Fwd: Re: Cooling issues XS 914 on the ground
Goto page 1, 2, 3  Next
davidjoyce(at)doctors.org
PostPosted: Thu Jul 28, 2016 3:22 am    Post subject: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Roland, I had endless problems with overheating with my 914/XS. Going to LAA Rally was a nightmare, because sitting in a queue to take off always led to overheating, needing me to pull out of the queue and shut down. I then had a Woodcomp SR2000 which is a low twist prop, very much like a Warp Drive one or pretty much any prop you see on a Rotax 91X. The problem is that at idling speeds the central part of the prop is in Beta mode, effectively diverting air from the cooling inlets. When I switched to a Woodcomp SR3000W the problem was abolished completely, quite apart from gaining an appreciable amount of performance (equivalent to an extra 7 horse power). I can now sit in a queue all day if needs be!
I tried to attach the paper documenting a detailed comparison of performance with the two props, which appeared in the Europa mag some years back, but the list rejected it. However if you google, 'Does Propeller Twist matter' it comes up top of the options
Regards, David Joyce, G-XSDJ
On 2016-07-28 11:22, Roland wrote:
--> Europa-List message posted by: "Roland" <schmidtroland(at)web.de (schmidtroland(at)web.de)>
Hello,
I have the conventional XS cowling with the 914 and overheating might occur on the ground in high OAT's (25-30°C). I've shut down the engine once when reaching 118°C and then I could hear the 50/50 antifreeze boiling lightly. Does anyone know roughly the temperature gap between the CHT/CT (I only have a CHT gauge)?
I've read on another forum, that increasing to 2700RPM (and switch to a courser pitch?) brings down the temperature. I also have a water Thermostate installed, which I'll remove in a first step to lower the CHT-temperatures on the ground and increase the time until I have to shut down the engine (when reaching 115°C CHT). With this measure I (hopefully) increase the oil temperature at the same time (oil cooler partly covered by Radiator) so that I can taxi and take off earlier, since I don't have to wait for the oil to warm. Same goes after landing regarding the cooling run for the Turbo, when the CHT is creeping up quickly.
What are your experiences especially without water Thermostate on the ground in high temperatures / measures to avoid overheating?
I want to start with simple things before modifying the cooling tunnel, because I "only" have issues on the ground and quite satisfying setup for flying. Also modifications often end in a never ending story and often the only practical solution might be the best compromise...
The cooling of the XS is only sufficient for English summers I'm afraid Smile
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=458822#458822
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.com
.matronics.com/contribution
rampil
PostPosted: Thu Jul 28, 2016 5:33 am    Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
I believe the consensus on this forum and from hanging out with Europanauts
for many years has been that the 914 requires modification of the cowl and baffling to reduce the prevalent overheating issues at low airspeed and high OAT.
I believe Bud Yerly has extensive experience with these modifications.
Ira N224XS
Roland
PostPosted: Thu Jul 28, 2016 6:18 am    Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Hi David and Ira,
I guess you are both right, but achieved cooling-improvement on different ways.
David, I well remember our chat on the Europa AGM last year but have to admit, that I thought of something cheaper than a new propeller. I even would consider this, when it would be "only" the money provided it's a reliable solution. But since my Europa is on the Dutch register, I'd expect considerable paperwork with the authorities going along with additional costs. However additional performance is also tempting Smile
Ira, yes - Bud Yerly has huge knowledge of the Europa cooling modifications and I know his comprehensive article. Since I can't do much myself and cannot bring my Europa to his shop, I have to stick to more or less easy solutions like removing the thermostate first.
I have already modified the airflow in the tunnel with an aluminum sheet to force more air through the radiator and the result is quite good when airborn in all kind of OATs even in extensive climbs at MTOM. On the other hand I know of conventional installations (XS-cowling and 914) like the one of Tim Weert from Holland, who seems to have no cooling issues. The cooling-problem in my Europa is either not dramatic, since I can run the engine for >10 minutes from start up until take off in 28°C (and that is with a coolant thermostate which pushes the temperatures quick to 85°C). It's rather the situations like sitting behind a queue at the holding position - like David described it - when it becomes uncomfortable with one eye always on the CHT-gauge. At the AERO fare in Friedrichshafen I positioned my Europa 3 meters behind a Cirrus SR 22 to keep the CHT at 115°C.
