		mojavjoe
				 Posted: Sat Aug 27, 2016 3:37 pm    Post subject: fsss windsheild |
				I'm about to attach my windshield and I'm in the process of making a 1/8" plywood template. When I bought the kit they had not drafted plans for the ss. The frame of my fsss is similar to the mk iii xtra so if you built an xtra maybe you can solve some of my problems. I'm assuming that the small windows at the lower front and the main window are cut as one piece.  My frame makes a curve at the bottom of this small window that the plywood can't make without cracking, If the Lexon won't make this curve and another at the top of the frame can it be softened with heat? What is a safe way to apply heat? I've seen the door frames attached in some mk iii's with pins at the front and in others with piano hinge at the top, what are the pro's and con's? I'm also assuming that the nose cone is attached after the windshield is in place.
 thanks
 Joe
		lcottrell
				 Posted: Sat Aug 27, 2016 6:04 pm    Post subject: fsss windsheild |
				Every one must be asleep.  :-/ Lexan will bend without breaking. It mostly depends on the thickness if you will be able to bend it. I have bent 60/1000's 90 degrees with the help of a jig. Heat will not help you with lexan.   I am having trouble understanding what the piece that you are trying to fit looks like. If this doesn't help you, perhaps a picture would be worth more than words.Larry
 On Sat, Aug 27, 2016 at 5:35 PM,  <mojavjoe(at)comcast.net (mojavjoe(at)comcast.net)> wrote:
  	  | Quote: | 	 		  I'm about to attach my windshield and I'm in the process of making a 1/8" plywood template. When I bought the kit they had not drafted plans for the ss. The frame of my fsss is similar to the mk iii xtra so if you built an xtra maybe you can solve some of my problems. I'm assuming that the small windows at the lower front and the main window are cut as one piece.  My frame makes a curve at the bottom of this small window that the plywood can't make without cracking, If the Lexon won't make this curve and another at the top of the frame can it be softened with heat? What is a safe way to apply heat? I've seen the door frames attached in some mk iii's with pins at the front and in others with piano hinge at the top, what are the pro's and con's? I'm also assuming that the nose cone is attached after the windshield is in place.
 thanks
 Joe
 The older I get, the less tolerant I am of those who are intolerant of others.
		Richard Pike
				 Posted: Sat Aug 27, 2016 8:13 pm    Post subject: Re: fsss windsheild |
				Let me chime in my .02$ here... You can form Lexan in an oven or other heated chamber, if you make up a form, cover it with old t-shirt material, heat up the oven and watch closely until you see the Lexan collapse and assume the shape of the form. That can turn out fairly well, helped my brother make a taller windshield for his KLR650 that way, using some 1/8" Lexan, and it was acceptable. Probably 13" X 22".
 Had to put a sharp bend in the top of the Lexan windshield of my Anglin J-6 and there was no way to put it in any sort of oven. Used a space heater until that portion of the windshield started to sag, and promptly dropped the part needing to be bent on a coffee table and cranked the rest of it to the appropriate angle. Turned out pretty good, but it did have some major optical anomalies.
 On the first shorty windshield for my MKIII, needed the top to bend over sharply, I got a friend to help me cold bend the 1/8" Lexan in a big wooden bench vise that was 3' long, sort of like a sheet metal brake, except made out of wood. About a 3' width, it was all we could do to manage it, and that was many years ago. Gird up yer loins, and get a REALLY BIG friend to help you. Mine was old and skinny...
 So you can use heat with Lexan, but don't expect great things unless you get REALLY lucky. If you can cold bend it, by all means do so.
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
