Posted: Tue Aug 02, 2016 7:47 am Post subject: Dynon Pitot AOA placement |
I did not research this on the forum before closing my wings - I thought that I would simply place the Dynon Pitot in the same place as the Europa original.
I have received the dynon and it has a larger surface area that the europa item and therefore will exert more stress on the mounting point. it also has a larger "footprint"
So the options I see are:
- Putting the dynon in the same place as the Europa pitot but with some reinforcement ont he outside. I am assuming that if the europa pitot works in that position then the dynon should work too.
- Making a new hole which I am loath to do.
- I saw various options on the forum history including mounting the dynon on the wing inspection cover. Has anyone done this?
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
erichdtrombley(at)juno.co Guest
Posted: Fri Aug 05, 2016 2:57 pm Post subject: Dynon Pitot AOA placement |
Hi Will,
You didn't mention which mounting mast you using, only that you have the Dynon Pitot. Which mast you have will determine options.
Erich Trombley
914 Mono Classic
William wrote
"I did not research this on the forum before closing my wings - I thought that I would simply place the Dynon Pitot in the same place as the Europa original.
What Happens When You Take a Testosterone Supplement
If you're like most guys, you love having energy, being able to have a ...
http://thirdpartyoffers.juno.com/TGL3132/57a5197929b3019790bf9st01vuc
rampil
Posted: Sat Aug 06, 2016 7:09 am Post subject: Re: Dynon Pitot AOA placement |
Generically speaking, a larger surface mount area implies a lower stress than a smaller area (Force per square inch and all). In the States, an extra ply or two of BID applied through the mounting hole would cover the new screw holes. What the UK requires, I can not begin to comment on.
Posted: Thu Aug 11, 2016 11:23 am Post subject: Dynon Pitot AOA placement |
Ira thanks
Im sure there wont be a problem in colombia with this
Will
On Aug 6, 2016 10:12, "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote: | Quote: | --> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=459264#459264
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
Posted: Thu Aug 11, 2016 11:24 am Post subject: Dynon Pitot AOA placement |
Eric
Im using the half mast as opposed to just the probe....if that makes sense
Will
On Aug 5, 2016 7:02 PM, "Erich Trombley" <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)> wrote:
> Erich Trombley
> 914 Mono Classic
