				 Posted: Sat Sep 10, 2016 5:22 pm    Post subject: Just checking |
				Dear all
 I just want to check that I understand the fundamental concept of the electrical system
 All the loads (with some exceptions) are connected to the buss bar.
 When the engine is not running the battery powers everything.
 Once the engine is running the alternator powers everything and charges the battery.  So the flow sort of reverses as soon as the alternator comes on line.
 Do I understand correctly?
 William Daniell
 LONGPORT
 +57 310 295 0744
		rampil
				 Posted: Sat Sep 10, 2016 5:49 pm    Post subject: Re: Just checking |
				Absolutely nothing can be ascertained until we have direct visualization
 of your circuit diagrams AS BUILT.  To much variation in the wild to claim anything about home built aircraft. Any other comment here would be pure surmise
		spcialeffects
				 Posted: Sun Sep 11, 2016 12:44 am    Post subject: Re: Just checking |
				Hi William. You should post your electrical questions in the AeroElectrical section of the Matronics List. I too have had problems getting my head around this part of my build but stick with it......after a few months things start to make a bit more sense. Good luck
 Frank
				 Posted: Sun Sep 11, 2016 6:08 am    Post subject: Just checking |
				Ira
  I followed the europa wiring diagram exactly
  Will
 On Sep 10, 2016 20:55, "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote: 	  | Quote: | 	 		  --> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
  Ira N224XS
  http://forums.matronics.com/viewtopic.php?p=460399#460399
   FORUMS -
  WIKI -
  b Site -
            -Matt Dralle, List Admin.
		rampil
				 Posted: Mon Sep 12, 2016 2:45 am    Post subject: Re: Just checking |
				Hi Will,
 If you are using the minimalist Europa power system, then in general, your
 surmise is correct. The battery supplies power to the "grid" when the
 alternator produces less than the charging voltage (say 12V for the sake of
 simplicity). When the alternator generates its full voltage  or approximately
 13.6V, it pushes energy back into the battery and is the source of buss power.
 That being said, I have seen a few very crazy things done in OBAM aircraft.
 Also, I dare say no one outside the UK uses the exact design provided by
 Europa. My own power system uses a "carefully" considered modification of Bob Nuckolls' designs. The advantage of going beyond the minimalist
 design includes mainly removal of critical single point failure nodes and the inclusion of secondary sources (I have a second alternator and battery for
 the EFIS as I used to do IFR ops).
 I have also recently seen crazy things done to other engine systems. A local elderly gent with a kitfox installed a shutoff valve in his oil reservoir return
 line deep inside his cowl to prevent sumping after shutdown.  Of course, he
 eventually forgot to reach in and turn it back on at some point and completely
 bricked his 912s.
 This is why I ask for design as built when people ask for troubleshooting help.
				 Posted: Mon Sep 12, 2016 6:27 am    Post subject: Just checking |
				Ira
 Interesting design addition you mention.  Understand your point.
 Actually I am going for minimalist Europa System.    So thanks I just wanted to check that I had the fundamentals correct.
 I do have a Dynon but that has its own battery and I have a good handheld and a portable GPS so I figure that from the avionics side I am ok.   Incidentally I fired the dynon and the electrical system up yesterday and it talked to all the devices and no sparks or smoke.  The radio worked fine as well.
 My turbo rotax 912 has a mechanical pump as well as the electric pumps.
 So I think that I am going to stick with simple.
 many thanks again will
 William Daniell
 LONGPORT
 +57 310 295 0744
 On Mon, Sep 12, 2016 at 5:45 AM, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
  Hi Will,
  bricked his 912s.
  Ira N224XS
  http://forums.matronics.com/viewtopic.php?p=460424#460424
   FORUMS -
  WIKI -
  b Site -
		rampil
				 Posted: Mon Sep 12, 2016 11:12 am    Post subject: Re: Just checking |
				Hi Will,
 I realize that you did not inquire of design advise, but I will offer some
 anyway.  The dirt simple electrical system in the combined builder's manual
 has a single 30A SloBlo fuse between the battery and the 914 fuel pump.
 If that goes, there is no other way to power the pump and bye bye. I really
 hate single point fatal errors.  It was bad enough that I had to deal with them
 in my day job!
				 Posted: Mon Sep 12, 2016 11:31 am    Post subject: Just checking |
				Ah thanks.much appreciated.  All advice gratefuly received.  I have learned so much from reading the posts of others.
  I have one pump connected direct to the alternator and the other to the bus.  (As well as the mechanical pump which is good for 22" map).
  Would that be ok?
  Will
 On Sep 12, 2016 14:18, "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote: 	  | Quote: | 	 		  --> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
  Hi Will,
  in my day job!
  Ira N224XS
  http://forums.matronics.com/viewtopic.php?p=460443#460443
   FORUMS -
  WIKI -
  b Site -
		Fred Klein
				 Posted: Mon Sep 12, 2016 12:19 pm    Post subject: Just checking |
				Ill second Iras suggestion to go to AeroElectrics at MatronicsBob Nuckolls is a true guru for all things electrichas been very helpful to me w/ my electrically-dependent engine, particularly w/ regards to developing my plan B in the event things go south while airbornehis book is a treasurehe does not, however, suffer fools gladly.
 F.
 PS: For the curious, I am focusing on getting my cooling system to do the job while Miz. E is sitting on the ground.
  	  | Quote: | 	 		   On Sep 12, 2016, at 3:45 AM, rampil <ira.rampil(at)gmail.com> wrote:
  Hi Will,
  bricked his 912s.
  Ira N224XS
				 Posted: Mon Sep 12, 2016 1:03 pm    Post subject: Just checking |
				Fred
 Yup I did download and read the book cover to cover and I am an avid reader of his forum.
 WIll
 William Daniell
 LONGPORT
 +57 310 295 0744
 On Mon, Sep 12, 2016 at 3:13 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
  	  | Quote: | 	 		  --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
  I’ll second Ira’s suggestion to go to AeroElectrics at Matronics…Bob Nuckolls is a true guru for all things electric…has been very helpful to me w/ my electrically-dependent engine, particularly w/ regards to developing my “plan B” in the event things go south while airborne…his book is a treasure…he does not, however, suffer fools gladly.
  F.
  > On Sep 12, 2016, at 3:45 AM, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
  > Hi Will,
  > bricked his 912s.
  > Ira N224XS
   FORUMS -
  WIKI -
  b Site -
