solder splices
bobnoffs
PostPosted: Mon Sep 26, 2016 4:23 am    Post subject: solder splices Reply with quote
hi all,
 i know solder connections are generally frowned on, especially in engine compartment but my take on a solder splice in the middle of a 6'' run with the wire bundled with 6 others is that it is totally satisfactory. am i wrong that solder is ok if you pick your application sites?
 bob noffs
rnjcurtis(at)charter.net
PostPosted: Mon Sep 26, 2016 7:20 am    Post subject: solder splices Reply with quote
I was never aware that solder connections were frowned upon!  In fact my belief is that a well executed solder connection, with good mechanical connection, good solder flow, and a double insulation with heat shrink, is in fact more reliable than any other connection, over the long term.  Just my humble opinion!
Roger
bobnoffs
PostPosted: Tue Sep 27, 2016 4:13 am    Post subject: solder splices Reply with quote
i agree that the joint if undisturbed can't be beat. i was questioning if movement would become a factor in the condition i described.
 bob noffs
On Mon, Sep 26, 2016 at 10:17 AM, Roger <rnjcurtis(at)charter.net (rnjcurtis(at)charter.net)> wrote:
Roger
PostPosted: Tue Sep 27, 2016 4:40 am    Post subject: solder splices Reply with quote
At 07:07 AM 9/26/2016, you wrote:
hi all,
 bob noffs
I don't know why it wouldn't be just fine ANYWHERE
the materials, talents and tools are likely to
produce a serviceable joining . . . irrespective
of location.
Soldering was 'frowned upon' on the 1960's
production lines at Cessna because soldering irons
burned people and melted carpets. At Boeing, I had
to have a fireman come out and give me a permit
to plug in an iron . . . just to make sure I wasn't
working the task close to flammables. It's process
sensitive (meaning you gotta have the moves).
But an artfully crafted solder joint is no
more/less risky to meeting design goals than
a crimped connection.
bobnoffs
PostPosted: Tue Sep 27, 2016 3:58 pm    Post subject: solder splices Reply with quote
ok, away we go. i like my soldered joints more than any crimped joint cuz i made them.
 bob
On Tue, Sep 27, 2016 at 7:36 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
hi all,
 bob noffs
  of location.
PostPosted: Wed Sep 28, 2016 8:14 am    Post subject: solder splices Reply with quote
Understand.
See http://tinyurl.com/dgg2nb if you haven't already.
rv8iator(at)gmail.com
PostPosted: Wed Sep 28, 2016 10:12 am    Post subject: solder splices Reply with quote
The stress riser that occurs at the interface between wire strands and solder filled wire strands if not mechanically supported is a candidate for fatigue failure due to vibration induced flexing.
This is true of field splices and soldiered pin/wire connection.
Good mechanical support/strain relief is imperative to prevent fatigue failure of the connection/soldier joint.
A good crimped connection does see a stress riser at the crimp/wire interface... BUT the transition is not as sharp as with soldier wicked into wire strands.  Crimped pins the wire are generally supported upstream from the crimp thus creating a mechanical support for the connection.
Chris Stone
On Tue, Sep 27, 2016 at 5:36 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
hi all,
 bob noffs
  of location.
