decaclops(at)gmail.com Guest
Posted: Tue Aug 09, 2016 3:57 pm Post subject: Wig Wag difficulties |
Howdy,
I've wired up my landing lights using the Tridon flasher and two
switches according to the WIGWAG WITH B&C SSF-1 FLASHER page 5.0 diagram
and I can't get them to work right. When I put the first switch in the
center wig wag, position, the flasher just buzzes. When the second
switch is put in the center position, I sometimes get 1 flash and then
it just hangs with one light lit. I reversed the 2 and 3 wires at the
flasher and the behavior switches sides.
For lights I'm using the Baja Designs Squadron Pro Leds at 42w each and
I put the 5w 75 ohm resistors across them as in the drawing LED WIGWAG
WITH B&C SSF-1 FLASHER, page 1.0.
I've verified the wiring and the switch functions with a continuity
tester. I changed out the flasher and it worked perfectly for about a
half a minute. I turned it off to install the switches back in the panel
and when I tried it again, same hang up.
Any ideas?
Ed Holyoke
ceengland7(at)gmail.com Guest
Posted: Tue Aug 09, 2016 4:40 pm Post subject: Wig Wag difficulties |
On 8/9/2016 6:56 PM, Ed wrote:
Howdy,
diagram and I can't get them to work right. When I put the first
switch in the center wig wag, position, the flasher just buzzes. When
the second switch is put in the center position, I sometimes get 1
flash and then it just hangs with one light lit. I reversed the 2 and
3 wires at the flasher and the behavior switches sides.
and I put the 5w 75 ohm resistors across them as in the drawing LED
WIGWAG WITH B&C SSF-1 FLASHER, page 1.0.
panel and when I tried it again, same hang up.
Any ideas?
Ed Holyoke
I can't find the flasher on their web site, but if it's buzzing, that
sounds like it's one of the old style mechanical 'vibrator' style
flashers. If you use them with LED lights, the lights probably don't
draw enough current to make the flasher 'switch' between the lights.
FWIW....
Posted: Tue Aug 09, 2016 6:53 pm Post subject: Wig Wag difficulties |
Yup, and that's why I put the resistor across the light per Bob's
drawing. B&C doesn't seem to carry the flasher anymore but it is still
available if you look around for it. Tridon EL13A-2.
Ed
On 8/9/2016 5:42 PM, Charlie England wrote:
<ceengland7(at)gmail.com>
> Howdy,
> Any ideas?
> Ed Holyoke
FWIW....
Joined: 28 Mar 2008 Posts: 1974 Location: Riley TWP Michigan
lyleapgmc
Posted: Tue Aug 09, 2016 8:18 pm Post subject: Wig Wag difficulties |
There are flashers specifically for LED lights that will operate with
the light (no pun intended) load of LEDs. They are used on cars and
motorcycles, particularly when incandescent lamps are replaced with LEDs.
One of the reasons for installing LEDs is that they draw much less
current. Another is that the run very cool. Adding a resistor across
them defeats the purposes and the advantage is gone. The resistor has
to sink the current that an incandescent bulb would draw. This creates
heat just as it does when the incandescent bulb is lit.
I consider the resistor to be a jury rigged cure that is best dealt with
by using the correct components.
Lyle
Posted: Wed Aug 10, 2016 8:05 am Post subject: Wig Wag difficulties |
Howdy Lyle,
It is indeed a bandaid, but perhaps not a complete loss. 75 ohms at
12.5v is less than 2/10 of an amp. I can afford that. The problem that I
have with it is it didn't work to make the flasher cycle. I think I'll
try paralleling 2 of them. That will cost me about a third of an amp.
Little enough if it makes the circuit work right. I'll still be at less
than half of the 8 amps that 100w halogens would pull.
Got a part number for the correct LED flasher? The one's I've been
looking at need switched power to them or they will constantly flash.
