MT Governor failure
Goto page 1, 2  Next
civengpe
PostPosted: Tue Aug 16, 2016 4:27 pm    Post subject: MT Governor failure Reply with quote
You are right under me on the SB list. I feel EXTREMELY lucky nothing has happened in my 135 hours of flight. I am really at a loss as to how to proceed here. MT has my governor for the SB, but I wonder if I shouldn't just bite the bullet and go to a different brand.
Is there a better mouse trap out there?  I'm not sure if it matters, but I have an MT 12B prop.
Shannon
On Aug 16, 2016 7:16 PM, "Sandra & Rick" <jrlark(at)bmts.com (jrlark(at)bmts.com)> wrote:
Hi all, so here is the rest of my storey.
All in all not too impressive. This happened on April 27, 2016, during my
very first flight.  Engine over speed to 3060 rpm, which heated the
crankshaft thrust surface and caused multiple heat checks.  Unfortunately I
didn't respond as quickly as I could have so the crank was destroyed (first
flight, just coming off the runway, not expecting this etc).  Engine was
torn apart, none destructive tested and crank shaft was replaced.
     Here are a few picture of what my governor looked like internally.
#2083 shows the bushing that was seized,  #2084 shows some of the gouging,
#2089 shows the make, serial # etc, #2092  shows where the bushing should
have been, there were sharp ridges etc from the bushing rotating in the
housing,   #2095 show one side of the area where the gears were located,
#2096  shows the same area, opposite side, as does #2098, #2082 shows the
house where the drive shaft passed through to the engine drive and where the
bushing used to be located.
Rick
Southampton, Ont
Vans # 40956
philperry9
PostPosted: Tue Aug 16, 2016 4:40 pm    Post subject: MT Governor failure Reply with quote
I'm curious as to whether Rick's failure is related to the failures of Myron and Todd.   It seems to me that Rick's failure is directly related to the published SB (Matching SN and bearing issue).   Myron and Todd's both has SN's outside the SB and experienced broken metal as opposed to a rotating bushing.
It seems to me like Ricks failure, while very significant, expensive, noteworthy, and concerning, is unrelated to the recent failures....
Am I right?
Phil
On Tue, Aug 16, 2016 at 7:26 PM, Shannon Hicks <civeng123(at)gmail.com (civeng123(at)gmail.com)> wrote:
Shannon
Rick
Southampton, Ont
Vans # 40956
jrlark
PostPosted: Tue Aug 16, 2016 4:55 pm    Post subject: MT Governor failure Reply with quote
Phil you are correct, it is a different failure.  The one fact I wonder about is whether Myron and Todd failures somehow started with the bushing?  Does anyone know?
Unfortunately I can’t figure out how to post any pictures on Matronics.  Anyone know how?
Rick
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phillip Perry
Sent: Tuesday, August 16, 2016 8:40 PM
Subject: Re: FW: MT Governor failure
Am I right?
Phil
Shannon
Rick
Southampton, Ont
Vans # 40956
Tim Olson
PostPosted: Tue Aug 16, 2016 5:04 pm    Post subject: MT Governor failure Reply with quote
I'm thinking that most of them were delivered around the same timeframe and they are probably just differing failures but still related to some issue that came around that timeframe. I bet the SB serial number range is insufficient.
Because there are so many MT governors flying since 2005 that we would hear of more if there were a large number of failures. That said, if your governor was from 2011 thru 2013, I'd be concerned even if your governor isn't within the S/N range.
On Aug 16, 2016, at 7:39 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Am I right?
Phil
Shannon
Rick
Southampton, Ont
Vans # 40956
jeff(at)westcottpress.com
PostPosted: Tue Aug 16, 2016 5:45 pm    Post subject: MT Governor failure Reply with quote
For those looking for an alternative governor, here is what I am using with my YIO-540-D4A5 and Hartzell Blended Airfoil. This was recommended to me by Gary Sobek.
