Skipping the Endurance Bus
art(at)zemon.name
PostPosted: Sun Aug 07, 2016 6:37 am    Post subject: Skipping the Endurance Bus Reply with quote
Folks,
Please double-check my logic. I am designing the electrical system for my BD-4C, which is a largely mechanical airplane. Totaling up the typical current draw for everything except pitot heat, I am at 21 amps. Max draw is 28 amps. Since a B&C backup alternator can supply 30 amps at cruise RPM, it seems that I don't need an endurance bus at all. Instead, I would have the following emergency procedure:
In Case of Alternator Failure
  1. Primary alternator OFF
  2. Backup alternator ON
  3. Pitot heat OFF (unless required for flight)
I do still need to add a couple of items to my equipment list but neither draws much current: electronic ignition and a second com radio.
Does this make sense? Am I missing something?
    -- Art Z.
http://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
donjohnston
PostPosted: Sun Aug 07, 2016 2:51 pm    Post subject: Re: Skipping the Endurance Bus Reply with quote
That's the logic I used.
Primary alternator, secondary alternator (20a), battery.
My final backup is my iPad with Foreflight connected to a Stratus II that should be able to run for at least five hours.
If I have failures on all of those then someone up there really doesn't like me.
ceengland7(at)gmail.com
PostPosted: Sun Aug 07, 2016 4:51 pm    Post subject: Skipping the Endurance Bus Reply with quote
On 8/7/2016 9:36 AM, Art Zemon wrote:
Folks,
    -- Art Z.
http://CheerfulCurmudgeon.com/ "If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
The only question would be whether you intend to fly IFR, & actually need pitot heat. Plan B might be in order, because that alone would probably take almost half your backup alt's capacity.
On a tangent to that...
A friend who's a retired Pratt engineer built an RV-6A a number of years ago. His choice of engine monitor had the option of adding air data, so his regular ASI was hooked to the standard pitot, and the ASI input on the monitor was hooked to a 'pitot port' installed in the pressurized section of the cowl above the engine. Airspeed indications of the two indicators agreed with each other within a couple of knots, over the speed range of the plane.
Charlie
art(at)zemon.name
PostPosted: Sun Aug 07, 2016 7:12 pm    Post subject: Skipping the Endurance Bus Reply with quote
Charlie,
Good catch. Yes, this will be an IFR airplane. To the electrical load analysis that I have already done, I still need to add the second comm radio and the second EFIS screen, but those are minor loads compared to the pitot heat.
Cheers,
    -- Art Z.
On Sun, Aug 7, 2016 at 7:54 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
PostPosted: Mon Aug 08, 2016 12:53 pm    Post subject: Skipping the Endurance Bus Reply with quote
Folks,
Primary alternator OFF Backup alternator ON Pitot heat OFF (unless required for flight)
Do you have a battery contactor?
The e-bus structure eliminates the load
of a battery contactor during endurance
ops.
PostPosted: Mon Aug 08, 2016 12:56 pm    Post subject: Skipping the Endurance Bus Reply with quote
At 10:10 PM 8/7/2016, you wrote:
Charlie,
Have you ever shared a proposed disribution
diagram? It would be MUCH easier to for
electron-herders to convert words into
copper-reality when offering advise.
art(at)zemon.name
PostPosted: Mon Aug 08, 2016 2:46 pm    Post subject: Skipping the Endurance Bus Reply with quote
Bob,
Thank you for mentioning the contactor. Yes, I will need one. No, I had not gotten far enough through my design to remember it. And no, I had not realized that the contactor uses significant power to stay closed. I'll add it to the list.
I found White-Rodgers contactors at Aircraft Spruce and the data sheet lists continuous power of 9 or 10 W which I figure to be approximately 0.75 A at 13.8 V. http://www.aircraftspruce.com/catalog/pdf/11-03161.pdf
Does that sound right for planning purposes?
    -- Art Z.
On Mon, Aug 8, 2016 at 3:52 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Folks,
  ops.
art(at)zemon.name
PostPosted: Mon Aug 08, 2016 3:07 pm    Post subject: Skipping the Endurance Bus Reply with quote
Bob,
Here are the diagrams that I have so far:
https://drive.google.com/open?id=0BzOP2gb9_3RQUHpIMjNfa0NnQW8
The overview is basically my table-of-contents and it has the list of devices with power requirements.
Cheers,
    -- Art Z.
On Mon, Aug 8, 2016 at 3:55 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
Charlie,
