		| Author | Message |
		| graeme.hart(at)onecoolkat Guest
				|  Posted: Sun Oct 02, 2016 1:43 am    Post subject: Trim Damper Bolt Length |   |
				| Hi All
 I am attempting to assemble the Trim Damper system but the M5x60 bolt appears too long and is hitting the bracket TS02.
 I have used an FL14 spacer and AN960-416L washer on both sides of the bellcrank bearing.
 Have I done something wrong or am I supposed to trim the M5x60 bolt to a suitable length?
 Thanks for any advice.
 Graeme
		| Back to top |  |
		| h&jeuropa
				|  Posted: Sun Oct 02, 2016 3:55 am    Post subject: Re: Trim Damper Bolt Length |   |
				| Graeme,
 You should not have to trim the M5 bolt.
 TS03 bellcrank is supported by AN4-15A bolt with two FL14 spacers.
 The friction assembly attaches to the bellcrank in the hole aft of the bellcrank bearing.  Fig 2 page 19-2 shows how the friction assembly is made.  The M5 bolt is secured by M5 nyloc and check nuts.
 Hope this helps.
 Jim & Heather
		| Back to top |  |
				|  Posted: Sun Oct 02, 2016 11:48 am    Post subject: Trim Damper Bolt Length |   |
				| Thanks Jim and/or Heather
I realise my mistake now.  I was trying to install the M5 bolt like a normal bolt with the head up against the nut end of the TS04A shaft.
 Looking at figure 6 on page 4 I realise that there is a gap between the head of the nut and the end of the shaft.
 Now I just need to order some replacement TS04B friction washers (due to me getting some nickel anti seize compound on them).
 Thanks again
 Graeme
 On Mon, Oct 3, 2016 at 12:55 AM, h&jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
  	  | Quote: |  	  | --> Europa-List message posted by: "h&jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
 Graeme,
 Hope this helps.
 Jim & Heather
 http://forums.matronics.com/viewtopic.php?p=460884#460884
 FORUMS -
 WIKI -
 b Site -
 -Matt Dralle, List Admin.
		| Back to top |  |