PCU5000.COM
I purchased through:
Ameritech Industries dba American Propeller Service
Repair Station No. NO3R717L
20208 Charlanne Drive
Redding, CA 96002
Phone: (530) 221 4470
Fax: (530) 221 5210
Email: sales(at)ameritech-aviation.com (sales(at)ameritech-aviation.com)
Jeff Carpenter
N410CF
Flying
Am I right?
Phil
Shannon
Rick
Southampton, Ont
Vans # 40956
Westcott Press
1121 Isabel Street
Burbank, CA 91506
jeff(at)westcottpress.com (jeff(at)westcottpress.com)
818-861-7300
Kellym
PostPosted: Tue Aug 16, 2016 6:04 pm    Post subject: MT Governor failure Reply with quote
Well, I have pretty much the same governor and prop. My governor is a
-5, which came direct from MT in Germany, but that may or may not be a
difference. I have the same MT 3 blade prop Vans sells.
I made some minor modifications to my flight today with these issues in
mind...to minimize time over water, away from roads or civilization, but
mad 4.5 hour flight to get myself and plane home. Where to go from here
will depend a lot on the reports. No one wants to do a teardown, or have
a lot of expenses not covered by insurance. Nor do we want to have
hangar queens awaiting a solution.
I have to look up the service bulletin and see if my governor falls in
that range. Has anyone posted the service bulletin?
Shannon
during my
Unfortunately I
(first
gouging,
should
shows the
where the
Rick
Southampton, Ont
Vans # 40956
Kelly McMullen
KCHD
philperry9
PostPosted: Tue Aug 16, 2016 6:17 pm    Post subject: MT Governor failure Reply with quote
Here's the link to all the SB's Kelly...  The SB that's been discussed here is #27.
http://www.mt-propeller.com/en/entw/serviced.htm
Phil
On Tue, Aug 16, 2016 at 9:04 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
Well, I have pretty much the same governor and prop. My governor is a -5, which came direct from MT in Germany, but that may or may not be a difference. I have the same MT 3 blade prop Vans sells.
I made some minor modifications to my flight today with these issues in mind...to minimize time over water, away from roads or civilization, but mad 4.5 hour flight to get myself and plane home. Where to go from here will depend a lot on the reports. No one wants to do a teardown, or have a lot of expenses not covered by insurance. Nor do we want to have hangar queens awaiting a solution.
I have to look up the service bulletin and see if my governor falls in that range. Has anyone posted the service bulletin?
Shannon
    during my
    Unfortunately I
    (first
    gouging,
    should
    shows the
    where the
    Rick
    Southampton, Ont
    Vans # 40956
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
Kellym
PostPosted: Tue Aug 16, 2016 6:20 pm    Post subject: MT Governor failure Reply with quote
Thanks Phil. I sure thought you would be flying before I first got into
the air.
here is #27.
Phil
nothing
to how
matters, but
Shannon
during my
heated the
Unfortunately I
destroyed
(first
etc). Engine was
replaced.
internally.
of the
gouging,
bushing
should
rotating in the
were located,
shows the
drive and
where the
Rick
Southampton, Ont
Vans # 40956
FORUMS -
WIKI -
b Site -
Kelly McMullen
KCHD
philperry9
PostPosted: Tue Aug 16, 2016 6:35 pm    Post subject: MT Governor failure Reply with quote
I was thinking we'd be up about the same time.
I got stuck communing 3.5 hours each way to work on the plane and I did it every single week for a year and a half. That really slowed me down.
Last December I finally got a hangar in Waco and could finally move the plane up here with us. Now it's just a 10 minute walk from the house to the airport.
It's within striking distance to flying (I think).
On Aug 16, 2016, at 9:20 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
Thanks Phil. I sure thought you would be flying before I first got into the air.
> here is #27.
> Phil
> nothing
> to how
> matters, but
> Thanks,
> Shannon
> during my
> heated the
> Unfortunately I
> destroyed
> (first
> etc). Engine was
> replaced.
> internally.