I'll remove the thermostate first....
Anyway thanks for your advice!
Roland
PH-ZTI
XS TG 914
trevpond(at)aol.com
PostPosted: Thu Jul 28, 2016 8:58 am    Post subject: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Hi
Neville Eyre's cowling a make the engine run a lot cooler on the ground. Give him a ring and I'm sure he will be pleased to discuss.
When OAT is high I always taxi my 914 Eoropa with coarse pitch set - it certainly helps.
Trev
G-LINN
On 28 Jul 2016, at 15:18, Roland <schmidtroland(at)web.de> wrote:
Hi David and Ira,
David, I well remember our chat on the Europa AGM last year but have to admit, that I thought of something cheaper than a new Propeller. I even would consider this, when it would be "only" the money provided it's a reliable solution. But since my Europa is on the Dutch Register, I'd expect considerable paperwork with the authorities going along with additional costs. However additional performance is also tempting Smile
Ira, yes - Bud Yerly has huge knowledge of the Europa cooling modifications and I know his comprehensive article. Since I can't do much myself and cannot bring my Europa to his shop, I have to stick to more or less easy solutions like removing the Thermostate first.
I have already modified the airflow in the tunnel with an aluminum sheet to force more air through the Radiator and the result is quite good when airborn in all kind of OATs even in extensive climbs at MTOM. On the other hand I know of conventional installations (XS-cowling and 914) like the one of Tim Weert from Holland, who seems to have no cooling issues. The cooling-problem in my Europa is either not dramatic, since I can run the engine for >10 minutes from start up until take off in 28°C (and that is with a coolant Thermostate which pushes the temperatures quick to 85°C). It's rather the situations like sitting behind a queue at the holding position - like David described it - when it becomes uncomfortable with one eye always on the CHT-gauge. At the AERO fare in Friedrichshafen I positioned my Europa 3 meters behind a Cirrus SR 22 to Keep the CHT at 115°C.
I'll remove the Thermostate first....
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=458828#458828
zwakie
PostPosted: Thu Jul 28, 2016 2:20 pm    Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Hi Roland,
Roland wrote:
...that I thought of something cheaper than a new propeller. I even would consider this, when it would be "only" the money provided it's a reliable solution. But since my Europa is on the Dutch register, I'd expect considerable paperwork with the authorities going along with additional costs.
This might be easier than you might think: if I remember correctly, PH-DIY has this engine/prop combination (2-blade version I think).
Roland wrote:
...I have to stick to more or less easy solutions like removing the thermostate first.
How is removing the water thermostat going to help? With CT over 85C it's wide open, isn't it? With CHT's way up high, it is fair to assume that CT is well above 85C. I would not expect you're getting more coolant to flow by removing the thermostat and don't see how this is going to help you to bring the CHT's down...
One option you could consider, but only worthwhile looking at if you your oil-temps are 'well below' red-line: an oil-water heat exchanger. This would allow you to use the excess cooling capacity of your oil radiator to bring down CHT indirectly (additional benefit of this approach a.o. is your oil temp will be above 50C quicker after startup)
Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR
PostPosted: Thu Jul 28, 2016 11:17 pm    Post subject: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Roland, I would not for a moment knock the benefits of having better designed cowlings and internal cooling air flow arrangements. If I were starting again I would go down that course as well as having a high twist prop. The most impressive cowling design I have come across is the beautiful one Nigel Graham has produced for his Callisto Europa variant. However as a fix, a high twist prop seems comparitively cheap and easy (Dutch authorities apart!) and has the added benefit of improved performance.
For interest I have worked out the 'natural air flow rate' past the tip and 1/3 radius points of my two props when they are idling in fine pitch at 1700 engine rpm:
Low twist tip (31 deg) 69kts   1/3 R (43 deg) 35.7 kts
High twist Tip (23 deg) 49kts   1/3 R (49 deg) 44.2kts
You will see that the low rwist blade is trying to produce an airflow at its tip almost twice that at its inner part, whereas the flow on the high twist blade is relatively unifofm along its length. I am not an aerodynamicist, so cannot say just what effect that might have, but would be surprised if it does not result in a significant diversion of air flow out from the central portion which of course contains the colling air inlets. These figures are for the Woodcomp props, but Warp Drive and other low twist blades must provide very similar results.
