AirEupora
budyerly(at)msn.com Guest
Posted: Thu Aug 11, 2016 10:11 am Post subject: Did Anybody see thius on BBC |
Looks intact and probably is. Nightmare to pull out all the fasteners and
metal. Yuk!
In fresh water , just pull the engine and gear out, do some corrosion
control and reassemble. Inspect, test and go fly!
4-6 hard weeks plus engine rebuild time. Salt leaching out of the seams,
joints fastener holes etc. is a real concern.
$25,000 insurance job in fresh water, but in salt water, I doubt it will
return to fly. Would require a higher inspection requirement due to
corrosion concerns and getting the fasteners out and changing trim motors
and tailplane system on a classic is a bit of a pain..
Saved the pilots life and the environment.... Must be a good airplane.
Bud Yerly
Roland
pete(at)lawless.info Guest
Posted: Thu Aug 11, 2016 10:56 am Post subject: Did Anybody see thius on BBC |
Bud it did not end up intact. There is another picture from a local
paper showing the engine broken off from the fuselage. WInd and waves I
guess.
Before: http://www.holderness-gazette.co.uk/artplanecrashbeach110816.htm
After:
http://www.hulldailymail.co.uk/pilot-escapes-unscathed-as-plane-crashes-in-withernsea/story-29606351-detail/story.html
At least we know they float!
Pete
G-RMAC Classic #109
and metal. Yuk!
seams, joints fastener holes etc. is a real concern.
will return to fly. Would require a higher inspection requirement due
to corrosion concerns and getting the fasteners out and changing trim
motors and tailplane system on a classic is a bit of a pain..
Bud Yerly
zwakie
Posted: Fri Aug 12, 2016 2:42 am Post subject: Re: Did Anybody see thius on BBC |
Sorry to read about your misfortune Bob, glad that you walked away relatively unharmed yourself.
Take you time, hope that in the end all works out for you!
When you are up to it, could you please let us know what happened?
_________________ Marcel Zwakenberg
Europa XS TG || 912ULS || PH-SBR |
Roland
Posted: Fri Aug 12, 2016 3:33 am Post subject: Re: Did Anybody see thius on BBC |
All the best also from me and sorry for my post above - it was inadequate and not funny.
Roland
PH-ZTI
XS TG 914
gregoryf.flyboy(at)comcas Guest
Posted: Fri Aug 12, 2016 12:43 pm Post subject: Did Anybody see thius on BBC |
Roland,
Your comment made me laugh whole-hearted, that's for sure.
Of course the comedy is now overshadowed by what appears to be the loss of
the plane. That's very sad, and I feel for the pilot/owner. There is still
the over-stretched voice at the back of my head that is saying it 'might?'
be fixable. I think of Thomas Scherer who has done it, and probably Bud, and
other names here?
Have a great day,
Greg Fuchs