> of the
> gouging,
> bushing
> should
> rotating in the
> were located,
> shows the
> drive and
> where the
> Rick
> Southampton, Ont
> Vans # 40956
> FORUMS -
> eferrer" target="_blank">http://forums.matronics.com
> WIKI -
> errer" target="_blank">http://wiki.matronics.com
> b Site -
> rel="noreferrer" target="_blank">http://www.matronics.com/contribution
glastar(at)gmx.net
PostPosted: Tue Aug 16, 2016 10:33 pm    Post subject: MT Governor failure Reply with quote
I had just this morning an email feedback from MT Germany, they are
working on a new SB which should cover the impacted serial numbers so
they now seem to be aware of what is causing this issue?
Werner
is insufficient.
> Am I right?
> Phil
> brand.
> Thanks,
> Shannon
> Hi all, so here is the rest of my story.
> 2016, during my
> heated the
> Unfortunately I
> destroyed (first
> Engine was
> internally.
> the gouging,
> bushing should
> rotating in the
> were located,
> #2082 shows the
> and where the
> Rick
> Southampton, Ont
> Vans # 40956
glastar(at)gmx.net
PostPosted: Thu Aug 18, 2016 6:21 am    Post subject: MT Governor failure Reply with quote
I got this morning a feedback from MT, that my Governor with
S/N 10G598G
is impacted and that I should send it to the factory to be fixed (this
is manufactured in 2010
Werner
Werner
> is insufficient.
> Tim
Tim Olson
PostPosted: Thu Aug 18, 2016 6:29 am    Post subject: MT Governor failure Reply with quote
Thanks Werner,
If you are talking to someone there, see if you can get a feeling for
what the EARLIEST date a governor would have if it were affected.
I'm betting that we'll find it's somewhere after 2009 or 2010,
but I'll be more comfortable if I heard what they had to say.
S/N 10G598G
Werner
> Werner
>> is insufficient.
>> Tim
civengpe
Werner,What engine do you have?
I have an Aerosport Power IO-540 with 9.2:1 pistons and MT is telling me that mine is impacted as well.  From talking with MT in Florida, the engine is what is driving the modification requirements.  Ie Barret, Aerosport etc....
Is this what others are hearing as well?
Shannon Hicks
On Thu, Aug 18, 2016 at 9:20 AM, Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)> wrote:
--> RV10-List message posted by: Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)>
S/N 10G598G
is impacted and that I should send it to the factory to be fixed (this is manufactured in 2010
Werner
I had just this morning an email feedback from MT Germany, they are working on a new SB which should cover the impacted serial numbers so they now seem to be aware of what is causing this issue?
Werner
is insufficient.
FORUMS -
WIKI -
b Site -
philperry9
PostPosted: Thu Aug 18, 2016 6:33 am    Post subject: MT Governor failure Reply with quote
Did they tell you what the fix is and how their modification differs from the standard/defective batch?
Phil
S/N 10G598G
Werner
> Werner
>> is insufficient.
>> Tim
Kellym
PostPosted: Thu Aug 18, 2016 6:41 am    Post subject: MT Governor failure Reply with quote
I might see higher compression pistons affecting the prop via harmonics.
I do not see what else about the engines would have anything to do with
who put them together. For the most part, engines built by the reputable
shops mentioned will have flow balanced cylinders, well balanced
rotating parts and run smoother than a factory engine. I see nothing
about that has anything to do with the governor. So far we are not
getting any information beyond the service bulletin about where the
problem might lie.
On 8/18/2016 7:29 AM, Shannon Hicks wrote:
Werner,
Aerosport etc....
Shannon Hicks
S/N 10G598G
Werner
Werner
same timeframe
related to some
number range
is insufficient.
that we would
said, if
if your
FORUMS -
WIKI -
b Site -
Kelly McMullen
KCHD
civengpe
PostPosted: Thu Aug 18, 2016 6:53 am    Post subject: MT Governor failure Reply with quote
Kelly,I'm just passing along what MT in Florida told me.  They have my governor in their shop and told me they have the parts on order from Germany to correct the issue.  Beyond that, I don't know what the specific issue was other than they said it only affects non certified IO-540s.
I really wish someone from MT would at least get out in front of this and post something.
