Intermittent Battery Failure
Goto page 1, 2  Next
PostPosted: Wed Jul 20, 2016 4:37 pm    Post subject: Intermittent Battery Failure Reply with quote
The first symptoms appeared a couple of weeks ago. The Dynon D-180 rebooted during decent when the engine was idling. (My D-180 does not have a backup battery installed.) It happened again a few days later. My first thought was that the 6-year-old PC680 battery needed charging. But I dismissed that theory because the D-180 only needs 10 volts to operate. And the battery always cranked the engine fine. Back on the ground, the battery measured near 13 volts. Next theory: Maybe the D-180 is not working right?
I fully charged the battery, removed the charger, and waited a couple of days before measuring the battery voltage at 13. Just to rule out the battery, I decided to turn on the master switch and landing light (nothing else) and see how long the battery would last before running down. After turning on the master, I heard an intermittent clicking sound for a few seconds, then quiet. The landing light did not come on. Using the positive battery terminal as a reference point, the voltage on the master contactor small terminal was 4.5 volts. Maybe a defective master switch? No. The airframe also measured 4.5 volts. The negative battery terminal was also at 4.5 volts, but only for a couple of seconds. Then the landing light came on and the battery measured close to 13 volts. I left the landing light on for a half hour before shutting everything off. The battery measured 12.4 volts. Maybe there was a bad connection at the battery? I took the M6 battery bolts out and made sure the ring terminals were clean and put it all back together and charged the battery. The next day, everything worked and the battery was still close to 13 volts.
Then today I went into the +90 degree F hangar and turned on the master switch and landing light. Nothing. The battery voltage varied between 2 and 5 volts. The voltage must have gone above that for a few milliseconds because the contactor made a faint click noise periodically.
Of course I will buy a new PC680 battery. I thought the failure mode was unusual and decided to post about it here. Sometimes the battery was putting out 13 volts and sometimes less than 5 volts. Strange.
Joe Gores
PostPosted: Wed Jul 20, 2016 5:29 pm    Post subject: Intermittent Battery Failure Reply with quote
Please send me your old battery. I'll reimburse the postage.
We'll see what we can find out.
PO Box 130
Medicine Lodge, KS 67104
PostPosted: Wed Jul 20, 2016 5:34 pm    Post subject: Re: Intermittent Battery Failure Reply with quote
Does your PO Box accept heavy packages like a battery?
Joe
Joe Gores
stephencliverichards(at)g
PostPosted: Thu Jul 21, 2016 4:21 am    Post subject: Intermittent Battery Failure Reply with quote
If you have 4.5v from battery neg terminal to frame with a low load current you must have a high resistance in connection to battery, ground to framework, or in connecting cable or lugs
Clive
Sent: ‎21/‎07/‎2016 01:44
Subject: AeroElectric-List: Intermittent Battery Failure
I fully charged the battery, removed the charger, and waited a couple of days before measuring the battery voltage at 13. Just to rule out the battery, I decided to turn on the master switch and landing light (nothing else) and see how long the battery would last before running down. After turning on the master, I heard an intermittent clicking sound for a few seconds, then quiet. The landing light did not come on. Using the positive battery terminal as a reference point, the voltage on the master contactor small terminal was 4.5 volts. Maybe a defective master switch? No. The airframe also measured 4.5 volts. The negative battery terminal was also at 4.5 volts, but only for a couple of seconds. Then the landing light came on and the battery measured close to 13 volts. I left the landing light on for a half hour before shutting everything off. The battery measured 12.4 volts. Maybe there was a bad connection at the battery? I took the M6 battery bolts out and !
Joe Gores
http://forums.matronics.com/viewtopic.php?p=sp; - List Contributinbsp;   &=
PostPosted: Thu Jul 21, 2016 4:29 am    Post subject: Intermittent Battery Failure Reply with quote
At 08:34 PM 7/20/2016, you wrote:
Sure. There is a medium priority mail flat
rate box with inside dims 11 x 8.5 x 5.5
that should hold it.
PostPosted: Thu Jul 21, 2016 4:51 am    Post subject: Re: Intermittent Battery Failure Reply with quote
Clive
Clive, You overlooked the part of my post saying that the positive battery terminal was used as a reference point for the voltmeter tests.
But I appreciate you trying to help.
Joe Gores
PostPosted: Thu Jul 21, 2016 5:03 am    Post subject: Re: Intermittent Battery Failure Reply with quote
Bob, I had already boxed up the battery with 2" of Styrofoam all around it. The box is too big for your PO Box. Can I send it to your house instead? I have the address: 2*9 ***** Lane.
EDIT: Disregard the above. I will use flap rate mail to PO Box.
Before boxing it up, I checked the battery voltage once again. It varied between zero and 12.5. The problem seems to be getting worse. By the time it gets to you, it might be a completely open circuit. Do you still want me to send it? I do not know what you can do with it except to cut the case open. I know that you have many irons in the fire and hate to see you spend time and money for shipping.
Joe
Joe Gores
ceengland7(at)gmail.com
PostPosted: Thu Jul 21, 2016 5:28 am    Post subject: Intermittent Battery Failure Reply with quote
Occasional oversize items aren't normally an issue for USPS PO box subscribers. The clerk just leaves a key in the PO box to a parcel locker, where the package is placed. But...
It will likely be cheaper to re-box it in a 'flat rate' priority box like Bob described, than to pay even Standard Rate shipping on something heavy like a battery.
(USPS Operations Support Specialist in a previous life)
On Thu, Jul 21, 2016 at 8:04 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=458473#458473
rampil
PostPosted: Thu Jul 21, 2016 6:11 am    Post subject: Re: Intermittent Battery Failure Reply with quote
This sure sounds like a classic bad connection in your wiring plant.
