issues?
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
skidmk
PostPosted: Fri Sep 23, 2016 6:20 am    Post subject: issues? Reply with quote
Gents,
I filled the cooling unit oil reservoir several times over the past few days. Approximately 250 ml was used in total. In all cases the reservoir slowly emptied, and a steady dripping leak saw observed coming from an unidentifiable unit below the Cooling Turbine (as labeled and observed via borescope.)
I can confirm that there is no leak in the reservoir or the hose running down to the Turbine unit. The leak is internal to the Cooling Turbine and/or the assembly attached below it.
Oil is coming from unit with 3 holes in center of photo. Appears to be from left hand holes only. (Looking up)
FUEL LEAK
A fuel leak has developed out of the overflow pipe located just aft of the large belly panel I had removed to investigate the oil leak. The fuel appears to be coming from a rectangular unit just below the burner cans.
Rectangular unit that fuel is draining from. (Looking aft)
Any further thoughts?
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
 Filesize:  583.09 KB
 Viewed:  3496 Time(s)
 Filesize:  482.74 KB
 Filesize:  667.04 KB
Mike "Skidmk" Bourget
Ottawa, Ontario
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