Shannon Hicks
On Thu, Aug 18, 2016 at 9:42 AM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
I might see higher compression pistons affecting the prop via harmonics. I do not see what else about the engines would have anything to do with who put them together. For the most part, engines built by the reputable shops mentioned will have flow balanced cylinders, well balanced rotating parts and run smoother than a factory engine. I see nothing about that has anything to do with the governor. So far we are not getting any information beyond the service bulletin about where the problem might lie.
Werner,
Aerosport etc....
Shannon Hicks
    S/N 10G598G
    Werner
        Werner
            same timeframe
            related to some
            number range
            is insufficient.
            that we would
            said, if
            if your
    FORUMS -
    WIKI -
    b Site -
FORUMS -
WIKI -
b Site -
glastar(at)gmx.net
PostPosted: Thu Aug 18, 2016 7:02 am    Post subject: MT Governor failure Reply with quote
They did ask the engine type and as I have two governors from them one
on a O-320 and the 2nd for an IO-540 I got only feedback by email so far
(still need to supply the O-320 serial which is at the airport).
They did not specific ask for the type details so I'm not sure it has an
influence.
I had so far only email contact but will try to get more details.
Cheers Werner
problem might lie.
> Werner,
> Aerosport etc....
> Shannon Hicks
> S/N 10G598G
> Werner
> issue?
> Werner
> same timeframe
> related to some
> number range
> is insufficient.
> that we would
> said, if
> if your
> Tim
> FORUMS -
> WIKI -
> b Site -
> rel="noreferrer"
gengrumpy
PostPosted: Thu Aug 18, 2016 7:07 am    Post subject: MT Governor failure Reply with quote
Me too as Tim and mine are same vintage!
grumpy
On Aug 18, 2016, at 9:29 AM, Tim Olson <Tim(at)MyRV10.com> wrote:
Thanks Werner,
> S/N 10G598G
> Werner
>> Werner
>>> is insufficient.
>>> Tim
civengpe
PostPosted: Thu Aug 18, 2016 7:11 am    Post subject: MT Governor failure Reply with quote
Ok, so I just hung up with Andy with MT in Germany.  Here is what he told me.  In certain situations, the fly weights can become loose and cause the failures that we have seen.  They have already identified the modifications needed and will be publishing SB 31 this coming Monday.  All 860-3 governors manufactured between April 2010 and July 2013 are affected regardless of the type of engine.
I did encourage him to post something so that they could get ahead of the issue.
By the way, my governor is in that range.
Shannon Hicks
On Thu, Aug 18, 2016 at 9:53 AM, Shannon Hicks <civeng123(at)gmail.com (civeng123(at)gmail.com)> wrote:
Shannon Hicks
Werner,
Aerosport etc....
Shannon Hicks
    S/N 10G598G
    Werner
        Werner
            same timeframe
            related to some
            number range
            is insufficient.
            that we would
            said, if
            if your
    FORUMS -
    WIKI -
    b Site -
FORUMS -
WIKI -
b Site -
Kellym
Interesting. I wonder what non-certified features they perceive as
issues. Ignition?, Compression ratio? fuel injection? That should cover
most of it. Doesn't give me any comfort to have a certified engine built
by a well known reputable shop. I've only heard of ignition affecting
props, somehow modifying the harmonics a bit, but that still should have
nothing to do with the governor.
On 8/18/2016 7:53 AM, Shannon Hicks wrote:
Kelly,
IO-540s.
and post something.
Shannon Hicks
Werner,
telling me
Aerosport etc....
Shannon Hicks
<glastar(at)gmx.net <mailto:glastar(at)gmx.net>
S/N 10G598G
Werner
Germany, they
serial
this issue?
Werner
same timeframe
related to some
serial
number range
is insufficient.
that we would
failures. That
said, if
concerned even
if your
<http://www.matronics.com/Navigator?RV10-List>
FORUMS -
<http://forums.matronics.com>
WIKI -
<http://wiki.matronics.com>
b Site -
rel="noreferrer"
<http://www.matronics.com/contribution>
FORUMS -
WIKI -
b Site -
Kelly McMullen
KCHD
Goto page 1, 2  Next
Page 1 of 2