Not impossible to manage, but it means a revision of the wiring and
switching at best and an additional switch at worst. Since I've already
silk screened my panel, I'd like to avoid that.
Ed
On 8/9/2016 9:15 PM, Lyle Peterson wrote:
<lyleap(at)centurylink.net>
Lyle
> http://www.aeroelectric.com/articles/WigWag/WigWag.pdf
> Joe Gores
> http://forums.matronics.com/viewtopic.php?p=459415#459415
Posted: Wed Aug 10, 2016 8:07 am Post subject: Wig Wag difficulties |
Thanks, Joe.
Page 5.0 is the drawing I emulated, along with the resistors shown on
the last page. I'm wired exactly as drawn and it's not working as it
should. I'm thinking about trying parallel resistors to have 37.5 ohms
across the lights. Maybe that will do it.
Ed
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Wed Aug 10, 2016 9:34 am Post subject: Re: Wig Wag difficulties |
I still sell my wig wags by the boatload. They require no load resistor and work on everything (almost). Not the cheapest, but they are guaranteed forever if I can manage it.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
Posted: Wed Aug 10, 2016 10:10 am Post subject: Wig Wag difficulties |
To update where I'm at - I paralleled two 75 ohm, 5w resistors on each
light and got solid flashing for the 20 minutes that I tested it. The
resistors are too hot to grip between fingers but not too hot to touch
lightly. I calc about .33A loss and about 4.16 watts. I might try some
50 ohm, 10w resistors which should save me a tenth of an amp and run
slightly cooler.
Ed
henador_titzoff(at)yahoo. Guest
Posted: Wed Aug 10, 2016 10:46 am Post subject: Wig Wag difficulties |
Look at the bright side, Ed. As your alternator fails and your battery voltage goes down, your Gube Roldberg (I'm dyslexic) two resistor implementation will suck in less current to dissipate less vital battery energy. There is a reason for LED lighting other than reliability - they use less power (energy). Why not do the right thing and replace that wig wagger with something that works with less current flowing through it, e.g. Eric Jones' wig wagger? It sounds like a brighter idea than power dissipating resistors giving off invisible infrared photons. I don't mean to speak for Eric, but maybe he can ship you a unit to test drive. If it works, great; if it doesn't, you ship it back.
Henador Titzoff
| Quote: | From: Ed <decaclops(at)gmail.com>
Sent: Wednesday, August 10, 2016 2:09 PM
Subject: Re: Re: Wig Wag difficulties
--> AeroElectric-List message posted by: Ed <decaclops(at)gmail.com (decaclops(at)gmail.com)>
slightly cooler.
http://www.matronics.com/Navigator?AeroElectric-List<; http://forums.sp; - NEW MATRONICS LIST WIKI -http://wiki.masp; -nics.com/contribution" target="_blank">http://www.matronics.com/contribut===============
Posted: Wed Aug 10, 2016 6:39 pm Post subject: Wig Wag difficulties |
>Adding a resistor across them defeats the
. . . by how much?
> implementation will suck in less current . .
Incandescent lamps were king When that flasher
was first applied to OBAM aircraft, further,
the lowest cost solution for fabricating a useful wig-wag
installation was realized by incorporating an
automotive, 3-terminal flasher. Given that
three terminals are quickly used up with
two lamp outputs and one power input. For the
internals of this flasher to function, it needed
to seek a power ground through the OFF side
lamp.
This philosophy worked well in cars for decades
before flying a few decades more in airplanes.
When builders began the transition to LED
populated fixtures, it seems that the legacy
flasher technology was unable to secure a
operable ground through the newer lamp
technology.
The first design goal was to offer a means
by which existing incandescent installations
could be converted to LED with a minimum
of cost . . . and power 'wasted'. Experiments
conducted in our shop and on some airplanes
showed that the added resistors would allow
a quick and easy transition to LED.
75 ohms paralleled with the fixtures I
had access to appeared to be a good compromise
while adding only 0.2 amps to system loads
in the wig-wag mode.