Batteries do not generally fail in this manner with wild swings in output (unless it is a loose connection to multiple electrode plates internally).
When you put your VOM directly to the 680, was it simply by touching the leads to the contact bolt tops, or was it via an electrically secure connection?
OTOH, six years is pretty long in the tooth for a 680 in an aviation application. They are cycle-lifetime limited and will slowly reduce their charge holding capacity. I have changed out my Odessey 680 four times over the 12 years of service of my Europa.
Ira N224XS
PostPosted: Thu Jul 21, 2016 7:23 am    Post subject: Re: Intermittent Battery Failure Reply with quote
Thanks Charlie, I misread Bob's post and thought that he was giving the dimensions of his PO Box. I will use your suggestion.
Rampil, the problem can not be the aircraft wiring because I was measuring voltage directly between the battery terminals. Well actually on the 6mm stainless steel bolts that screw into the brass battery terminals.
Just to be 100 percent sure that I am not seeing things, I set the battery on my workbench and connected a 50W 12 volt lamp to it. The lamp lit up and the voltage dropped from 12.85 to 12.3 So now the battery is working fine. I know that some of you think that the problem could be in the aircraft. But the only thing that can make battery voltage drop is a very heavy load or short circuit. I doubt that is case because there was no heat or smoke or sparks.
I am going to hang onto the battery until after OSH, then do some more testing. The battery is not going back into the airplane.
Joe Gores
PostPosted: Thu Jul 21, 2016 8:38 am    Post subject: Intermittent Battery Failure Reply with quote
I don't have a mailbox. All mail to a street address
for me defaults to the box. If it's too big, it sits
behind the counter. Send it to the box. No sweat.
Education was never cheap . . . yeah . . . I'd like to
have it.
PostPosted: Thu Jul 21, 2016 8:40 am    Post subject: Intermittent Battery Failure Reply with quote
At 08:26 AM 7/21/2016, you wrote:
Occasional oversize items aren't normally an issue for USPS PO box subscribers. The clerk just leaves a key in the PO box to a parcel locker, where the package is placed.Â
But...
OH YEAH . . . use the flat rate box. There's no
'practical' weight limit on those boxes. It will
fit in the medium, top load box with a published
weight limit of 70 pounds.
PostPosted: Thu Jul 21, 2016 8:42 am    Post subject: Intermittent Battery Failure Reply with quote
Nonetheless, it would be very useful to get
cap/load test data on the battery after being
in service that long.
PostPosted: Thu Jul 21, 2016 9:34 am    Post subject: Intermittent Battery Failure Reply with quote
-------- Original message --------
Date:07/21/2016 10:23 AM (GMT-06:00)
Subject: AeroElectric-List: Re: Intermittent Battery Failure
Joe Gores
Measuring on the screws isn't the same as measuring on the terminals. The battery might be bad, but you're still including 2 extra junctions (failure points) in the measurement. I've seen situations where I had to scrape the terminal itself to get the meter probe to make good contact, so...
http://forums.matronics.com/viewtopic.php?p=458485#458485
_-============================================================
_-=          - The AeroElectric-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?AeroElectric-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=              - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-=   --> http://wiki.matronics.com
_-=             - List Contribution Web Site -
_-=  Thank you for your generous support!
_-=                              -Matt Dralle, List Admin.
_-=   --> http://www.matronics.com/contribution
PostPosted: Thu Jul 21, 2016 2:49 pm    Post subject: Re: Intermittent Battery Failure Reply with quote
OK Bob, I will ship the PC680 to you via USPS flat rate box.
This morning I had checked the battery on the workbench and it lit up a 50 watt lamp and the voltage was 12.3
Late this afternoon I did another test. I measured open circuit voltage of 12.8 VDC. Then I connected the 50W test lamp but it did not light up. The test lamp wires were clamped between the brass battery terminals and the M6 bolts and washers, albeit only finger tight, but tight enough to resist the wires pulling out. The terminals are clean, no corrosion. While the lamp was connected, I put a voltmeter on the bolt heads: 0.5 volts. While I was holding the meter probes on the bolts for several seconds, the lamp suddenly came on and the voltage went up to 12.4 volts. There was no intermittent external connection. Whatever the problem is, it is internal to the battery. The failure might be related to ambient temperature. It was cooler this morning and in the upper 80s this afternoon.
Joe Gores
PostPosted: Fri Jul 22, 2016 4:03 am    Post subject: Intermittent Battery Failure Reply with quote
Thanks!
PostPosted: Mon Jul 25, 2016 3:47 pm    Post subject: Re: Intermittent Battery Failure Reply with quote
I sent the battery along with a note. If the battery appears to be dead, wait and check it again the next day. Or apply pressure to the front and back side of the case. There seems to be an intermittent internal open circuit.
Joe Gores
PostPosted: Mon Jul 25, 2016 4:26 pm    Post subject: Intermittent Battery Failure Reply with quote
At 06:47 PM 7/25/2016, you wrote:
Joe Gores
Just picked it up today. Need to clear another
battery project off the bench tomorrow and I'll
get yours out to look at. thanks for the heads-up.
PostPosted: Tue Jul 26, 2016 12:05 pm    Post subject: Intermittent Battery Failure Reply with quote
It didn't want to 'work' out of the box.
I'll let it set for awhile. I was hoping
to evaluate the state-of-the-chemistry
but perhaps the stresses of shipping were
too much. I'm imagining an internal weld
fracture. We'll massage it a bit before
I cut the case open.
PostPosted: Wed Jul 27, 2016 4:02 pm    Post subject: Re: Intermittent Battery Failure Reply with quote
You might try cooling the battery. If that does not bring it to life, try some gentle pounding with your fists.
Joe Gores
Goto page 1, 2  Next
Page 1 of 2