Regards, David Joyce, GXSDJ
On 2016-07-28 23:20, zwakie wrote:
--> Europa-List message posted by: "zwakie" <mz(at)cariama.nl (mz(at)cariama.nl)>
Hi Roland,
Roland wrote:...that I thought of something cheaper than a new propeller. I even would consider this, when it would be "only" the money provided it's a reliable solution. But since my Europa is on the Dutch register, I'd expect considerable paperwork with the authorities going along with additional costs.This might be easier than you might think: if I remember correctly, PH-DIY has this engine/prop combination (2-blade version I think).
Roland wrote:...I have to stick to more or less easy solutions like removing the thermostate first.How is removing the water thermostat going to help? With CT temps over 85C it's wide open, isn't it? With CHT's way up high, it is fair to assume that CT temps are well above 85C. I would not expect you're getting more coolant to flow by removing the thermostat and don't see how this is going to help you to bring the CHT's down...
Marcel Zwakenberg
http://forums.matronics.com/viewtopic.php?p=458847#458847
ics.com
.com
Roland
PostPosted: Fri Jul 29, 2016 1:41 am    Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Hello Marcel,
removing the thermostat brings the benefit, that I can taxi earlier (with much lower CHTs) after engine start, because the radiator, which will then warm up immediately also warms the oil cooler, that is mounted behind it - so I shorten the time waiting for the oil temps to rise. Now I have >50°C CHT when I start taxi with the oil at 30°C.
The same at the holding position, where I expect the CHTs to be close to the oil temperatures. When I'm ready for departure with 75°C oil/water temps, I have a margin of 40°C until I'd have to shut down at 115°C. That's also quite some time.
The oil/water exchanger is generally a brilliant idea, but only with ample cooling reserves, which I don't have unfortunately.
As for the efforts with the Dutch CAA - there isn't a Europa Trigear flying with the Woodcomp SR 3000 W AFAIK (Frans Feldmann has the 2-bladed). For the "glijkstelling" this is required IIRC. And the MTOM has to be 656 kg as well. However I also think it's doable with the ILENT...
David, I've read your interesting article now and it seems the biggest benefit is in cooling rather than performance, although I wouldn't sniff at a couple of knots either. I asked my Dutch mechanic, who is also a Woodcomp dealer and he estimated the Price in the region of 4500 EUR, but will check the exact price for me (anyone want an Airmaster for 4000 EUR Wink ?
A Belgian Europa friend has mounted a cooling flap in the lower cowling in front of the Radiator which also works pretty well he says.
He also recommended this cooling fluid http://www.sm-sport.de/Oele-Pflege/Sonstiges/Denicol-Sub-Zero-Water-Cooler-2-Liter-Kuehlfluessigkeit.htm?SessionId=&a=article&ProdNr=D180-1432&p=601 , which also seems to drop the temperatures a bit.
Many food for thought - thanks again friends!
Roland
PH-ZTI
XS TG 914
kheindl(at)msn.com
PostPosted: Fri Jul 29, 2016 2:10 am    Post subject: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Roland,
A couple of notes about Woodcomp. Frans Veldman has the long bladed SR3000/2W, the
same as my own ( I was the first to use one). It necessitates the raising of the nose gear
by 50 mm, a fairly simple and inexpensive mod. Mine also has the feathering (glijkstelling?)
option.
I have no idea which control instruments would be available, because Smartavionics no
longer supply theirs. The original dual instrument from Woodcomp did not work for me
at all.
Karl
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of Roland <schmidtroland(at)web.de>
Sent: 29 July 2016 10:41:42
Subject: Fwd: Re: Cooling issues XS 914 on the ground
--> Europa-List message posted by: "Roland" <schmidtroland(at)web.de>
Hello Marcel,
David, I've read your interesting article now and it seems the biggest benefit is in cooling rather than performance, although I wouldn't sniff at a couple of knots either. I asked my Dutch mechanic, who is also a Woodcomp dealer and he estimated the Price in the region of 4500 EUR, but will check the exect Price for me (anyone want an Airmster for 4000 EUR Wink ?