Yes, they run too hot to touch . . . so do
battery contactors . . .
There were, and stall are, plans for replacing
the automotive flasher . . . but if the flasher
is not performing as needed in a new installation,
there has to be an explanation . . . which would
be interesting to know.
Had anyone offered an "LED compatible" wig-wag
flasher in a neat little box with the resistors
built in, few if any consumers would be aware
of them . . . and probably not inclined to
speak of them in pejoratives.
To be sure, there are more efficient alternatives
in new hardware . . . at a price in dollars
(and perhaps labor to make a change-out).
The notion that the resistors represent a significant
'waste' during battery only operations begs
the question as to what the total endurance loads
look like . . . I suggest that if one even
chooses to run wig-wag in a battery only
endurance mode . . . the resistor losses
are insignificant.
I'd like to think this forum is the place where
designs are explored and decisions made on
an analysis of measurements, outcome of
experiment and a quest for achieving design
goals . . . throwing sand and spit-balls is
not helpful.
Let's be good shepherd of electrons and see if we
can figure out why this one system is not
working as expected when hundreds of similar
systems have been flying for years.
Posted: Wed Aug 10, 2016 7:18 pm Post subject: Wig Wag difficulties |
At 01:09 PM 8/10/2016, you wrote:
| Quote: | --> AeroElectric-List message posted by: Ed <decaclops(at)gmail.com>
To update where I'm at - I paralleled two 75 ohm, 5w resistors on each light and got solid flashing for the 20 minutes that I tested it. The resistors are too hot to grip between fingers but not too hot to touch lightly. I calc about .33A loss and about 4.16 watts. I might try some 50 ohm, 10w resistors which should save me a tenth of an amp and run slightly cooler.= |
A power resistor running at rated dissipation
will sizzle-spit . . . over 100C surface
temperature. They just do that.
Your experiment suggests that the flasher
in hand is a bit more demanding of a low-
as-practical resistance to ground on the
OFF lamp.
I've had a couple builders use resistors
much like this
http://tinyurl.com/jroz29g
while rated at many more watts . . . if
not mounted to a heat sinking surface,
it too would be too hot to touch. The
handy thing about these guys is that
they're easy to mount on metal surface
that sharply reduces their operating
surface temperature.
And . . . of course . . . you can change
out the flasher for one more specific
to the application.
I've opened several versions of those
devices. One particular model was easily
converted to a 4-wire device by cutting
a trace on the board and soldering
on a ground wire to bring out of the case.
Then the need for 'grounding resistors'
goes away. But if the externally added
resistors is not a source of heartburn,
then I suspect the devices cited above
will do the job . . . and the price is
right.
Posted: Thu Aug 11, 2016 8:10 am Post subject: Wig Wag difficulties |
Howdy Bob,
It behaved the same with two different flashers, both EL 13A-2, one
Tridon brand the other Novita which appears to be the follow on to
Tridon. Maybe 75 ohms would work at 14.4v, but I'm testing in the garage
at more like 12.6 with a power supply supporting a battery. When cold,
it would sometimes flash for a few and then stop. My guess is that the
resistance went up with heat and the current was reduced below the
threshold that the flasher would work with.
The mountable and heat sinked resistors seem like a good idea. Better
than zip tying a hot resistor to the wires for sure.
I am not worried about .3A as long as the alternator is running. If it
is offline, so will be my main buss and the exterior lighting. My load
analysis shows me at 26.4A for night VFR while wigwaging. That's 66% of
my 40A alternator capacity. When I designed and built my electrical
system, I was planning to use 100w halogens as I have in my other
airplane. I've dropped at least 4 amps with the LEDs. I'm also going
with LED position/strobe lights for an additional current and weight
savings of around 9 amps and 2 1/2 pounds.
Ed
> slightly cooler.=
OFF lamp.
much like this
*http://tinyurl.com/jroz29g*
to the application.
right.
