Cooling issues XS 914 on the ground
Goto page Previous  1, 2
Burrilla
PostPosted: Thu Aug 25, 2016 7:04 am    Post subject: Cooling issues XS 914 on the ground Reply with quote
I’ve just looked at these>
http://www.demon-tweeks.co.uk/motorsport/fans-fan-kits/revotec-slimline-cooling-fans
various sizes.
Alan
[quote] On 25 Aug 2016, at 15:55, david park <dpark748(at)icloud.com> wrote:
Can you give fan specs and where available!
Dave Park
> On 25 Aug 2016, at 15:22, Greg Fuchs <gregoryf.flyboy(at)comcast.net> wrote:
> I am implementing a cooling fan for ground running. No temp specs, since the
> plane is in build....however, a cooling fan in similar arrangement works
> great on my motorcycle, so I figured it might work well here. Its an
> electric radiator fan for a quad Kart of of some sort, and covers approx.
> half of the oil cooler. The oil cooler, though offset from the water cooler
> (914 engine), is sealed to it in the area where they over-lap in front of
> the fan to promote airflow through both radiators (sucking air through the
> oil radiator will also do the same with the water radiaor...lots of work
> here to create tight-fitting air dams). Having the two radiators tight with
> each other will hopefully cut down on warm-up time during the winter as
> well. The fan is lightweight, cheap, and only requires a wire run and
> switch. Once verified to work, it will be made to be automatic on/off. For
> extreme cooling situations in flight with the airflow pushing and the fans
> pulling, the extra leverage 'seems' a no-brainer. I figure it won't windmill
> much if at all in the airflow while off, due to the resistance to the air by
> the radiators mounted in front of it. This arrangement would be much easier
> to implement with the radiators in-line with each other, but the offset is
> known to work well, and the decision had already been made. More data will
> follow at some point..
> Greg Fuchs
> 914 TRI
cakeykev(at)gmail.com
PostPosted: Thu Aug 25, 2016 7:32 am    Post subject: Cooling issues XS 914 on the ground Reply with quote
Demon tweeks do mc fans push and pull with specs of m2 per hour
Kevin
Dave Park
> Greg Fuchs
> 914 TRI
PostPosted: Thu Aug 25, 2016 7:37 am    Post subject: Cooling issues XS 914 on the ground Reply with quote
Dave,
Dimension of fan is approx. 100mm square, and is made for radiator cooling,
so it should handle the temps.
Put this into your favorite web search tool:'Electric Radiator Cooling Fan
For Chinese 200cc 250cc Quad ATV Go Kart Buggy'
You'll find it...cost is about 15 US Dollars. Cheap enough to try.
Greg
PostPosted: Thu Aug 25, 2016 7:46 am    Post subject: Cooling issues XS 914 on the ground Reply with quote
Dave Park
[quote] On 25 Aug 2016, at 16:36, Greg Fuchs <gregoryf.flyboy(at)comcast.net> wrote:
Dave,
Greg
Remi Guerner
PostPosted: Thu Aug 25, 2016 10:22 am    Post subject: Re: Cooling issues XS 914 on the ground Reply with quote
Thanks Nigel for your detailed answer. I look forward to hear from you when you are in the testing phase of your Calypso.
Remi
carlp101
PostPosted: Thu Aug 25, 2016 2:32 pm    Post subject: Re: Cooling issues XS 914 on the ground Reply with quote
Hi all,
Here are a few pics I took tonight of my installation. I'll need to take some with the cowl off.
Let me know if you have any questions.
All the best.
Carl
https://dl.dropboxusercontent.com/u/18135747/image%201.jpeg
https://dl.dropboxusercontent.com/u/18135747/image%202.jpeg
https://dl.dropboxusercontent.com/u/18135747/image%203.jpeg
https://dl.dropboxusercontent.com/u/18135747/image%204.jpeg
Page 2 of 2