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=458862#458862
st Email Forum -
pa-List">http://www.matronics.com/Navigator?Europa-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
p; - NEW MATRONICS LIST WIKI -
matronics.com
p;   -Matt Dralle, List Admin.
Roland
PostPosted: Fri Jul 29, 2016 2:40 am    Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Hello Karl,
I was envious of the design of Frans's and Ilona's (BTW where are they??) cooling tunnel, which can be lowered completely into the airflow. From what I've read about the Woodcomp Prop I now suspect it's the main contributer to the cooling efficiency of their plane. On the other hand I remember, that Frans had a lot of head scratching due to cooling issues despite using the Woodcomp in the beginning of the flight testing of PH-DIY. He admired the guys in the Dimona TTC doing airtows in hot weather all day long.
To be fair, I'm generally very satisfied with the Airmaster and Martin is great in supporting if any problems come up. Also the controller is trouble free in operation (I have the full feather option as well). With the Warp Drive blades you can mowe the high grass at the airfield Smile
Airmaster also provide new Whirlwind blades, which can be used on the AP332 hub with some modifications. But I don't know their contribution to airflow/cooling yet, only heard that they also add some knots to Speed.
Roland
PH-ZTI
XS TG 914
PostPosted: Fri Jul 29, 2016 3:41 am    Post subject: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Roland, It was actually a 4kt gain in top speed at various altitudes, equivalent to an extra 7.5 horse power. William Mills did comparable direct comparisons in his 912 Classic and also gained 4kts top speed with improvements in fuel consumption & climb performance. I believe, by the way, that the latest Woodcomp controller is a good design, very much up to the Smart Avionics one.
Hello Marcel,
Roland
PH-ZTI
XS TG 914
ics.com
.com
zwakie
PostPosted: Fri Jul 29, 2016 11:45 am    Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Hi Roland,
Thanks for your explanation. I can follow your reasoning, but to me this approach of taking out the water thermostat sounds like fighting symptoms instead of root cause, right?
Roland wrote:
... Frans's and Ilona's (BTW where are they??)...
Last thing I heard is that they are doing a sailing trip around the world, I was told hey have been away from home for over a year now...
Roland wrote:
...On the other hand I remember, that Frans had a lot of head scratching due to cooling issues despite using the Woodcomp in the beginning of the flight testing of PH-DIY. ..
Yes indeed, they have been changing things over quite a lot initially. I don't remember it's current state, but at one point the original oil cooler was taken out, and replaced with a smaller oil cooler on a dedicated NACA-inlet (not in tandem with the water cooler), dumping the air into the cowling itself. On top of that an oil-water heat exchanger and a cowl-flap. Built to very high standards and very cool looking, but most importantly: this setup worked a treat...
Marcel Zwakenberg
frans(at)privatepilots.nl
PostPosted: Fri Jul 29, 2016 5:26 pm    Post subject: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Just a few notes:
After a lot testing it became obvious that the whole single problem of
the Europa cooling is that the radiator is way too thick, so air won't
flow easily through it. (It is NOT a cylinder wall cooling problem
like some people seem to think. Although you could get a little bit
more margin by blowing more air over the engine, it is not an
efficient solution. It is like driving your car with a clogged
radiator, and then discovering if you leave off the hood that it will
improve the situation a bit. It works, but it is not the correct way
to do it).
This became quite obvious when I observed the Dimona's towing gliders
at my homefield, they have exactly the same engine but tow gliders
during a hot day with full power climbs at low airspeeds, without any
problems.
After going through the whole process of lowering the oil radiator,
widening the dog house exit, making more holes in the cowling, I had
still not a very good cooling.
All problems were immediately solved when I kicked out the old coolant
radiator and replaced it with a thin radiator just like they use in
Dimona's and other commercial Rotax driven aircraft.
So, what I did was:
1) Close the two "eyes" in front of the cowling. They don't serve any
purpose. Also close the "gills".