Posted: Thu Aug 11, 2016 5:00 pm Post subject: Wig Wag difficulties |
Howdy Bob,
It behaved the same with two different flashers, both EL 13A-2, one Tridon brand the other Novita which appears to be the follow on to Tridon. Maybe 75 ohms would work at 14.4v, but I'm testing in the garage at more like 12.6 with a power supply supporting a battery. When cold, it would sometimes flash for a few and then stop. My guess is that the resistance went up with heat and the current was reduced below the threshold that the flasher would work with.
The mountable and heat sinked resistors seem like a good idea. Better than zip tying a hot resistor to the wires for sure.
I am not worried about .3A as long as the alternator is running. If it is offline, so will be my main buss and the exterior lighting. My load analysis shows me at 26.4A for night VFR while wigwaging. That's 66% of my 40A alternator capacity. When I designed and built my electrical system, I was planning to use 100w halogens as I have in my other airplane. I've dropped at least 4 amps with the LEDs. I'm also going with LED position/strobe lights for an additional current and weight savings of around 9 amps and 2 1/2 pounds.
Ed |
Good moves. Why would you run wig-wags with
an off-line alternator?
First, such an occurrence is rare.
When it does occur, the design goal is
NOT to run everything including the kitchen
sink . . . but to keep really USEFUL things
running until the airport of INTENDED DESTINATION
is in sight. In the earliest days of the implementation
of an e-bus, EN ROUTE operating loads were often
reduced to 3 amps or less.
Certainly, running any form of exterior lighting
does not improve significantly on your probability
of comfortable termination of flight.
Adding the SD-8 in Z-13/8 was a quantum jump
in options for EN ROUTE energy consumption. A
Plan-B could consider continuous consumption
of 8A or more . . . with total independence
on the battery's contained energy.
Once the airport was in sight, you could
fire up everything, kitchen sink and all,
for descent and approach to landing.
The through process in this particular
Failure Modes Effects Analysis is to deduce
electrical demands for sustained flight
sans main alternator. For myself, the
design goal would be to sustain useful/
necessary electro-whizzies, battery only
for duration of fuel aboard.
I.e. your ELECTRICAL endurance should be
equal to or greater than FUEL endurance.
In no scenario can I imagine that exterior
lighting of any kind is a significant factor
in the equation for comfortable termination
of flight at airport of intended destination.
Back when LongEz was king, a nav/com, transponder,
turn-coordinator and minimal panel lighting
was easily power up for 4 hours or more by
a rather small battery.
Your own demands for comfortable EN ROUTE
operations without a main alternator are
undoubtedly different. It's a good thing
to KNOW what they are and then design
for meeting those demands for what ever
ENDURANCE value you choose . . . perhaps
an hour is okay in your book . . . but 3+
hours would not be a bad thing.
Energy consumption for exterior lighting
doesn't figure into that consideration.
Posted: Thu Aug 11, 2016 8:09 pm Post subject: Wig Wag difficulties |
Howdy Bob,
Yeah, I had an alternator fail in our 6A and just kept going. I had cap
checked the RG-25 battery at the most recent annual using a 4 amp load
with a West Mountain Radio CBA, and got 8 hours out of it to 10.5v so I
knew that the situation wasn't critical. We flew on for a couple of
hours, landed for gas, and flew another hour and a half to our intended
destination. Replaced the alternator the next day and still had plenty
of pop in the battery for engine start.
My new plane will pull a little over 6 amps at minimum load with 2
electronic ignitions, another 2 amps if I don't kill the MFD. I have two
PC680s which I will cap check before I fly and at each annual so I will
know my endurance. I can power the E-bus with either or both batteries
so I can run one and hold the other in reserve if I so choose. Using the
Odyssey discharge charts, I'm reading about 5 hrs. endurance, if I'm
careful. I may still put on an SD-8 for belt and suspenders.
Ed
