Digest can also be found in either of the
of the Yak-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 16-06-27&Archive=Yak
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 16-06-27&Archive=Yak
Yak-List Digest Archive
Total Messages Posted Mon 06/27/16: 5
Today's Message Index:
1. 09:30 AM - Re: [Non-DoD Source] M-14P for sale (Bitterlich, Mark G CIV NAVAIR, WD)
2. 12:11 PM - Re: [Non-DoD Source] M-14P for sale (Ole Anders Andersen)
3. 12:42 PM - Re: [Non-DoD Source] M-14P for sale (Bitterlich, Mark G CIV NAVAIR, WD)
4. 12:43 PM - Re: [Non-DoD Source] M-14P for sale (Bitterlich, Mark G CIV NAVAIR, WD)
5. 02:40 PM - Re: Wanted "Nanchang Clock" (JON)
Time: 09:30:52 AM PST US
From: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil>
Subject: RE: [Non-DoD Source] M-14P for sale
An oil leak from where exactly please?
Mark
Posted: Tue Jun 28, 2016 4:14 am Post subject: Gear handle |
See if the problem also exists in the rear cockpit with the front gear selector in neutral and retracting the gear using the rear gear selector. If it still leaks, most likely one of the gear actuators is allowing air pressure to pass by the internal seals. If the problem goes away when you use the rear gear selector, then most likely you have a bad front gear selector.
The only way I know how to determine which actuator it is is to physically remove the B-Nut from the UP side of each actuator one at a time and listen for the air leaking from the gear selector. If it goes away, you've found the leaking actuator. The UP side of the actuator is the fitting closest to the chrome shaft which extends/retracts. It's a 90 degree elbow. You can also put a small amount of saliva on your finger tip and place your finger tip over the 90 degree fitting. If the actuator is leaking you'll feel the air on your finger tip.
One more thought...if you find one actuator leaking, you may want to overhaul all three because the other two actuators may not be far behind starting to leak. If it has been more than 5-7 years since they were overhauled, you may want to "bite the bullet" and just overhaul them and the shuttle valves at the same time.
Dennis
To: yak-list(at)matronics.com
Sent: Tuesday, June 28, 2016 3:27 AM
Subject: Yak-List: Gear handle
--> Yak-List message posted by: =?utf-8?Q?H=C3=A5vard_Dale?= <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)>
Hi,
Any suggestions?
Br
Havard
Norway
[quote] Den 28. jun. 2016 kl. 09.03 skrev Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)>:
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2016-06-27&Archive=Yak
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2016-06-27&Archive=Yak
From: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
Mark
Posted: Tue Jun 28, 2016 4:29 am Post subject: Gear handle |
Thanks Dennis,
I will do the check and report back:-)
Br
Havard
Den 28. jun. 2016 kl. 14.13 skrev A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)>:
[quote]See if the problem also exists in the rear cockpit with the front gear selector in neutral and retracting the gear using the rear gear selector. If it still leaks, most likely one of the gear actuators is allowing air pressure to pass by the internal seals. If the problem goes away when you use the rear gear selector, then most likely you have a bad front gear selector.
One more thought....if you find one actuator leaking, you may want to overhaul all three because the other two actuators may not be far behind starting to leak. If it has been more than 5-7 years since they were overhauled, you may want to "bite the bullet" and just overhaul them and the shuttle valves at the same time.
Dennis
From: Håvard Dale <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)>
Subject: Gear handle
Hi,
Any suggestions?
Br
Havard
Norway
HTML Version:
Text Version:
Mark
dougsappllc(at)gmail.com Guest
Posted: Tue Jun 28, 2016 10:51 am Post subject: Gear handle |
Havard,
Could be either actuators leaking back through the gear valve or the gear valve itself. If it's the actuators I do not carry Yak 52 actuators at this time. If it is the 3 port, or the 5 port valve we have them in stock.
Best check the actuators first.
Best,
Doug
On Tue, Jun 28, 2016 at 12:27 AM, Håvard Dale <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)> wrote:
[quote]--> Yak-List message posted by: =?utf-8?Q?H=C3=A5vard_Dale?= <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)>
Hi,
Any suggestions?
