Posted: Sat Oct 01, 2016 2:34 pm Post subject: AEC 9005 |
At 04:45 PM 10/1/2016, you wrote:
| Quote: | Thanks Bob! What kind of product do you use for the coating?
I can think of some other projects that can benefit from that.
The 'in-crowd' uses a mil-spec polyurethane
coating specifically crafted for etched circuit
boards. In the 'po-boy' world, a clear poly
by Krylon, Deft, et. als. will suffice.
You can get it at any hardware or big-box
store. Here's one example.
http://tinyurl.com/gpsdkh4
It doesn't need to be this specific product.
Any of the clear poly's are fine. You need
to mask off connectors. Getting that stuff
into a d-sub is . . . well . . . you get
the picture.
I clean a board of solder-flux and other
guck with the spray from a can of carburetor/
air intake cleaner (a close cousin to lacquer
thinner). Walmart sells a can of it for a
couple of bucks . . . I buy this stuff by
the case for a host of cleaning tasks.
http://tinyurl.com/h8ppujv
Walmart may have the polyurethane too . . .
hlbartel(at)pld.com Guest
Posted: Sat Oct 01, 2016 3:50 pm Post subject: AEC 9005 |
I like your input about using the carburetor cleaner, but I have acquired an allergy to that product. I have found a product from CRC Industries that I like very well, but have not yet used it on circuit boards for cleaning. Here is a link to the product, and all our local auto parts stores stock it.
http://www.crcindustries.com/ei/product_detail.aspx?id=05018
What would be your take on using it instead of carburetor cleaner for that purpose?
Harry
Posted: Sat Oct 01, 2016 6:39 pm Post subject: AEC 9005 |
At 06:46 PM 10/1/2016, you wrote:
| Quote: | Bob,
What would be your take on using it instead of carburetor cleaner for that purpose? |
High order probability of success. When
cleaning a newly assembled board, products
of assembly (flux mostly) needs to be removed
before coating. Depending on type of flux, it
MIGHT just come off with water. I used to assemble
my products with a water soluble flux and run
finished boards through he dishwasher.
But without knowing the specifics of what
ever solder flux you have (or perhaps other
contaminants acquired with service/age like
Mr. Yates board), a more universal solvent
can be considered. 91% isopropyl alcohol from
Walmart is often sufficient but it doesn't come
in a handy spray can. Mild solvents like paint
thinner/toluene/naptha work but again, not so handily
packaged. The carb cleaner has proven suitable
to my tasks for decades. I flush generously and
immediately blow dry with an air hose.
The biggest risk for solvent selection is
picking something too aggressive . . . MEK
comes to mind. Does a NICE job of getting
flux off. Also removes paint stripes
from resistors and melts some of the lesser-
robust plastic parts.
An on-purpose board cleaner . . .
especially from the likes of CRC is very
likely a well proven product.