2) Put a thin radiator in the "belly" of the cowling. The air exiting
the radiator is dumped "as is" into the cowling, and aimed at the
bottom of the engine (and exhaust tubes and damper). It helps cooling
the bottom of the engine where the oil collects and of course it also
helps if the heat from the exhaust is blown away before it can heat up
the engine bay.
3) Cooling the oil is done with a heat exchanger where the oil heat is
transferred to the coolant. This has several benefits:
a) The oil temperature will be slightly warmer than the coolant,
exactly what you want.
b) The oil will be warmed up more quickly when you start the engine.
c) If you get the coolant temp right, the oil temp will be right as well.
d) It doesn't need any airflow, the whole setup is straigtforward.
4) I took away the doghouse and cowling exit and replaced it by an
almost level flap. Typically during flight the underside of the flap
is only 1cm(!) lower than the rest of the airplane. That's right, the
cooling is now so efficient that you don't need the doghouse at all
but just a sleek 1cm "doghouse" is sufficient.
5) I rerouted the exhaust through a "tunnel" ending short of the end
of the tunnel. This will create a ventury which will suck air through
the tunnel. I never tested this but it is assumed that this will help
the airflow through the cowling and it also lowers the drag of the
exhaust.
The result:
1) Enough cooling for any circumstances. Cooling is no longer an
issue. I can idle the engine unlimited time while on a mediterran hot
tarmac with temperatures around 40C. I can climb at full power with 60
knots airspeed as long as I want. There are no cooling problems at all
anymore.
2) Way less drag. The doghouse is gone, with its associated vacuum
hole and turbulent air dragging behind it. Less air is spilled for
cooling, so less air is disturbed. I estimate that I gained around 8
knots of speed by this conversion.
So you can have the 2-bladed prop because I (Dutch) have it already. A
2-blade prop is more efficient than a 3-blade prop, just like a single
plane aircraft is faster than a bi-plane. Leading edge is costly. The
less "leading edge" you have racing around bumping air molecules away,
the less drag. I did not find any disadvantages of having a two blade
prop, although it is said that carb balancing is more important. I
keep my carbs balanced anyway so for me it is no issue. Oh and it
saves some 4 Kg of gyroscoping weight at the nose.
Because the two bladed prop is a little bit longer, I extended the
nose gear 5cm to restore the ground clearance, but probably it is not
really necessary.
I would have invited you for a look at the PH-DIY, but I'm sailing
around the world (I'm currently in Tahiti).
Frans
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.22 (GNU/Linux)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=AVki
-----END PGP SIGNATURE-----
Remi Guerner
PostPosted: Sat Jul 30, 2016 2:51 am    Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Hi David,
I agree 100% with you about the effect of high twist blades on ground cooling and the possible improvement of the cruise performances, but I am puzzled by your figures.
Your figures for the Woodcomp low twist prop suggest these blades are very far from being suitable for this engine (914) as they need to be set at an incredibly high angle to transmit the power. It is very likely that the blades are fully stalled during the early take off phase, therefore reducing the take off performance. It is even possible that they are partially stalled (at the tip) at cruise.
My point is: if you start from a very bad prop, almost any other prop you try will show a significant performance improvement. It would be very interested to find out how the performances of your Woodcomp high twist prop compare with those of the Airmaster/Warp Drive.
Remi
Burrilla
PostPosted: Sat Jul 30, 2016 3:45 am    Post subject: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Has anyone experimented with putting an electric driven fan on the radiators i.e. a computer cooling fan?
The Skyarrow has one fitted for use during taxi etc to aid cooling and it is then switched off before takeoff.
Alan
GOBJT
PostPosted: Sat Jul 30, 2016 4:28 am    Post subject: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Remi, I agree that it would be great to have definitive trials of the whole range of props. Europa at one stage promised this but never came up with the goods. I would be very surprised if the Sr 2000 is a 'bad prop'. I first became interested in it when I saw Tom Justic's 914/SR2000 /XS take off together with th company 914/Airmaster/XS at Benezov during the 2000 Prague Fly out. Tom's plane climbed at an angle that looked to be 10 degrees steeper, whilst keeping up in a horizontal sense. During the years I flew one I never had problems keeping up with rivals. The tip angles were adjusted in both cases to give a max static of 5650 rpm.
