		mhealydds
				 Posted: Sun Aug 14, 2016 5:56 pm    Post subject: Trim Cable Nut |
				This may seem like a dumb question.....how did you get the elevator trim cable nut that is riveted to elevator cover plate threaded onto elevator trim control cable. I don't seem to have enough room to twist cover plate with nut around trim cable without elevator in the way.
 Thanks.....Matt
 (getting excited as end is in sight!)
		dmaib@me.com
				 Posted: Sun Aug 14, 2016 6:15 pm    Post subject: Trim Cable Nut |
				I installed #4 screws and nuts in lieu of riveting. I've been glad several times over the past 8 years.
 David Maib
  	  | Quote: | 	 		   On Aug 14, 2016, at 9:56 PM, mhealydds <mhealydds(at)gmail.com> wrote:
  Thanks.....Matt
  http://forums.matronics.com/viewtopic.php?p=459501#459501
  _________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
				 Posted: Sun Aug 14, 2016 6:25 pm    Post subject: Trim Cable Nut |
				If you unscrew the screws holding the trim system onto the HS deck, you can pull out on one trim cable enough to bend it out of the hole in the elevator and screw the nut and plate on. Then do the same on the other side.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 C: 352-427-0285
 F: 815-377-3694
  	  | Quote: | 	 		   On Aug 14, 2016, at 10:14 PM, David Maib <dmaib(at)me.com> wrote:
  David Maib
 > Thanks.....Matt
