heaysr(at)telus.net Guest
Posted: Sat Aug 20, 2016 10:56 am Post subject: M14P engine problem |
Symptom:
Mag drop at run-up (at) 70% RPM is 3% on Mag #1 (normal) and 5% fluctuating
to 10% on Mag #2.
Troubleshooting done to date;
- run engine on Mag#2 (RH mag feeding rear plugs) up to normal
cylinder head temp, 120 Deg C, shut down and measure temp of each cylinder.
No 2 cylinder found to be cold at around 45 deg C, while all others are to
approx. 100 deg C . Suspect bad spark plug
- swap rear sparkplug plug No 2 cylinder with rear No 3. As above, run
engine on Mag#2 up to normal cylinder head temp, shut down and measure temp
of each cylinder. No 2 cylinder found to be cold at around 45 deg C, while
all others are to approx. 100 deg C . Conclusion: it is not a spark plug
problem. Suspect HT lead from mag to spark plug.
- remove mag #2 cover, remove rear spark plug No 2, do a continuity
check with multi--meter on HT lead from No 2 post in distributor cap to
other end at plug connection. Circuit is continuous with .05 ohms at 200 ohm
setting. Repeat on HT lead No 3. Same ohm reading result. Suspect HT lead
insulation or connection of lead to distributor cap..
- remove small pointed screw at post no 2. Remove HT lead. Looks like
screw didn't penetrate insulation. Trim off insulation. Reinstall HT lead
and reinsert pointed screw. With No 2 plug out, reconnect HT lead. Use HV
tester attached to post no 2 in distributor cap. Result: Good strong spark
visible at Plug No 2. Repeat with circuit No 3. Again, a good strong spark.
Conclude that HT connection to post No 2 is OK and the HT lead insulation is
OK all the way to spark plug . Suspect Mag No 2.
- inspect all posts in distributor cap. Some have deposits. Clean to
bright metal. Look for cracks in cap. None found. Check rotor. Clean tip.
Looks OK. Check points are opening properly at No 2. Looks OK. Reassemble
everything. As above, run engine on Mag#2 up to normal cylinder head temp,
shut down and measure temp of each cylinder. No 2 cylinder found to be cold
at around 45 deg C, while all others are to approx. 100 deg C . Same result
as above. Suspect that P lead or mag switch is wired in correctly whereby
Mag switch set at #2 shorts out No 2 and leaves Mag No 1 on rear plugs.
- run engine on Mag #1 up to normal cylinder head temp, shut down and
measure temp of each cylinder. No 2 cylinder found to be warm at around 100
deg C, the same as all others. Conclusion. Mag switch and P leads are wired
according to the M14P manual. It is No 2 mag circuit to No 2 cylinder that
is the problem. Suspect we have somehow fixed the problem
- do a full run-up with mag switch at 1+2. Mag drop at run-up (at) 70%
RPM is 3% on Mag #1 (normal) and 5% fluctuating to 10% on Mag #2.
Absolutely no change. Nothing fixed.
So where is the problem????
If it was the coil, why would it not affect all cylinders. The mags are low
time (about 50 hours on them, but they are about 13 years. They sat for 11
years unused in a dry loft).
We are stumped!!
Does anyone have a diagnosis or cure.
Royden
Yak 55M
GeorgeCoy
Posted: Sat Aug 20, 2016 11:15 am Post subject: M14P engine problem |
I assume no arc tracking in the mag cap. If not you probably need to
replace the #2 rear plug hi tension wire to rule it out completely. I have
not had god luck with the high tension testers. Particularly with
intermittent changes. I also assume you are running the original Russian
ignition.
George
nigel(at)yakdisplay.com Guest
Posted: Sat Aug 20, 2016 11:17 am Post subject: M14P engine problem |
| Quote: | From first hand experience, a coil breaking down causes all sorts of strange problems, including symptoms that appear to point to the opposite mag and even complete momentary engine stoppage even if only one coil is affected even with mags on both!
Shelf Age is the key. Hours do not count.
Your cheapest option and least time consuming might be try try new new coil(s)... Got mine from Gill at m14p.com. She offers core coil exchange.
Just a thought....
Nigel Willson
Tel. 07809 116676
yakdisplay.com
Sent from my iPad
| Quote: | On 20 Aug 2016, at 20:05, Royden Heays <heaysr(at)telus.net> wrote:
Symptom:
to 10% on Mag #2.
We are stumped!!
Royden
Yak 55M
Richard.goode(at)russiana Guest
Posted: Sat Aug 20, 2016 10:45 pm Post subject: M14P engine problem |
I would be sure that it is a coil problem. These are terribly common, and
after our traditional Russian sources of coils has dried up, we were forced
to spend a lot on researching new production in Hungary which is now working
very well.
Richard Goode
Lancer
Joined: 21 Apr 2016 Posts: 30 Location: Cairns, Australia
Posted: Sun Aug 21, 2016 5:33 pm Post subject: Re: M14P engine problem |
It appears from your testing so far that you have eliminated it to #2 plug lead. The problem is that when the lead is installed inside the conduit it could be earthing and causing a loss of spark getting to the plug.
I'd replace the lead and go from there.
_________________ You can run but you can't hide |