Br
Havard
Norway
> HTML Version:
> Text Version:
> Mark
Posted: Tue Jun 28, 2016 12:40 pm Post subject: Gear handle |
Thanks Doug,
I will check tomorrow hopefully.
Br
Havard
Den 28. jun. 2016 kl. 20.49 skrev doug sapp <dougsappllc(at)gmail.com (dougsappllc(at)gmail.com)>:
[quote]Havard,
Best,
Doug
Hi,
Any suggestions?
Br
Havard
Norway
> HTML Version:
> Text Version:
> Mark
Posted: Wed Jun 29, 2016 1:06 pm Post subject: Gear handle |
Hi,
After test today I conclude with leak in gear handle.
Neautral rear- up forward=very Small leak in forward handle
Neutral forward- up rear= no leak
Down position no leaks either way.
Then I Think my forward handle gives the leak and no internal leak in actuators?
Doug, Could you qoute me a new handle?
Yaknorway52(at)gmail.com (Yaknorway52(at)gmail.com)
Br
Havard
[quote]Havard,
Best,
Doug
Hi,
Any suggestions?
Br
Havard
Norway
> HTML Version:
> Text Version:
> Mark
Posted: Thu Jun 30, 2016 3:37 am Post subject: Gear handle |
I agree.
A word of caution Havard. First, you will have to reuse the fittings from the old gear selector, unless you purchase new fittings from Doug. If you are using the old fittings, take a photo of how the fittings are clocked (positioned) into the body of the gear selector. This is very important when you reinstall the fittings into the new gear selector. If you do not clock the fittings correctly, you will end up cross threading the B-Nuts on to the fitting. Most importantly, DO NOT attempt to unscrew the fittings from the body of the old gear selector without first heating the fitting at the base of the fitting where it screws into the body using a propane torch. Then SLOWLY unscrew the fitting. If you don't heat the fitting first, you will end up galling the threads of the fitting, making it unusable.
You may want to ask Doug if he has new fittings available. If yes, don't think twice about buying them.
Dennis
Sent: Wednesday, June 29, 2016 5:03 PM
Subject: Re: Gear handle
Hi,
Br
Havard
[quote]Havard,
Best,
Doug
On Tue, Jun 28, 2016 at 12:27 AM, Håvard Dale <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)> wrote:[quote]--> Yak-List message posted by: =?utf-8?Q?H=C3=A5vard_Dale?= <yaknorway52(at)gmail.com (yaknorway52(at)gmail.com)> Hi, Had my 52 on jack's solving an air leak in up position. Have a Small leak out of forward gear handle After gear is in up and locked. Any suggestions? Br Havard Norway Sendt fra min iPhone > Den 28. jun. 2016 kl. 09.03 skrev Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)>: > > * > > ========================= > Online Versions of Today's List Digest Archive > ========================= > > Today's complete Yak-List Digest can also be found in either of the > two Web Links listed below. The .html file includes the Digest formatted > in HTML for viewing with a web browser and features Hyperlinked Indexes > and Message Navigation. The .txt file includes the plain ASCII version > of the Yak-List Digest and can be viewed with a generic text editor > such as Notepad or with a web browser. > > HTML Version: > > mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> > Subject: RE: [Non-DoD Source] M-14P for sale > > An oil leak from where exactly please? > > Mark > > > --
Posted: Thu Jun 30, 2016 6:59 am Post subject: Gear handle |
Dennis/Havard,Yes I carry most all the fittings, also have a double ended flare fitting which is excellent when splicing a air line. We also now carry the new stainless steel air fittings and plugs for use in the new style stainless steel air tanks.
Best,
Doug
On Thu, Jun 30, 2016 at 3:51 AM, A. Dennis Savarese <dsavarese0812(at)bellsouth.net (dsavarese0812(at)bellsouth.net)> wrote:
[quote]I agree.
Dennis
Hi,
Br
Havard
[quote]Havard,
Best,
Doug
