Herbgh(at)nctc.com Guest
Posted: Fri Jul 22, 2016 4:42 am Post subject: Voltage regulator |
What I get for not paying attention...too poor I guess...or too old..
Between the HKS list and the Kolb list ...i got off track....
Bottom line...sure would like to know why the ign enabling? line
comes from the regulator...? goes to?
Larry...your engine runs with no charge voltage? Herb
lcottrell
Posted: Fri Jul 22, 2016 5:00 am Post subject: Voltage regulator |
Yes it does. I have been told that the engine system and the charging system is different. Don't ask me to go into specifics. I do know that it keeps on running without a charge going to the battery.
I have ordered a replacement, be here Tuesday.
Larry
On Fri, Jul 22, 2016 at 6:41 AM, Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:
| Quote: | --> Kolb-List message posted by: Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)>
Bottom line...sure would like to know why the ign enabling? line comes from the regulator...? goes to?
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
The older I get, the less tolerant I am of those who are intolerant of others.
Posted: Fri Jul 22, 2016 5:38 am Post subject: Voltage regulator |
$44.88 and free shipping. What did the HKS distributor ask for one? Herb
On 07/22/2016 07:59 AM, Larry Cottrell wrote:
| Quote: | Larry...your engine runs with no charge voltage? Herb
Larry
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny."
Aristotle |
Posted: Fri Jul 22, 2016 5:59 am Post subject: Voltage regulator |
Kolbers:
The info below was obtained from Green Sky Adventures web site. Seems the HKS has a single charge system. If the alternator fails, better have a good battery.
The Rotax 912 uses two separate systems, one for charge and one for ignition.
Is it true: If the battery dies the engine will quit?
The HKS uses a DC CDI. This type of ignition allows a full advance curve, without which the engine would be very mediocre in most respects. It must have 12 volts DC from an outside source to start. Once running, a dead battery will not affect engine operation because the integral alternator will provide power for ignition. The concern, then becomes one of wiring. Output from the charging system needs to be on the line side of the circuit which powers ignition. This way, regardless of battery, cable, or master switch condition, primary power is uninterrupted. In the event of a charging system failure, ignition is dependent on battery.
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Larry Cottrell
Sent: Friday, July 22, 2016 8:00 AM
Subject: Re: Voltage regulator
Larry
FORUMS -
WIKI -
b Site -
_________________ John Hauck
Titus, Alabama |
lcottrell
Posted: Fri Jul 22, 2016 7:51 am Post subject: Voltage regulator |
Actually the one that I bought off Amazon was $104. with two day shipping. Might be more than I could get other places, but it all works out, and speed is more important to me.Larry
On Fri, Jul 22, 2016 at 7:38 AM, Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:
Larry
| Quote: | --
Aristotle |
Posted: Fri Jul 22, 2016 3:27 pm Post subject: Voltage regulator |
The 44.88 one was on Amazon also...Free shipping as I recall...Herb
On 07/22/2016 10:49 AM, Larry Cottrell wrote:
| Quote: | Actually the one that I bought off Amazon was $104. with two day shipping. Might be more than I could get other places, but it all works out, and speed is more important to me. Larry
Larry
| Quote: | --
Aristotle |
Aristotle |
lcottrell
Posted: Fri Jul 22, 2016 3:34 pm Post subject: Voltage regulator |
Its only money- sigh!Larry
On Fri, Jul 22, 2016 at 5:24 PM, Herb <Herbgh(at)nctc.com (Herbgh(at)nctc.com)> wrote:
Larry
| Quote: | --
Aristotle |
| Quote: | --
Aristotle |
lcottrell
Posted: Fri Jul 22, 2016 10:11 pm Post subject: Voltage regulator |
I checked and the proposed delivery date was aug to sept. I cancelled that and ordered the $48.00 one. It will get here sooner. :-/
Larry
brubakermal(at)yahoo.com Guest
Posted: Sun Jul 24, 2016 5:55 pm Post subject: Voltage regulator |
Cool herb you hit the ground running were in Indiana tonight
Sent from Yahoo Mail on Android
| Quote: | On Sun, Jul 24, 2016 at 1:50 PM, Herb
<Herbgh(at)nctc.com> wrote:
My S-14 arrived today...with the HKS-700E engine
Looking at the engine schematic...the 5 wire voltage reg does not have a wire that goes to the CDI boxes..! 3 wires are white and see the three Phase ac voltage... the Cdi boxes have two wires coming from the accessory case and are likely magnetic pickups... 180 degs apart for the two cylinders or could be two pickups for each cyl.. one full adv and one starting and low rpm? ... If single coil they must be set to max advance and the CDI box adds the delay for starting and low rpm operation...? To me...this means that a lot of motorcycle cdi's should work...? Most scooters work similarly... 10 dollar cdi box beats whatever HKS wants... ..whether I would use a Chinese one??? Not likely... I have had two bail on my scooter.. Betting Yamaha has a reasonable replacement?
Herb On 07/23/2016 01:10 AM, Larry Cottrell wrote:
| Quote: | I checked and the proposed delivery date was aug to sept. I cancelled that and ordered the $48.00 one. It will get here sooner. :-/
Larry
| Quote: | --
Aristotle |
Posted: Sun Jul 24, 2016 6:31 pm Post subject: Voltage regulator |
Safe trip home...
Off track a bit?/ Herb
On 07/24/2016 08:53 PM, Malcolm Brubaker wrote:
| Quote: | Cool herb you hit the ground running were in Indiana tonight
Larry
| Quote: | --
Aristotle |
Aristotle |
