fuselage center, f-623 rib question
tadsargent(at)bellsouth.n
PostPosted: Sat Jul 08, 2006 2:45 pm    Post subject: fuselage center, f-623 rib question Reply with quote
Charlie I can answer Bonus question 1. No step installed, no holed be
drilled. Weight is not that big of a deal if you install a 360CID Lycoming.
Bonus question 2. Yes enlarge the holes. It is amazing how much wiring
space is needed. Add this up. Manual trim cable, Tail strobe and Nav
light. Then if you put the ELT or Altitude hold.
As for the flange recheck the instruction or call Van's for help before you
cut anything off.
RV7A
TS "Stripes"