Regards, David
On 2016-07-30 11:51, Remi Guerner wrote:
--> Europa-List message posted by: "Remi Guerner" <air.guerner(at)orange.fr (air.guerner(at)orange.fr)>
Hi David,
Remi
http://forums.matronics.com/viewtopic.php?p=458908#458908
ics.com
.com
Roland
PostPosted: Sat Jul 30, 2016 12:04 pm    Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Hello Marcel, all,
yes - I'm fighting symptoms and of course I know, that it would be better to rather fix the source of the problems thoroughly instead, which obviously is, what Frans did (Frans - thanks a lot for your far-reaching explanations, your offer to have a look and btw good to know you're well off Smile.
I've learned, that most live with the cooling shortcomings of the Europa somehow or investigated and found their own ways to cure it (like David Joyce, who left it all like it is and changed to another propeller). At least I've read about and also saw many interesting solutions. Bud Yerly in Florida did something different than Frans who did it different than Neville Eyre.....
What I forgot to tell you, but what is most important for the whole discussion: I didn't build my Europa but bought it second hand. Those who found the best solutions are also builders or even worked at Europa Aircraft or have a shop, like Bud. What Frans and Ilona achieved or Bud Yerly does for his customers is way beyond my skills.
So I came to the conclusion, that I have to buy a Woodcomp, SR 3000 W, which seems to be an adequate fix for the cooling problem and adds a tad to the performance as well (since I want to keep the rest of the setup as it is, like David did, I'd also chose the 3-bladed and not the 2-bladed for that reason) or I make a flap in front of the cooler, like a friend in Belgium did it at his XS Mono 912S. Another option might be the new Whirlwind blades with a wider chord in the Airmaster hup http://www.airmasterpropellers.com/products/productdescription/type/view/id/67/ww-r64w, but I don't know yet if this is sufficient, since they are comparatively new. Obviously this would be much cheaper than a new Woodcomp with Controller.
At least my "only" cooling problem is SOLELY ON THE GROUND and in a couple of years, even though running the engine with a thermostat I never actually had to shut down the engine due to overheating. So I have to focus on that problem during ground operation.
Anyway thanks again to all for your input - much appreciated!!
Roland
PH-ZTI
XS TG 914
grahamsingleton(at)btinte
PostPosted: Sun Jul 31, 2016 3:11 am    Post subject: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Ask who has experience with the Whirlwind blades, David Joyce has recently fitted them but not done much flying yet, (approval issues with the LAA)
They look and sound very nice, much less harsh than the Warp Drive blades.
btw 3 blades will be smoother than 2, (which is why 2 blade windmills fail much sooner than 3 blade ones)
Graham
Hello Marcel, all,
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=458929#458929
a href="http://www.matronics.com/Navigator?Europa-List" target="_blank"bsp; -Matt Dralle, List Admin.<br======
Roland
PostPosted: Sun Jul 31, 2016 6:29 am    Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
I'll check the Whirlwind option as well. The performance improvement seems to be quite similar to the Woodcomp. Unfortunately they are not plug and play and some modifications to the hub/rootes are necessary. I spoke to Martin from Airmaster at the AERO fare.
Good thing is, that the LAA doesn't have me over a barrel any longer, since my Europa is Dutch registered now Smile
Roland
PH-ZTI
XS TG 914
Roland
PostPosted: Sun Jul 31, 2016 10:01 am    Post subject: Re: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
David, why are you testing the Whirlwind blades? You wrote, that you are satisfied with the Woodcomp. Anyway I would be very interested in the results, especially how/if they improve cooling, since you have a similar setup (I guess there's not such a big difference between Mono and Trigear).
Roland
PH-ZTI
XS TG 914
PostPosted: Sun Jul 31, 2016 10:17 am    Post subject: Fwd: Re: Cooling issues XS 914 on the ground Reply with quote
Roland, There are two David Joyces and I suspect it must be the other one!
David Joyce, GXSDJ
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=458979#458979
ics.com
.com
Page 1 of 3
